Old 09-08-2019, 05:48 PM #1
ktom3001 ktom3001 is offline
ktom3001 is on a distinguished road
Fox 2.5 DSC install questions/install
Installing Fox 2.5 CO with 600 springs. How much thread should be exposed in order to get ~3" lift? Out of the box is showing 2-3 threads, maybe 1/4".
Thanks!
Fox 2.5 DSC install questions/install-img_1618-jpg
ktom3001 is offline   Reply With QuoteReply With Quote
Old 09-08-2019, 05:52 PM #2
montijo505's Avatar
montijo505's Avatar
Only one way to find out......
Old 09-08-2019, 06:39 PM #3
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
The easiest way to adjust them is on the vehicle right? In order to hold them secure enough to thread the collars.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 09-08-2019, 07:14 PM #4
I've heard mixed reviews on this. Certainly the older version with 2 rings it's very difficult. Even with the single ring version it sounds like it's hit an miss.
I don't mind making small adjustments on the vehicle but I'd prefer to not have to spin the collar down 3-4".
Old 09-09-2019, 07:31 AM #5
blackoutt's Avatar
blackoutt blackoutt is offline
blackoutt has a spectacular aura about blackoutt has a spectacular aura about
blackoutt's Avatar
They aren't too bad to adjust installed with that corner jacked up. Only loosen the pinch bolt enough to spin the collar, too loose and it'll jump threads. LUBE it up good. The spanner tools that come with coilovers are junk, get a big punch that fits the holes (3/8" I think? don't quote me there). Mine have ~1-1/4" thread showing for 3" lift v8 with dual battery and twin compressor up front, no bumpers or winch.
blackoutt is offline   Reply With QuoteReply With Quote
Old 09-09-2019, 11:08 AM #6
Do you know what springs you have? It looks like mine came with 14" 600 lb springs. I'm surprised you got 3" lift with such little thread showing, that's encouraging. Thanks for the feedback
Old 09-09-2019, 12:12 PM #7
blackoutt's Avatar
blackoutt's Avatar
I could check the part numbers when I get home but I didn't specify spring when I ordered so I assume they are the standard 14" 600#.
Old 09-09-2019, 12:20 PM #8
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Nice shocks… looking forward to hearing about them.
Old 09-09-2019, 12:37 PM #9
snivilous's Avatar
snivilous snivilous is offline
snivilous will become famous soon enough snivilous will become famous soon enough
snivilous's Avatar
Pretty sure that's the hardest possible way to adjust them. If you know what they need to be adjusted to it's about 1000x easier to put them on a bench and clamp the top hat or use a crow bar through the bolts and turn it. Can you adjust them on the truck? Sure, but it sucks dick with everything in the way. If they're out already do them off the truck.
snivilous is offline   Reply With QuoteReply With Quote
Old 09-09-2019, 02:14 PM #10
Yeah I agree. Fox is claiming they're preset for 3" lift, I don't see how that's possible with so little thread showing. These are supposed to be for 0-3" lift so there's no way to back them off to 0"?
I just want to get it close so I'm not turning it so many times on the vehicle.
Old 09-09-2019, 03:01 PM #11
snivilous's Avatar
snivilous's Avatar
My girlfriend has the normal 2.5" Fox coilovers, I would assume the spring is the same but I can't find any markings saying the rate that are (easily) visible. She's at 22" hub to fender and 2.75" of thread showing. She has an aluminum plate bumper and that's it.
Old 09-10-2019, 07:47 AM #12
blackoutt's Avatar
blackoutt's Avatar
Counted mine for ya, I have 12-13 threads showing above the collar. There are older versions with shorter springs which might be where people are getting the 2.75" thread showing. I know looking at another guy's build before I bought mine he had about 3" of thread showing.
Old 09-10-2019, 12:05 PM #13
Thanks for checking. I'll count 12-13 for a starting point and set the driver side a little higher. Hoping it's not too difficult to adjust on the vehicle.
Excited to try this set up as I was never too fond of the 5100/Tacoma spring combo. Always felt bumpy and stiff at the top but would blow through the travel on big bumps.
Old 09-10-2019, 10:43 PM #14
Kaleo Kaleo is offline
Kaleo is on a distinguished road
Please keep us updated as I'm interested to know how much lift you get from 12 threads showing. Thanks . Do you have any added weight? What did you use in the rear?
Kaleo is offline   Reply With QuoteReply With Quote
Old 09-11-2019, 07:55 AM #15
blackoutt's Avatar
blackoutt's Avatar
That was my exact impression of 5100s as well. No complaints with the Fox with DSC, high speed compression always set at highest setting, low speed compression all the way low for slow offroad crawling, all the way high for "aggressive street driving" but usually a couple clicks back off of highest setting for daily driving or long road trip comfort.
1/4 , 2-3 , fox , showing , threads
NEED HELP! Hub install Antman 5th gen T4Rs 36 06-24-2022 10:21 AM
Bilstein Rear Shock Install vs. Stock Install Question HairyMan 3rd gen T4Rs 7 08-21-2015 09:51 AM
Toytec BOSS kit Install - Tools required and Tips for the install. Land_Shark 5th gen T4Rs 6 06-18-2014 12:36 PM
Can I install XM? pittpanthers Engines / Suspension / Wheels / Tires / Audio / Accessories 3 11-09-2009 11:43 AM
