Old 11-20-2020, 10:52 AM #1
RD9146 RD9146 is offline
RD9146 is on a distinguished road
testing used transfer case
Is there anyway to test a used transfer case prior to installing to make sure the accuater is working properly? Thanks in advance. Rick
RD9146 is offline   Reply With QuoteReply With Quote
Old 11-20-2020, 02:44 PM #2
pauldub pauldub is offline
pauldub will become famous soon enough
If the wires are long enough, you could put it under the car and plug the wiring into it and select H4 and L4. If the dash lights behave properly, you're probably good. You could also apply voltage to the appropriate connector pins on the actuator and monitor the limit switches. It's a bit fussy to get the actuator to stop in the right place but it's possible. I did this when I jazzed mine with 30 volts to get the motor in the actuator unstuck.
pauldub is offline   Reply With QuoteReply With Quote
Old 11-20-2020, 04:44 PM #3
Thanks man. Rick
Old 11-20-2020, 05:35 PM #4
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Is it possible to remove the actuator and apply the voltage to it, and see if it moves?
I don't really know how it works exactly whether its a shaft or arm but that would test the actuator itself. If it's easy to remove that is.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 11-21-2020, 11:18 AM #5
I thought it had to be timed if it was removed??
advance , case , properly , testing , transfer
v8 transfer case swap to 6cyl transfer case? V8RUNN 4th Gen T4Rs 23 09-11-2020 01:40 AM
FS 3rd Gen '01-'02 Transfer Case Actuator $50 + Transfer Part Out, Idaho Falls, ID BanditJunior For Sale: T4R Items 1 05-01-2019 01:57 PM
RCI Transfer Case Skid doesn't have Transfer Case Drain Hole boyfester RCI Metalworks 1 01-09-2018 08:35 PM
WTB: 4th gen V6 transfer case shift motor/transfer case drewskie88 Want to Buy/Trade 0 01-11-2016 12:41 PM
Advance Adapters 50-5705 Transfer Case Adapter 700R-4 To A Toyota Transfer Case 21 To NMRunner Classifieds - buy & sell (no commercial ads please) 0 08-18-2010 11:42 PM
