Old 09-14-2019, 03:52 AM #1
gookies gookies is offline
gookies is on a distinguished road
Replacing Rear Driveshaft?
Has anyone here replaced their rear driveshaft with the updated one from the LX470 (corrected: GX470)? If so, mind going through the steps you did? One important thing I've read is lining it back up properly so it's balanced, but that seems to be done when replacing u-joints on an old driveshaft, how do you line it up if it's a new one? I may need to replace mine because the rear seal that keeps the grease in popped out awhile back and I don't think Toyota sells that separately.
gookies is offline   Reply With QuoteReply With Quote
Old 09-14-2019, 08:34 AM #2
Toyojay Toyojay is offline
Registered User
Real Name: Jay
Toyojay will become famous soon enough
Registered User
Real Name: Jay
Do you mean the GX470? The LX should be longer since its based off the land crusier. What changed about the Lexus shaft?
Toyojay is offline   Reply With QuoteReply With Quote
Old 09-14-2019, 11:20 AM #3
NinjaOne's Avatar
NinjaOne NinjaOne is offline
NinjaOne will become famous soon enough
NinjaOne's Avatar
Yes, I have. Didn't do anything special to install; unbolted old one and bolted on new one. Don't forget to use blue locktite
Haven't had any noticeable balance issues
<a href=https://www.instagram.com/t4r_juan/ target=_blank>t4r_juan</a>
NinjaOne is offline   Reply With QuoteReply With Quote
Old 09-14-2019, 02:53 PM #4
Yes, you're correct, it's the GX470. I am not sure what improvements were made, but there was a TSB a long time ago and some members ended up with that driveshaft on their 4Runner due to the complaints about clunking (T-SB-0121-12)
Thank you, it's really that simple? Just unbolt the driveshaft and replace?
Old 09-16-2019, 11:52 PM #5
I ended up buying a Cardone re-manufactured driveshaft instead of OEM, which is around $300-400. This was only $106 on eBay, it's $169 on RockAuto. I'd suggest others to buy this since it's pretty inexpensive if they still have clunking after re-greasing, then you can just take the old driveshaft apart and lube it up properly to have as a back-up.
Drive Shaft-Driveshaft / Prop Shaft Rear Cardone 65-5017 Reman 884548270411 | eBay
back , driveshaft , rear , replacing , sells
Replacing driveshaft zerks? Montego Murph 4th Gen T4Rs 8 07-08-2019 06:21 PM
Marking driveshaft flanges when replacing entire rear axle? Southernbike 3rd gen T4Rs 5 01-22-2017 09:19 PM
Question about replacing rear driveshaft u-joints ki1022 3rd gen T4Rs 20 12-05-2015 01:05 PM
Replacing Driveshaft? JenniJ Maintenance/Detailing 2 08-28-2013 08:15 PM
