Old 09-18-2019, 11:17 AM #1
cannuck21 cannuck21 is offline
cannuck21 is on a distinguished road
Bilsteins Shocks - Replacement for X Reas
Replaced my x reas suspension late last year as the rear had started to leak and the cost of replacement was expensive. The Bilstein's have proved to me at least - excellent. Sure the ride is more firm but I like it. Took my 2003 V8 Ltd up to Alaska and then into the Yukon and back to BC in late May this year. Not a single problem - apart from a broken windshield picked up on the Dempster Highway. Tried to get to Tuc but the two ferries opened then closed due to ice flows. Will try again next year.
It is still a magnificent truck. 240, 000 km on the clock and I'll run it until the wheels fall off - then buy a new set.
Best truck that I have ever owned by far.
Yep Bilsteins had been a very good investment
cannuck21 is offline   Reply With QuoteReply With Quote
Old 09-18-2019, 01:56 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Yep, I have an '03 V8 Ltd. and replaced xreas with 4600 Bils and FJ springs couple years ago. Very satisfied, but would opt for the Eibach shocks if doing over.
Old 09-18-2019, 02:07 PM #3
rwelch53 rwelch53 is offline
Real Name: Ryan
rwelch53 is on a distinguished road
Real Name: Ryan
I have been torn between the Eibach Pro springs and shocks and the 5100's with Toytec springs...can I ask is there any particular reason you lean towards the Eibachs now?
rwelch53 is offline   Reply With QuoteReply With Quote
Old 09-18-2019, 09:44 PM #4
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Just from what I read on here about the Eibach's and their better feel on road, I'm strictly on road so a little more compliance over sharp bumps and RR tracks would be welcome.
Old 09-19-2019, 12:26 PM #5
Styner89's Avatar
Styner89 Styner89 is offline
Styner89 is on a distinguished road
Styner89's Avatar
I swapped out my xreas with 102,000 miles on my 04 v8 4x4 last week with the eibach pro lift and have no complaints so far. After settling I ended up with 2.25" lift in front and 1" in the rear. I am swaping to wildpeadk at3w today.
Styner89 is offline   Reply With QuoteReply With Quote
Old 09-21-2019, 10:35 AM #6
grave's Avatar
grave grave is offline
grave has a spectacular aura about grave has a spectacular aura about
grave's Avatar
Another +1 for Eibach. They’re basically copies of 5100s made of better quality material right here in Southern California.
pet every dog
grave is offline   Reply With QuoteReply With Quote
Old 09-21-2019, 09:08 PM #7
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Went to Eibach's site just to check out their gear and found they have some 4th Gen front shocks on closeout for $63 shipped.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 09-21-2019, 10:48 PM #8
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
From what Ryan explained, they have a couple strategically located bleed holes so that the digressive valving does not beat you up at slow shaft speeds.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
Old 09-25-2019, 01:09 PM #9
shootersanks shootersanks is offline
shootersanks is on a distinguished road
Eibach also has shocks for the 05-15 Tacoma on sale as well Front ($63) and Rear ($49)
I'm not sure what the difference is between the 4Runner and tacoma shocks are but for ~$225 you can have all 4 corners replaced.
Shootersanks
-2007 Shadow Mica SE 4Runner
shootersanks is offline   Reply With QuoteReply With Quote
Old 09-25-2019, 01:46 PM #10
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough
phatcheeks's Avatar
Those are just the Pro Truck shocks. Meant for stock suspension no lift. You will probably want to get the Pro Truck Sport shocks. Those are meant for lift. They are like the 5100s but supposedly better. I have these with the OME springs waiting to be installed
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
phatcheeks is offline   Reply With QuoteReply With Quote
Old 09-25-2019, 05:55 PM #11
Bluesky 07's Avatar
Bluesky 07's Avatar
Thanks, I’m not in the market for shocks, just posted that as a PSA for anyone needing some.
Old 09-26-2019, 01:47 AM #12
pahaf91 pahaf91 is offline
pahaf91 is on a distinguished road
I recently got rid of my xreas and installed 5100's and the 885-895 springs on my 2006 v6 4Runner.
on the road, they are amazing, i was going thru some twisties today and it felt a little like a sports car. didn't lean as much and hugged the corners. But a complaint that i have is that they are pretty dang stiff when going off roading at slow speeds.
I will have my tires aired down to 15psi over some fire trails and its still pretty bumpy. Not sure if thats my shocks or the springs since i heard the OME are pretty stiff.
pahaf91 is offline   Reply With QuoteReply With Quote
bilsteins , late , replacement , truck , year
Bilsteins Shocks - Replacement for X Reas cannuck21 4th Gen T4Rs 0 09-18-2019 11:16 AM
Shocks/Stuts replacement on my T4R and X-REAS?? nikilicious 4th Gen T4Rs 4 04-22-2015 11:42 PM
FS: 4th Gen X-REAS shocks adamf For Sale: Suspension/Wheels/Tires 1 05-02-2013 09:19 PM
WTB: 07-09 4x4 FJ Coils/Shocks (Bilsteins) BPo001 Want to Buy/Trade 0 03-20-2013 03:02 PM
WTB: Rear shocks for 3rd gen OME or Bilsteins baja bound Want to Buy/Trade 0 09-07-2011 12:46 AM
