09-12-2019, 05:37 AM
DAC button no where to be found
Well I finally went out and bought a 4Runner like I’ve always wanted. 1 winter in West Michigan made me want to sell my BMW immediately. Wife and I are planning to do some fun camping trips in this thing and I’m very happy to have a mostly rust free example. I have a 2006 Sport Edition V8, 4wd of course
As I’ve looked the truck over, for the life of me I cannot find the DAC button. Above the drivers left knee I have 4 buttons, only one of which has a function (center diff “lock”). On the center console I have 3 blank buttons. I’ve done reading on all manner of forums and articles. To my knowledge, it seems that everyone’s impression is that DAC came standard for all 4wd 4runners. However, I can’t find mine anywhere. Am I incorrect in thinking DAC was standard on 4wds? If it isn’t, have you heard of anyone retro fitting it?
Thanks for helping a newbie,
Andy
09-12-2019, 07:38 AM
Real Name: Elliott
Real Name: Elliott
Andy
DAC should be on the center console, the cluster of three between driver and passenger, should be right there. If not, it was blanked out for some reason.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
09-12-2019, 09:12 AM
Real Name: John
Real Name: John
Are you sure its 4wd? I had a friend that this happened to, bought what he thought and was told was a AWD car and it ended up being a FWD model that had had the tailgate replaced with a matching one from a AWD.
Just something to look at, otherwise I'd pop out the console and see if the switch wiring is there and try buying/installing a switch. As mentioned it might have been blanked out for some reason (previous owner by accident hit it too much?)
2004 4Runner V8 Limited - TRD Exhaust, LED Interior Swap, Pioneer HU, Tacoma TRD Front Suspension, FJ Rear Springs, 10" + 32" Light Bars, Prius Shift Knob, 275/65R18 Falken Wildpeak, 18x9 Level 8 MK6 Et0, GOBI Ladder, 06-09 Headlight Swap, TOTALED NOV 2019, RESURRECTED APR 2020 Build Thread
1998 Volvo S70 T5 - Custom Airlift Suspension, BBS Nebula Wheels, Brada Seats, Engine Bolt Ons - StanceWorks Build Thread
2010 Subaru Forester 2.5X - Wifes Car
09-12-2019, 09:19 AM
Real Name: Jeremy
Real Name: Jeremy
OP states he has a center locking diff button, so I'd say it's 4WD.
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
09-12-2019, 09:57 AM
I don't use DAC at all, removed the button actually.
I just put it in 4-low and manually shift to the 1st gear. Barely have to apply the brakes going down hill.
09-12-2019, 10:02 AM
Real Name: John
Real Name: John
Good point, just something to think about since I've seen it happen, it would haunt me if it happened to me, but crazier things have been seen haha
09-12-2019, 10:04 AM
A Front Wheel Drive 4Runner? That's a first for me! LOL!
09-12-2019, 10:14 AM
Well, he did say AWD car, not 4Runner, so.....
09-12-2019, 10:29 AM
Well ... I have a 2006 Sport Edition V8, 4wd of course
... Am I incorrect in thinking DAC was standard on 4wds? ...
You are correct. DAC is standard on all 4wd models.
Please confirm that you definitely have a 4wd model. You said there's a CDL button to the left of the steering wheel, but do you have the high/low range selector knob to the right of the steering wheel?
One other thing, I remember another person on this forum a few years ago saying they had a 4Runner that was missing lots of standard features too. It turned out that some dealership somewhere brought in a batch of 'bare bones' vehicles for some reason.
DAC actually does a pretty good job in my experience, but I probably only use it once a year. It also sounds like a miniature gun fight is going on behind the dash when it's doing it's thing, haha.
09-12-2019, 10:40 AM
Real Name: Elliott
Real Name: Elliott
Ditto! Couldn't stand it bumping into the button, so I unplugged it and filled the space with something more useful. I've been wheeling longer than I've had a license, so 4-lo 1st gear is all the DAC I will ever need
09-12-2019, 11:25 AM
Real Name: John
Real Name: John
haha, in this case it was a mid 2000's Volvo S40 Manual. The manual AWD ones were really hard to come by, so when he found one he snatched it up... turns out it was a Manual FWD, which were fairly common.
No FWD 4Runner here!
09-12-2019, 11:26 AM
Real Name: Michael
Real Name: Michael
Andy
Mine is currently just floating around under my center console where it used to reside. In its place is a USB to USB and USB to Power plug. If I want to reinstall it all I would do is pop out another blank and put it there, but I always bump into it and never use it so that's why I stowed it under the area it used to be. Could be possible that the previous owner did the same thing. Pop up the center console area where these switches are and take a look. Might just be hanging out under there
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
09-12-2019, 01:26 PM
I’ll check into popping out the blank and see if the wiring is there- wife has it today. Funny how she’s driven it more than I have in the last week.
I figured if it’s not there then I’ll get by with 1st gear low range. It’s what I’ve always used.
And it’s definitely 4wd. It’s in all time 4wd with low range twist knob next to right knee.
Thanks for the fast responses everybody.
09-13-2019, 02:41 PM
Removed the console today and I see that they probably unplugged and blanked out the dac. However, I see a 6 prong white and a two prong white plug, unsure what they go to. Any ideas?
I know the blue connection goes into the dac given the research I did. But unsure about other two.
09-13-2019, 03:50 PM
pretty sure thats the cigarette lighter wiring for the smokers kit.
