Old 09-04-2019, 10:40 PM #1
Dirtrider216 Dirtrider216 is offline
Dirtrider216 will become famous soon enough
Just a random question about long travel suspension
Like the title says, just a random question about LT suspension that I don’t quite understand.
What I do understand is that LT suspension for the 4Runner adds +2 or +3.5 etc inches to each side of the front wheel track width totaling 4 or 7 inches wider overall
But that’s just in front isn’t it? Is there a way, specifically on 4runners to get the same track width increase in the rear of the vehicle or is that something everyone just deals with and doesn’t really talk about due to the performance benefits of LT suspension?
2006 limited v8 4wd
Toytec/ebiach 3” coilover lift with 1/2” top plate spacers, Jba high caster UCA’s, blistein 5100 rear shocks with toytec superflex hd springs, Cooper st max 255/80/17 with mb 352 in 17x9 -12 mm offset, auxbeam light bar in front bumper, custom retrofit headlights, SS brake lines, 5th gen brakes, custom rear storage box
Dirtrider216 is offline   Reply With QuoteReply With Quote
Old 09-04-2019, 11:21 PM #2
Inv4drZm's Avatar
Inv4drZm Inv4drZm is online now
Inv4drZm's Avatar
Having a wider rear axle doesn't really net you much in terms of wheel travel, or any other sort of performance. Running different offset wheels in the rear or adding wheel spacers to the rear can accomplish that but it would mainly be for looks in matching the front.
The reason LT front kits widen track width is purely so they can achieve more travel. I don't think stability is greatly or noticeably increased by adding only 3.5" each side.
Inv4drZm is online now   Reply With QuoteReply With Quote
Old 09-04-2019, 11:58 PM #3
BlairB's Avatar
BlairB BlairB is offline
Real Name: Blair
BlairB will become famous soon enough
BlairB's Avatar
Real Name: Blair
I have a +2" kit on my truck and just run Spidertrax in the rear. It keeps the width close enough you never even think about it.
2008 4Runner Sport Edition 4WD V6- Long Travel, Camping Rig Build Thread
2023 Lexus LX600 F Sport- Daily Driver
2023 Highlander Hybrid Limited- Wife Daily Driver
BlairB is offline   Reply With QuoteReply With Quote
Old 09-05-2019, 10:03 AM #4
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
very good question. i didnt know a lot of those guys were running wider tracks in the front with those setups...kind of irks me or seems wrong.
hinmo24t is offline   Reply With QuoteReply With Quote
Old 09-05-2019, 07:14 PM #5
That’s what I was thinking.. even if just from an aesthetic standpoint
2006 limited v8 4wd
Old 09-05-2019, 07:49 PM #6
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Its crossed my mind many times, and I’ve talked to a few companies about it too being on/off the LT conversion over the past couple years.
Answer is how deep are your pockets... You can always have a custom length rear end built to match, but most don’t due to cost. The cheapest route is to just add spacers and or an offset rim as it gets you there or close enough without the drama. Personally I would be OK with keeping the rear a little narrower.
Considering the additional track width in the rear doesn’t contribute to the travel, I wouldn’t overthink it. At +3.5, expect it to looks wildly pre-runner. The problem with the 4Runner is unlike most truck people, many of us are not cutting into the cab to add shock hoops "bed cage" to bring the rear suspension up to the capability of the fronts.
I’ve come to the realization in my own build that unless I am willing to get into a custom rear, the fronts at +3.5 will most likely be overbuilt compared to the rest of the trucks capability. +2 gets you something a bit more balanced with a standard rear and the track increase also becomes much less of an issue. If anything I would consider pulling the fronts back in a bit with a different rim and go back to a stealthy stock look.
The biggest perk being I still get the added travel, and with the same/similar lift high as current 2.5 to 3", I basically recapture all of that droop I lost by lifting and normalizing the center-line of the suspension stroke. And not having to run fiberglass.
Old 09-06-2019, 12:39 AM #7
BlairB's Avatar
Real Name: Blair
BlairB's Avatar
Real Name: Blair
...and because photos always help, here is a +2" kit with 1.25" spidertrax in the rear. As you can see, you really don't even notice the difference in width.
I didn't do the +3.5" because the difference in width and not wanting fiberglass fenders.
Old 09-06-2019, 09:09 AM #8
Inv4drZm's Avatar
Inv4drZm's Avatar
Am I the only one with reverse-LT?
Old 05-10-2022, 06:07 AM #9
karitamiz's Avatar
karitamiz karitamiz is offline
karitamiz is on a distinguished road
karitamiz's Avatar
"A trip by car has many advantages - freedom of movement, going around more interesting locations, visiting non-touristy places, and spontaneously changing the route. It is a romantic idea, but it requires serious preparation. When I got a free ticket on Free Tours in Prague, Czech Republic | FREETOUR.com for a trip to Prague, I had a lot of problems on the way. Therefore, a mandatory rule for long trips is to check the car's condition. The car's technical condition in many respects will depend on the safety of a trip. If any problems are revealed at a car service center, they must be eliminated in advance. So that unforeseen situations on the road do not spoil your plans, take a set of ""ambulances"" for the car."
karitamiz is offline   Reply With QuoteReply With Quote
Old 05-10-2022, 10:37 PM #10
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Nice! You still doing the DSPM life?
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 05-22-2022, 06:15 AM #11
Direwolf82 Direwolf82 is offline
Direwolf82 will become famous soon enough
Agree, leaving the rear end narrower for me means if the front end will squeeze through a gap so will the rear and it'll give me a little more clearance turning next to an obstacle. Doesn't sound like much but my other truck is setup a few inches wider out front and it did make a difference in that thing.
Sent from my SM-A516V using Tapatalk
Direwolf82 is offline   Reply With QuoteReply With Quote
Old 05-22-2022, 02:30 PM #12
4wordSOUL's Avatar
4wordSOUL 4wordSOUL is offline
4wordSOUL is on a distinguished road
4wordSOUL's Avatar
Many aftermarket suspension vendors come up with clever terms like BOSS or ULTIMATE indicating the 'measurable' amount of performance their obfuscated marketing-speak tells you about what to expect from their products. Free your mind with Science and don't toy around with thoughts & prayers.
Toyota Long Travel IFS - Camburg vs Dirt King - YouTube
Suspension Construction and Limits | Everything About Toyota IFS Part 1 - YouTube
4 Common Myths About IFS Lifts | Everything About Toyota IFS Part 2 - YouTube
KDSS vs Swaybar Ultimate Test - YouTube
4wordSOUL is offline   Reply With QuoteReply With Quote
front , question , random , suspension , understand
Long Travel Suspension 3rd gen 4RUN0326 3rd gen T4Rs 38 01-23-2018 11:30 PM
Long Travel Suspension The.Bear.Runner Engines / Suspension / Wheels / Tires / Audio / Accessories 1 08-04-2015 07:04 AM
long travel suspension question pajamawally04 Classic T4Rs 2 04-01-2014 06:12 PM
Sas vs long travel suspension! B.peat Classic T4Rs 14 09-03-2013 05:36 PM
Long travel suspension rugger bugger Off-Roading 10 10-25-2006 01:21 AM
