Old 09-13-2019, 03:34 PM #1
yao995 yao995 is offline
yao995 is on a distinguished road
Lightbulb Help needed on 06 4Runner V6 176k with oil residue around the intake manifold
Hi, 4th gen friends.
I need some help to identify what is the issue of my car. I was cleaning my throttle body and noticed there was some oil residue around the intake manifold. I was thinking is it possible the intake manifold gasket? I did some research on our forum, but find nothing related. Have any of you guys seen this before? any thoughts? Car's idle is fine and I think there is no air leaking inside. Thanks in advance!
Help needed on 06 4Runner V6 176k with oil residue around the intake manifold-img_20190910_144734-jpg
yao995 is offline   Reply With QuoteReply With Quote
Old 09-14-2019, 11:34 AM #2
Any thoughts?
Old 09-14-2019, 04:26 PM #3
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Any thoughts?
Wait a while longer for more responses, it's the weekend and most are out doing weekend stuff and not on the forum.
I would think it would be more a valve cover gasket issue instead of the intake gasket because there really no oil to speak of in the intake or running through it, it could possibly also be a leak in the PCV hose, the PCV is for relieving any pressure/piston blowby from the crankcase via the oil galleys in the head, sometimes there will also be some oil vapor mixed in with the combustion gases/blowby and as it gets removed by excess pressure and also by a bit of suction from the intake, it goes via the hose to the intake to be returned to the cylinders to go through the combustion process again, if that hose is cracked it will/can drip oil residue onto the intake.
2004 Limited V8
Old 09-14-2019, 05:09 PM #4
f250ben f250ben is offline
f250ben is on a distinguished road
That gunk is old. No way to really know where it’s coming from because it’s all over the place. For all you know oil was spilled as it was being poured during an oil change and that’s all it is.
Use some degreaser and completely clean off that area. Then check it a few days later. If you have an actual small gasket leak or some other type of leak then it will start showing up right around the source.
f250ben is offline   Reply With QuoteReply With Quote
Old 09-14-2019, 09:01 PM #5
Thanks for your reply, this is my first post in our forum, I was thinking maybe no one has seen this post yet... Now I know, thanks!
I checked my valve cover gaskets while I was cleaning the throttle body, looks like it is dry on both side. But since I have owned this car for less than a year, it could be some previous oil residue. As long as it is not some common issue on 4th gen runner, it will be cool. I cleaned the PCV valve as well. ( I think the PCV hose only route on the drive side from the PCV valve to a black nozzle on the valve cover, am I right?)
I wonder, is it practical to add oil catch can on our runner? Any write up according to your knowledge. Thanks in advance!
Old 09-14-2019, 09:02 PM #6
Thanks for your reply, I think it is a good idea, but I forgot to clean them.. LOL, looks like I just find something to do tomorrow...
Old 11-21-2020, 07:42 PM #7
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
I just noticed the same thing on my ‘07. Did you find the cause of the oil build up?
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 11-21-2020, 08:00 PM #8
montijo505's Avatar
montijo505's Avatar
Most likely valve cover gaskets. They're inexpensive and easy to replace. Buy from McGeorge Toyota.
Sent from my SM-G986U using Tapatalk
Old 11-21-2020, 08:38 PM #9
Drcoffee's Avatar
Drcoffee's Avatar
Valve cover gasket are dry. Its coming from the valley somewhere
Here is what I found today when I removed the plastic intake plenum. Lots of oil outside of the gasket area. I assume this has been leaking and building up on the lower intake. Time will tell.
Help needed on 06 4Runner V6 176k with oil residue around the intake manifold-6cfbb3c2-c5a4-4a68-9933-8a7f6df32ff9-jpg
find , intake , manifold , oil , residue
Coolant hose under the intake manifold leak - 2004 4RUNNER V6 PTPT2002 4th Gen T4Rs 2 04-10-2021 08:16 AM
Coolant residue on intake manifold mike_m 3rd gen T4Rs 33 05-05-2020 06:21 PM
Will a 05 tundra intake manifold fit a 03 V8 4runner? bassmacka 4th Gen T4Rs 4 05-15-2018 10:28 AM
FS/FT intake manifold off 2000 4runner NNJ $40 habskater11 For Sale: T4R Items 3 04-12-2016 05:09 PM
FS: 3rd Gen Upper Intake Manifold Plenum & Lower Intake Runners - Cen TX; Will Ship SURF RUNNER For Sale: T4R Items 19 01-10-2016 12:22 AM
