09-10-2019, 04:05 PM
Real Name: James
Real Name: James
Air Leak Up Front
There is sound coming from the front right, not too loud, but definitely noticeable. A shop looked at it and the dx was "cracked Y pipe". The number they quoted was $1100...not chump change. I think the part is pricey.
Can a shop that does welding fix this if not too bad? The dealer CSR suggested that to me at the last O/C and roto...
Any insight would be much appreciated, as always.
Regards, sport2004
Gotta Start Somewhere 2004, V6 Sport 4WD (French Speaking), All LED interior lights, LED reverse lights, Weathertech-laser cut floor mats up front, 2nd row Weathertech-laser cut floor mats , OEM Extreme cargo liner, 4LO aint hap'nin
09-10-2019, 04:10 PM
Y-Pipe as in exhaust? Doug Thorley or URD's y-pipes are around $500.
But yeah any welder should be able to patch it easily.
Any pics? I want to see what a cracked Y pipe looks like!
09-10-2019, 04:15 PM
Real Name: James
Real Name: James
Thanks, me, too...but I think they dropped the belly pan and then used a mirror to ge a look at it. A part number would be useful, but then I'm not sure about that. The installer for the suspension parts installed last Spring may have someone, they were really good (and they're chomping at the bit to beef up the suspension...LOL).
Regards, sport2004
09-10-2019, 04:52 PM
Real Name: James
Real Name: James
Dealer wants $1227.00 for the part
Regards, sport2004
09-10-2019, 05:17 PM
2003 Galactic Gray Mica Limited V8
Inside: Pioneer AVH-2300NEX w/ backup cam | Dometic CFX3 55im | Custom floor w/ table & drawers
Outside: Hefty Fab Bumper | Warn ZR 10-S | RCI skids & sliders
Electrical: 150w solar panel | Victron MPPT controller | BlueSea breakers and panels
Suspension & Tires: Bilstein 5100's w/ Dobinson c59-314 & c59-329 | 5th Gen Trail wheels & Wildpeak A/T3W 275/70/17
09-10-2019, 05:32 PM
Real Name: James
Real Name: James
Originally Posted by jcaino
Thanks, I did see that after the comment of
@ Inv4drZm
Regards, sport2004
09-10-2019, 07:34 PM
Mangaflow has some direct fit y-pipe pieces if you want to keep the rear cats. You can even order them on Amazon.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
'08 Limited V8 Supercharged: URD // Doug Thorley // Rotora // Titanium Works // JAUS // Toytec // Bilstein // Fuel Shok // Nitto // Icon // Hefty Fabworks // RCI // CBI // Shrockworks // Baja Designs // Auxbeam // Fiberwerx // Addco
09-10-2019, 07:59 PM
Depending on how badly cracked or what type of patch job is needed… would it be possible to have an exhaust / muffler shop weld the seam and a quick fix? I suspect this would be pretty inexpensive.
09-10-2019, 08:24 PM
Real Name: James
Real Name: James
that's what i'm hoping...if there is rust, that wouldn't work
Regards, sport2004
09-10-2019, 08:25 PM
Real Name: James
Real Name: James
Originally Posted by Satori
thanks will check it out
Regards, sport2004
09-11-2019, 11:40 PM
Real Name: Leonard
Real Name: Leonard
Read the title, didnt know they made these with a compressor and tanks to run an air sytem. LOL.
Truck driver here, air leaks are a bad thing.
Having fun's build
09-12-2019, 11:22 AM
Real Name: James
Real Name: James
Originally Posted by having fun
read the title, didnt know they made these with a compressor and tanks to run an air sytem. Lol.
lol...no air bags
Regards, sport2004
01-22-2020, 05:16 PM
Real Name: James
Real Name: James
Well, I've been limping along with this, however, some heavy snow on the roads over the weekend must have increased the damage, causing a little more noise, which I hate.
Anyway, found a shop that says they can source a "Walker" aftermarket Y pipe, which does include one integral cat, and install for about 850...of course, when they start breaking things down, could have some other rust-damaged components in bad shape...we'll see.
Regards, sport2004
