Old 09-06-2019, 05:21 PM #1
Quiero Quiero is offline
Quiero is on a distinguished road
Suddenly blowing hot air (no AC)
07 4th gen SR5 4WD V6 160k miles
The AC is suddenly blowing hot air. Compressor does not appear to kick on or try to engage. It worked great yesterday morning, blowing cold as ever. During the afternoon, nothing. This make me think its not pressure related.
A few weeks ago the AC light blinked a few times, but then stopped and its been working fine since. I swapped out the relay with the foglight relay and it still isn't working.
Magnetic clutch?
I dropped it off at my mechanic as I'm going to be out of town all weekend. Just bracing for what it might cost.
Thanks!
Quiero is offline   Reply With QuoteReply With Quote
Old 09-11-2019, 03:57 PM #2
Its the dreaded evap core. Seems to be a problem on these trucks.
$1200 including a new heater core and new blower motor sounds like a bargain from my local guy after looking at how much work is required.
Old 09-17-2019, 04:29 PM #3
Kardolf Kardolf is offline
Kardolf is on a distinguished road
Independent shop, chain, or dealer?
Kardolf is offline   Reply With QuoteReply With Quote
Old 09-18-2019, 08:04 AM #4
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
If you sprung a freon leak the compressor will not kick in. Have you put gauges on it to check high/low pressures?
08TxRunner is offline   Reply With QuoteReply With Quote
Old 09-18-2019, 08:32 AM #5
Captsolo Captsolo is offline
Captsolo will become famous soon enough
Magnetic clutch?
Thanks!
I replaced a 12 year old compressor in my 2005 4runner and AC pumped cold again.
Cost was $198 (new Denso) + $200 installation by experienced AC tech included recharge and evac system so as not to ruin new AC compressor by Denso (sold by Amazon)
All the rest of AC is OEM. SR5 2005 145,000 miles V6.
Tech put dye in system to find leak and drove for two weeks...
Captsolo is offline   Reply With QuoteReply With Quote
Old 09-19-2019, 02:52 PM #6
Yeah they charged and tested with dye on mine as well. They could not find the leak anywhere and he suspected it was the evap core. He was right.
Very highly trusted independent shop in Las Vegas. I just got it back yesterday and they did a great job. Total damage was about $1300 but I had them include a new blower motor & new heater core while they had it all apart.
Old 06-18-2021, 09:52 AM #7
TraceyMills TraceyMills is offline
TraceyMills is on a distinguished road
If the unit does not start and there is no corresponding hum, disassemble the compressor only after checking the voltage. An indicator is ideal for this purpose. If there are phases, it is advisable to check the fuse, which also often fails. If the fuse blows again, there is a possibility of a short circuit in the system. There is a possibility that the motor has severe mechanical damage. Operating under heavy load, overheating, or voltage fluctuations are the reason why the unit fails. So you need to contact a good handyperson. Good luck
TraceyMills is offline   Reply With QuoteReply With Quote
air , blowing , relay , suddenly , working
Help. 4lo beeping suddenly, can’t figure it out depth 4th Gen T4Rs 14 08-20-2018 04:51 PM
A/C Starts Blowing when in Defrost(windshield blowing) setting Frank12 3rd gen T4Rs 9 10-21-2017 07:23 PM
Help: Battery Suddenly Died Grape Ape 5th gen T4Rs 19 08-28-2014 07:59 AM
Brakes suddenly ! one-4-one Problems & Warranty Issues 5 06-25-2011 09:02 PM
Handling sucks suddenly... Kraeken 4th Gen T4Rs 2 04-14-2010 04:34 PM
