Old 09-09-2019, 11:38 PM #16
montijo505's Avatar
montijo505's Avatar
Originally Posted by Bluesky 07 View Post
It does seem odd and I don't have the expertise to know one way or the other, I was just going on the fact it was pronounced before the seals went in and gone after. Got it aligned today and the left caster & toe + right toe were all significantly off.
Driving much better but there's still a wuh-wuh-wuh sound that varies with wheel speed and seems to be coming from the right front. It's faint but definitely noticeable. Sure thought that was going to disappear once the new bearings were in. Guess I'll be spending some time going through the front end noise threads.
Sounds like you may have slightly bent one of the dust shields during re install. Make sure they’re not touching the rotors. If it is, just bend it back. Good place to start checking.
Old 09-10-2019, 08:14 AM #17
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Thanks, I appreciate the suggestion but the sound was there before the bearing install. I thought it was one of the bearing symptoms and would go away after the replacement, but that didn’t happen.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 09-10-2019, 10:51 AM #18
metramm metramm is offline
metramm will become famous soon enough
I would be interested to hear the outcome of the wha-wha-wha noise as i have personal experience with this and never found the answer.
Before my 4runner and 05 Acura TL I had a sweet 93 SC 300. Friend of mine was hot dogging it and drifted into a curb and bent the rear control arms and some other stuff costing me almost 1k to fix.
Anyways, from that day on, I had that wha-wha-wha noise that varied with speed just as you describe.
I had the diff, rear bearings, rims, etc checked and the mechanic found nothing.
Never did figure it out and eventually traded it in for the Acura since the sound was driving me crazy.
Hope you get yours resolved!
Metramm
2006 4Runner Limited 4x4 v6
241,000 miles and counting!
metramm is offline   Reply With QuoteReply With Quote
Old 09-10-2019, 12:02 PM #19
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
what condition are the front tires in? snap a couple pics of the tread area.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 09-10-2019, 05:35 PM #20
Bluesky 07's Avatar
Bluesky 07's Avatar
Left Front
Right Front
Old 09-12-2019, 02:56 PM #21
Fried Rice Fried Rice is offline
Real Name: Dillon
Fried Rice is on a distinguished road
Real Name: Dillon
I’m interested also as I have the same thing going on. I have replaced the front wheel bearings and the axles (which needed replacing anyway) as well as all the brake parts but still have the noise.
Good luck!
Fried Rice is offline   Reply With QuoteReply With Quote
Old 09-12-2019, 06:35 PM #22
nevada's Avatar
nevada's Avatar
Left Front
Right Front
they don't look too bad. the reason I asked to see them, is sometimes if an aggressive tread is worn badly, it can make a noise similar to what you were describing.
Old 09-12-2019, 10:09 PM #23
Bluesky 07's Avatar
Bluesky 07's Avatar
Yes, it was a good suggestion to check the tread.
Old 09-12-2019, 11:18 PM #24
djkurious djkurious is offline
djkurious is on a distinguished road
Good luck!
Following also. I have replaced the same items and tie rods.
2003 4Runner SR5 V8
319k and counting...
djkurious is offline   Reply With QuoteReply With Quote
Old 10-27-2019, 11:45 AM #25
Bluesky 07's Avatar
Bluesky 07's Avatar
Well, there was a serious & embarrassing flaw in my logic: when the noise started has nothing to do with the cause. That occurred to me & I finally had a chance to check today. Guess what? Bent passenger side dust shield.
Old 10-27-2019, 03:25 PM #26
Terminator03 Terminator03 is offline
Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough
Glad you found the source! I haven’t tracked mine down yet and was assuming it was the bearings. I need to replace the driver's side dust shield anyway due to rust, so I was planning to just replace the bearings since it needs to come apart anyway...
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
Old 10-27-2019, 07:29 PM #27
Bluesky 07's Avatar
Bluesky 07's Avatar
Not as fixed as I thought it seems...noise is much better but still there right at 40mph. Wondering if the shields are getting bent when I reinstall the wheels.
Old 10-27-2019, 08:34 PM #28
Direwolf82 Direwolf82 is offline
Direwolf82 will become famous soon enough
I do know that some wheel bearings, most of the ones I've done on various vehicles, do NOT come packed with grease. Do you know if it was pre packed or did you pack it before install?
Dry bearings, even new, can give an odd sound at certain frequencies/rpm.
Hopefully you get it figured out.
Direwolf82 is offline   Reply With QuoteReply With Quote
Old 10-27-2019, 08:42 PM #29
Real Name: Skip
Real Name: Skip
The front wheel bearings are a sealed bearing, no need to grease them, couldn't grease them even if you wanted too.
2004 Limited V8
Old 11-01-2019, 10:04 PM #30
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Don't rule out rear bearings. I swore my fronts were bad when i purchased my vehicle and the dealership replaced a rear under warranty and it fixed a rear left when I swore it was a front left.
gaber6 is offline   Reply With QuoteReply With Quote
front , how-tos , installed , knuckle , part
front end wobble/shimmy! 01thunder 3rd gen T4Rs 12 10-06-2017 05:29 PM
Vsc, shimmy shimmy shake rattle & buzz lcbjr77 4th Gen T4Rs 3 01-14-2016 05:47 PM
Install of new CV axle and Front Bearing Hub hkollie1 4th Gen T4Rs 5 09-30-2012 03:22 PM
Little Front End Shimmy on Highway bluecollarjock 3rd gen T4Rs 3 10-01-2011 07:35 PM
Front end shimmy when applying the brakes dcv2508 4th Gen T4Rs 4 11-08-2004 06:27 AM
