Old 09-09-2019, 11:06 PM #1
NorthWesty NorthWesty is offline
NorthWesty is on a distinguished road
Problem when installing Bilstein 5100
Hey,
I am having issues installing my Bilstein 5100 struts...
I have been using the no-spring-compressor method and have followed step by step instructions on the process.
I have also bought the Moog FJ coil springs for the front.
Once I started to jack up the lower control arm to compress the spring, I could never get the shock to protrude enough at the top. I tried all settings for the perch and even on the stock height setting I could not get it.
I ended up switching back to the stock coil and was finally able to get the top nut on. However, once I got it all buttoned up and lowered the truck back down to the ground, the springs never compressed enough and the truck has about a 4 inch lift in the front. On stock springs, I do not think that's a good thing.
What am I doing wrong here? I haven't heard of anyone else having this problem. It seems like a very common job.
Here is a pic of what it looks like now on the stock springs, 5100s set to stock height...
Problem when installing Bilstein 5100-received_527984357775191-jpg
NorthWesty is offline   Reply With QuoteReply With Quote
Old 09-09-2019, 11:41 PM #2
montijo505's Avatar
montijo505's Avatar
Originally Posted by NorthWesty View Post
Hey,
I may be mistaken but if one of the parts (don’t remember which one) is upside down, this is the result. I’ll look for a thread and try to post. In the meantime post photos of how it’s assembled to see if someone with the same stuff can confirm it’s correct.
Old 09-09-2019, 11:46 PM #3
TejasRunner01 TejasRunner01 is offline
TejasRunner01 will become famous soon enough TejasRunner01 will become famous soon enough
Honestly I suggest renting a spring compressor. They aren't as difficult as you may think. Just zip everything in place and you can install it in no time. Also you should get your money back when you return it. Good luck!
Sent from my Mi MIX 2S using Tapatalk
TejasRunner01 is offline   Reply With QuoteReply With Quote
Old 09-10-2019, 12:26 AM #4
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
I just did the same install last week and had no issues. Can you post a pic of the shock/spring configuration?
Which Moog spring?
And you're on the lowest "0" setting on the 5100s?
Jack stands on the frame on both sides?
Or one side at a time?
eleven14 is offline   Reply With QuoteReply With Quote
Old 09-10-2019, 01:20 AM #5
ktom3001 ktom3001 is offline
ktom3001 is on a distinguished road
Sounds like the spring perch is upside-down on top of the height clip. If I remember correctly you will not be able to see the clip when the perch is installed correctly.
ktom3001 is offline   Reply With QuoteReply With Quote
Old 09-10-2019, 01:58 AM #6
Hey guys thanks for the quick responses.
Noobie mistake, it was that the spring purchases were upside down. Able to get the Moog springs in after all.
Cheers,
Tanner
Old 09-10-2019, 09:12 AM #7
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
LOL, I did EXACTLY the same thing my first time. Glad you figured it out.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 09-10-2019, 10:16 AM #8
Berty_K's Avatar
Berty_K Berty_K is offline
Berty_K has a spectacular aura about Berty_K has a spectacular aura about Berty_K has a spectacular aura about
Berty_K's Avatar
If you ever end up installing heavier springs, place a jack stand below the opposite rear lower control arm mount before jacking up the front control arms. Will give you more compression.
I needed to do this when I was installing my preload spacers
'08 Silver SR5 V6 4x4: OEM+
Berty_K is offline   Reply With QuoteReply With Quote
coil , front , problem , springs , stock
Need help! Bilstein 5100 very odd problem RainyDayRunner New Members 4 02-12-2017 12:45 PM
'97 4R problem installing Bilstein rear shocks DUK-RNR 3rd gen T4Rs 4 05-26-2016 08:12 PM
Bilstein 5100 install problem ToyoTitus 3rd gen T4Rs 6 02-23-2016 12:11 AM
Bilstein 5100 with FJ Spring problem Rjameseast 4th Gen T4Rs 9 02-22-2015 10:44 AM
2013 TE problem with rear Bilstein 5100's CaliTE 5th gen T4Rs 18 04-09-2013 05:08 AM
