Old 09-11-2019, 10:40 AM #1
JoshuaHufford JoshuaHufford is offline
JoshuaHufford is on a distinguished road
Coolant temp while towing.
07 V8, towing a camper that weights about 3500lbs. I always use the Torque app while towing to keep an eye on the trans and coolant temps.
While going up a decent grade about a half mile long, trans had to downshift to 3rd to maintain 60mph. By the time I got to the top the coolant temp had hit 220F. Is this normal or anything to be worried about?
The ambient temp was about 85F, I had the AC on. Up to this point I had been driving for about 90 minutes averaging between 50-60mph, on a windy, hilly road, but most of the hills are small until this one. The temps had been between 190-200F for most of the drive.
I live in Missouri so this is about the as tough as towing gets around here, but at some point we would like to take a trip out west with the camper, obviously the air will be thinner and the mountains will be a lot steeper and longer, don't want to run into trouble!
JoshuaHufford is offline   Reply With QuoteReply With Quote
Old 09-11-2019, 11:33 AM #2
MT Runner's Avatar
MT Runner MT Runner is offline
MT Runner is on a distinguished road
MT Runner's Avatar
Your engine coolant hit 220? Or your trans temp hit 220?
I tow a similar weight with my V6 here in Montana, so I see a lot of pretty good size hills. Elevation is between 3,400 and 6,000ft pretty much anywhere I go.
My engine coolant is between 198-204 no matter what Iím doing. Driving around town without a trailer or towing my camper up a hill in the summer at 60mph.
Trans temp can vary greatly. When Iím towing the camper on flat ground on the interstate and cruising in 4th gear, trans temp is usually around 160-170.
Its pretty common for me to get around 200 on a hill if itís decent size, but it drops right back down as soon as Iím over the hill.
The highest temp Iíve ever seen on my scangauge for the trans was 232, it was a long, gradual hill, with a headwind and I had been towing for over 3 hours at that point. It cooled back down once I finally hit level ground again.
I think if you hit that 220-230 range going up a hill but then it drops back down to well under 200 under your normal driving conditions, you should be fine.
220 isnít an extreme temp necessarily, but you definitely wouldnít want to tow a long distance at that temp. Itís getting on the warm side for sure, but nothing I would stress too much about if itís not at that temp for the majority of your trip.
Iím not positive on this but I believe Iíve read that the ďdummyĒ light for the trans will kick on at 265 degrees, but by the time that does kick on, thatís way too hot.
2005 SR5 V6
URD headers and MAF Cal
AFE Intake
Dobinson 302 coils w/ 221 struts front, 505 coils w/ 705 shocks rear, JBA UCAís, 255/75R17 KO2ís, Level 8 MK6 wheels
MT Runner is offline   Reply With QuoteReply With Quote
Old 09-11-2019, 11:36 AM #3
MT Runner's Avatar
MT Runner's Avatar
One other question, are you towing in 4th or 5th gear?
190-200 seems a bit high for towing on flat ground. If you tow in 5th the trans is going to be constantly searching for the right gear even on the most minor of hills. Try towing in 4th for a little while next time and see where your trans temp is.
2005 SR5 V6
AFE Intake
Old 09-11-2019, 11:52 AM #4
nevada's Avatar
nevada nevada is offline
nevada will become famous soon enough nevada will become famous soon enough
nevada's Avatar
220 is still considered safe. but, I think its higher than it should be in that scenario.
how is the condenser? full of bugs and dirt? same with the radiator. I have seen them get very dirty directly behind the condenser, where its difficult clean.
also, how is the fan clutch. at that temp, it should have been engage, and likely you could have heard the roar. especially in 3rd at 60mph. if the clutch is getting weak, and not flowing quite enough air at heave loads, you could build some excess heat.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 09-11-2019, 12:26 PM #5
RonJR RonJR is offline
Real Name: Ron
RonJR will become famous soon enough RonJR will become famous soon enough
Real Name: Ron
A few miles at 220 or even 240 degrees isn't going to hurt a thing. The rate of breakdown of transmission fluid doubles roughly every 20 degrees F above 180 degrees. So, if transmission fluid lasts 100,000 miles at 180 degrees, it will last 50,000 miles at 200 degrees, 25,000 at 220, etc. If you extrapolate this out to 300 degrees, you will find the lifetime is about 1000 miles. Do an internet search on transmission fluid lifetime vs. temperature and you will see multiple web pages showing this relationship.
