06-01-2014, 11:38 AM
Any writeup for replacing fuel injector o-rings
I've searched and can't find a thread on replacing 4th gen fuel injector o-rings. I'm pretty sure my rough idle and fuel smell is due to those going bad. Thanks.
09-08-2019, 07:52 PM
Real Name: Brandon
Real Name: Brandon
It’s super easy. I’m mechanically inclined because I’ve worked electric/H/VAC since i was 11 with my dad.
No experience on cars besides this forum and youtube.
All you need is a socket set and I used a hex set with a socket driver. Only 3 bolts but idk how you’d do it without it. Access is limited and a normal Allen key won’t do.
Fuel injector work is super easy. Just removing bolts and taking things apart.
Keeping organized is harder than the job. 2 hours max and I was drinking and smoking. Haha
I replaced one of my injectors because of heavy idle. It seemed to work for a few weeks but the heavy idle is still there randomly. Cold. Never once it’s warm.
I’ve done compression tests. Pass.
Coolant pressure test- fail. No visible leak anywhere.
Coolant gas combustion test- PASS. What!?!?
I’ve cleaned Throttle body and MAF.
I ordered magnaflow exhaust, CSF radiator, new water pump and fan clutch, a/c condenser (only because it’s bent and will impede the new larger radiator. I’m guessing?) and Hayden trans cooler.
I’m going to throw all that in and pray for the best.
09-09-2019, 08:36 AM
Make sure you lube the o-rings before you put things together. The last thing you want is a torn or punched o-ring after all that work.
09-09-2019, 12:17 PM
bookmarked, have a persistent p0174 and an intermittent p0304, swapped coils, and p0304 persists.
previous poster 's naration makes it seem like an easy procedure, wish i could see a youtube video. as i intend to swap out all bank 2 injectors with ebay remanns, saw a set of 6 for $60
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto...... sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
09-09-2019, 02:50 PM
V8 or V6? The V6 FSM on here has a section for Fuel Injector Assembly replacement. See the attachment.
For the V6, make sure you start by pulling the C/OPN relay in the engine bay, then run the engine until it runs out of fuel. This depressurizes the fuel system. Then disconnect the battery.
After that it's basically just pulling things off the top of the engine to get to the fuel rail. The FSM covers how to remove the fuel rail, but you don't need to do that. Just unbolt the injectors and replace the o-rings.
Make sure you lube the new o-rings with gasoline before installing. And make sure the injectors are properly seated while installing and tightening the bolts.
It's not a difficult job, just takes some time to get to them.
09-09-2019, 09:39 PM
Real Name: Elliott
Real Name: Elliott
Just throwing in my .02, but if you are going thru the trouble of removing the fuel rail to replace orings, replace the injectors too, and the fuel pressure regulator. They are all part of the fuel rail, and it would be incredibly frustrating to have it in your hand, put it back in, and need to replace it in a couple months or less. Handle it once.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
09-09-2019, 09:43 PM
Real Name: Elliott
Real Name: Elliott
I used those, the Denso remans work great. Again, the fuel rail has all 6, so it makes sense to replace all of them since you have it apart.
