Old 09-11-2019, 08:59 PM #1
Styner89's Avatar
Styner89 Styner89 is offline
Styner89 is on a distinguished road
Styner89's Avatar
Alignment question
I just instaled the eibach pro lift and got my 2004 v8 4x4 4runner aligned and the attached picture is what the results are. I am going to take it back to them because it now has a bad shake in the steering wheel over 60 mph and starts to pull right. I am not sure what the SAI, Cross SAI and Included angle are and why they are in the red. Anyone have any ideas what these are and if I need to do anything to get them fixed?
I have stock upper control arms if it matters. I only got about 2.25" of lift in the front and 1" in he rear after it settled.
Styner89 is offline   Reply With QuoteReply With Quote
Old 09-11-2019, 11:09 PM #2
having fun's Avatar
having fun having fun is offline
Real Name: Leonard
having fun will become famous soon enough having fun will become famous soon enough
having fun's Avatar
Real Name: Leonard
Not sure what they can do for the shakes, but, camber, caster and toe are the main things to get green.
And with stock arms and that much lift, think they did you pretty good.
Having fun's build
having fun is offline   Reply With QuoteReply With Quote
Old 09-12-2019, 09:22 AM #3
Styner89's Avatar
Styner89's Avatar
From what I have found on google there might be something bent in the suspension but that might not be correct. It is just weird that when I took it to them there was not shake all the way up to 75mph but not anything over 60mph I have a shake.
Old 09-12-2019, 12:37 PM #4
blackoutt's Avatar
blackoutt blackoutt is offline
blackoutt has a spectacular aura about blackoutt has a spectacular aura about
blackoutt's Avatar
Alignment looks decent for the part installed. I would make sure that the LCA bolts are torqued to spec (or a little over) It might also be possible that the bushings are worn out and an alignment tore them through. It's quite common to have to replaced LCA bushings and CV boots shortly after lifting it.
blackoutt is offline   Reply With QuoteReply With Quote
Old 09-12-2019, 04:34 PM #5
Styner89's Avatar
Styner89's Avatar
Thanks for the information. I am having the wheels balanced in the morning and taking the 4runner back to the alignment shop Saturday morning to have them do a once over and see if there is anything they can do to fix it from pulling to the right.
I was mainly working that the SAI and Cross SAI would cause problems like tire wear or something. Not sure what would cause those to be out of speck so much on one side and the over all front.
Old 09-12-2019, 06:53 PM #6
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough
phatcheeks's Avatar
Sorry cant help with your alignment. Number look good though.
You got any pics of your lift? I have been considering this lift but cant find that many decent pics.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
phatcheeks is offline   Reply With QuoteReply With Quote
Old 09-13-2019, 09:08 AM #7
Styner89's Avatar
Styner89's Avatar
No problem. I ended up with 2.25" lift in front and 1" in the rear after it settled. I am running 265/65/17 Cooper HTP tires currently. Planning on maybe falken at3w in 265/70/17 maybe another brand haven't completely decided yet but probably won't go any larger than 275.
Before the lift
After the lift
angle , ideas , lift , red , sai
Alignment question... FattyHunter 5th gen T4Rs 25 06-24-2018 10:49 PM
Another 5th Gen alignment question Gunny69 5th gen T4Rs 2 08-12-2014 10:14 PM
Another Alignment question Gunny69 5th gen T4Rs 5 05-02-2014 11:38 PM
Alignment question rocket67 5th gen T4Rs 9 08-02-2012 03:40 PM
4th gen alignment question nyc4runnin 4th Gen T4Rs 10 10-04-2010 06:55 AM