Now, you don't run at 220-240 degrees constantly when towing, just for short periods. So, a more useful way of looking at this is, every mile at 200 degrees is the same as 2 miles at 180. Every mile at 220 degrees is the same as 4 miles at 180. Every mile at 240 degrees is the same as 8 miles at 180.
So, if you pull a long, 7 mile grade in the Rockies with your transmission at a constant 240 degrees, you've just subtracted 56 (7x8) miles from your transmission fluid life. If you did that only once it would mean that, instead of changing fluid at 100K miles, you need to change it at 99,944 miles instead. Not a big change.
However, you'll generally run above 180 degrees fairly often when towing, which is why Toyota recommends a 50,000 mile fluid change interval for vehicles that regularly tow. It's kind of a simple rule of thumb that takes most of the above into account for the "average" person who uses their 4runner for towing.
I pulled our 3500lb Rpod up into the Snowy Range west of Laramie, Wyoming, last week. That's a 7 mile 8% grade. Outside air temperature was around 70 deg. I was running about 40 mph in 3rd and 2nd. Torque converter temps hit 240, and pan temps ran around 228. Pan temp is probably most important, because that's where the fluid spends most of it's time.
2006 Sport Edition, V8, 181K miles, 2.5/1.5 Daystar spacer lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 221K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 09-11-2019, 12:30 PM #6
MT Runner's Avatar
MT Runner's Avatar
A little off subject, but what RPod do you have? We just sold our old camper this spring and got a 176T this summer. Only got to use it a few times, but really like it so far.
2005 SR5 V6
AFE Intake
Old 09-11-2019, 12:47 PM #7
Real Name: Ron
Real Name: Ron
We have a 179. Just got it last spring, and we like it a lot. We call it our "Happy houR Pod".
Old 09-11-2019, 01:40 PM #8
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss is on a distinguished road
MY GARAGE
rdruss's Avatar
Real Name: Ron
MY GARAGE
I would guess your coolant temp went up because trans temp went up when downshifted to 3rd and operated there for awhile. If trans is cooled by engine coolant, then for sure, if not and air-to-oil cooler, then is cooler in radiator air stream? If so, then the extra heat rejected from it into the rad airstream could be the cause.
Old 09-11-2019, 03:15 PM #9
I'm talking about engine coolant here, not transmission fluid temp.
The trans temp went up as well but nothing that I thought was dangerous.
I had been running in 4th gear the whole trip, if I'm on level ground with the camper I can run in 5th gear, but any kind of hills I loose too much speed so I usually always put it in 4th when towing the camper.
I'll check for bugs, other obstructions etc. I've heard the fan clutch engage when stopped for a while in hot weather, but I didn't hear it engage this time, but I would think it would be hard to hear at 60mph, but maybe not? Maybe replacing the fan clutch as a precaution would be a good idea.
Old 09-11-2019, 05:44 PM #10
nevada's Avatar
nevada's Avatar
the fan in my 06 isn't nearly as easy to hear as in my 85.
however... that might be because it has never came on lol. I can for sure hear it even at 60. and with a worn engine pushing 37's, its working HARD. lol
Old 09-12-2019, 08:04 AM #11
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 is on a distinguished road
MY GARAGE
Real Name: Newell
MY GARAGE
You should be fine. Most coolants don't start to boil until around +250.
UrbanRunner651 is offline   Reply With QuoteReply With Quote
coolant , point , temp , temps , towing
coolant temp sensor SAYWHAT 3rd gen T4Rs 31 08-30-2018 07:44 PM
Coolant Temp Switch on the 3.0 Adumb Classic T4Rs 0 11-10-2016 01:35 AM
Water/coolant temp T4R-DDOGG 3rd gen T4Rs 20 09-05-2015 07:19 PM
Coolant temp - the answer? PoshSnoop 3rd gen T4Rs 3 06-07-2015 02:02 AM
How do I change coolant temp sensor on 3.0 markfagus Classic T4Rs 1 05-29-2011 12:21 AM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
