Old 10-09-2019, 09:15 PM #16
Hunter.Cribb's Avatar
Hunter.Cribb Hunter.Cribb is offline
Real Name: Hunter
Hunter.Cribb is on a distinguished road
Real Name: Hunter
Originally Posted by AuSeeker View Post
Thanks, did you go with the KYB Plus or just the KYB shock and your OEM springs?
KYB Plus
2006 Limited V6 4WD, Natural White (Sold)
2006 Limited V8 4WD, Salsa Red Pearl
Hunter.Cribb is offline   Reply With QuoteReply With Quote
Old 10-10-2019, 10:23 AM #17
Originally Posted by dp3000 View Post
Hi,
Does anyone have a part number or link to the KYBs? Needing to change front and rear shock, after reading this I think I will use the KYB shock and spring combo in the front.
check rockauto for them, they have the best prices for kyb's & many other parts. & kyb might still be offering a rebate.
Old 10-10-2019, 12:10 PM #18
You say the KYB plus front shock provides a little bit of lift from stock, could you measure from the fender opening to the center of the hub/wheel so I can compared it to mine?
I will be doing my shocks in the near future and I'm thinking of going with the KYBs and I want to compare your measurement to mine which has a 1" spacer in it at present.
measured mine today. from center of cap to bottom of fender is 20.5". i usually measure from the ground to bottom of fender & that is 35.5" with 265/70/17 tires on stock sport rims.
hopes that helps
Old 10-10-2019, 05:34 PM #19
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Originally Posted by Hunter.Cribb View Post
Mine is 20 1/2 in from the center of the wheel with the KYB installed
hopes that helps
Thanks to both of you for the measurement, that's the same as I have with a spacer installing so the KYB Plus shock will have me setting at the same height as I am now which I like the way it looks and drives.
I always measure from the fender to the center of the wheel which give you a truer measure of how much lift one has, when measuring from the ground the actual lift is not known from one T4R to another because of the different sizes of tire everyone has, even the same size tires vary from brand to brand a little bit.
2004 Limited V8
Old 10-11-2019, 01:25 PM #20
when you first install them the lift will be much higher, it took about 1000 miles for mine to settle to where they are now, & after another 1000 miles it hasnt gone any lower. you should also like the ~10% stiffer springs & shock valving compared to the stock (worn?) shocks/springs.
yes i agree measuring from center of cap/hub is a better way to judge lift, i guess i do from the ground on my vehicle(s) because my tires are the same before i did the shocks.
report back when you install the kybs, curious to hear how you like them.
Old 10-11-2019, 07:02 PM #21
Real Name: Skip
Real Name: Skip
I will report when I do the shocks but it will be at least a year or so, my shocks now aren't all that bad at present and I will be redoing all of my brakes and then replacing the timing belt before anything else.
2004 Limited V8
installed , kyb , left , part , strut
Kyb strut plus titan34 4th Gen T4Rs 11 08-28-2019 11:03 AM
Has anyone installed KYB Strut-Plus units? by-tor 4th Gen T4Rs 9 12-03-2018 09:30 AM
Installed Bilsteins 5100 last night... front strut question Patrickg 4th Gen T4Rs 14 07-24-2015 02:55 PM
Strut Top Nut blaze17 3rd gen T4Rs 7 03-28-2015 03:06 PM
OME 881 Coils-3" Lift Front Strut Assy w/KYB Gas-A-Just strut-3rd gen runner STRRAYNGE For Sale: Suspension/Wheels/Tires 7 04-30-2012 09:44 PM
