Old 09-13-2019, 09:45 PM #1
Diocletian Diocletian is offline
Diocletian is on a distinguished road
Odd dome fuse shorting issue
So I've begun doing some quick and easy mods on my new to me 06 4Runner SR5. I did the HCF delete, combined with a K&N drop in filter, then did replacement bulbs for my license plate housings. All was going good and I moved on to the interior.
I started with the map lights, finished the right bulb with no problem and it tested fine. I then went to replace the left side and thats when I noticed all my interior lights went dark. I thought maybe it was because the car cut power to them(my mustang does that after a while).
I checked the light I just replaced and now it wouldnt turn on. I check the dome amp in the engine bay and noticed it was blown. So I replaced it, which fixed all the lights EXCEPT the left map light. I tried to flip the polarity of the light, thinking it caused the short and boom, blew another fuse.
Replaced it AGAIN and still the left map light won't work. Keep it mind it was working with the regular bulb.
Im at a loss, I'm out of fuses too so I will get some more but I'm confused as to why that particular light is causing the issue. Ill try with another LED light tomorrow but anybody got any ideas?
Diocletian is offline   Reply With QuoteReply With Quote
Old 09-13-2019, 10:24 PM #2
Real Name: Skip
Real Name: Skip
I haven't clue as to why it's blowing the fuse..BUT...I would try the regular bulb to see if it does the same or no issue before trying another LED, it could be just the one LED causing the issue or a direct short, so try the regular bulb and see what happens.
2004 Limited V8
Old 09-14-2019, 06:55 AM #3
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
please check this thread out
(Intermittent) Dome Fuse Blowing
i posted a pdf of short to ground, use that as a reference for checking blown fuse.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 09-14-2019, 07:56 AM #4
A lot of good info in there but I dont have a Voltmeter, guess I could buy one. Wonder why LED lights would cause this issue? I'll check the left map light contacts first, thats where I believe I isolated the short
Old 09-14-2019, 10:36 AM #5
Solved it! It was in fact a faulty LED bulb causing the short! Replaced the bulb, no more blowing fuses, replaced all interior lights except the dome lights as I didnt get the right bulb for them...oops
Old 09-16-2019, 07:16 PM #6
ZBarren1 ZBarren1 is offline
ZBarren1 is on a distinguished road
I had the exact same thing last month. Still cruising around with one yellow dome light.
ZBarren1 is offline   Reply With QuoteReply With Quote
left , light , lights , map , replaced
15 amp Dome fuse keeps frying! trail_runner 3rd gen T4Rs 44 01-09-2024 05:44 PM
Blowing Dome Fuse 10 amp dandees1 4th Gen T4Rs 12 03-11-2022 07:53 PM
Dome Light Fuse issue TurtleAdventure 3rd gen T4Rs 12 05-30-2021 12:05 PM
I keep blowing my 15A dome fuse. Help Lanqe 3rd gen T4Rs 25 07-01-2020 12:22 AM
Wiring Harness Shorting Issue. Howitzer Classic T4Rs 32 12-01-2018 09:16 PM
