01-09-2019, 02:06 AM
Real Name: Matt
Real Name: Matt
Clicking and popping sound, loud when stationary????
I've tried to source this clicking and popping sound coming from my 4runner for a few weeks now. I can't seem to find out where it is coming from and it only happens when I'm stationary. This happens when I turn the steering wheel fully to the left to full right, and then back again, full right to left, then full right. And the other way around. When driving, I can here the same click/pop sound when doing u turns or backing out of a parking spot.
Something makes a very loud pop/click sound. Originally, I thought it was my tie rods, since I recently replaced those, but they aren't loose. Then I checked my suspension for loose bolts. Uca, lca, lbj and strut assemblies are all tight. I don't think it's a word CV simply because it's not a constant click/pop sound. It just clicks/pops once.
Anyone else have this issue? Or know what else to look into?
01-09-2019, 04:34 AM
Real Name: Clay
Real Name: Clay
So, it happens all the time but it’s louder when you’re not moving, but while you turn your steering wheel stop to stop?
Have you jacked the front of the vehicle and checked everything under no load? 4wd not engaged? Sorry if I’m making you repeat yourself.
Reason: Clarification
01-09-2019, 10:21 AM
have you greased the steering stops? Nasty sound on right turn
01-09-2019, 11:37 AM
Real Name: Matt
Real Name: Matt
That's correct. I believe the noises come when there's strain on the steering system, as it doesn't happen while moving unless I make a uturn or sharp turn.
IIRC, when I lifted the car up it didn't make any noise, but I will check to confirm.
01-09-2019, 11:38 AM
Real Name: Matt
Real Name: Matt
Originally Posted by chaz
No I have not. I'll give this a shot.
01-09-2019, 08:40 PM
Real Name: Clay
Real Name: Clay
I’d lift the front and check for play in your bearings to rule that out. It kinda sounds like bearings but you should be able to feel rumbling while you’re driving. If it’s popping that loud..
01-09-2019, 09:54 PM
Real Name: Matt
Real Name: Matt
Definitely not wheel bearing. If my bearing was that bad... That'd be terrifying to drive on. Lol
01-10-2019, 12:50 AM
Real Name: Elliott
Real Name: Elliott
Sounds like something is loose. Check everything suspension related, alignment cams, ball joints, front diff mounts if you are dropped. Could be anything
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
01-10-2019, 06:16 PM
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
01-10-2019, 10:19 PM
Check your upper and lower control arm bushings,they will make a creaking noise if worn.
01-14-2019, 12:39 PM
Real Name: Matt
Real Name: Matt
This was what I was thinking originally, but everything is tight. So I'm scratching my head trying to figure out d the source of the noise haha
01-14-2019, 12:40 PM
Real Name: Matt
Real Name: Matt
Originally Posted by Bossman
No it's not that. I did have that issue though, but the crack/popping sound is significantly louder than the steering column click
01-14-2019, 12:42 PM
Real Name: Matt
Real Name: Matt
When I checked the bushings we're quite good. Obviously they're loose because of age, but they held in place when I used a pry bar to see if they'd click or make metal to metal contact.
01-14-2019, 12:44 PM
Might try unbolting the tie rods and turning back and forth again, to see if it is isolated to the steering column or steering rack.
01-14-2019, 01:06 PM
Real Name: Matt
Real Name: Matt
I'll give this a shot, but when I lifted up the truck and had no load on the front wheels, they don't make any creak/pop sounds. It seems to only happen when the load is high. Like when stationary, or making a uturn, or rolling out of a parking spot. While driving at normal street speeds(25mph+), switching lanes or turning into a street, there aren't any of the mentioned sounds.
