Old 09-18-2019, 05:20 PM #1
GLP's Avatar
GLP GLP is offline
GLP is on a distinguished road
GLP GLP is offline
GLP's Avatar
Transfer Case Output Shaft Seal
I noticed last weekend gear oil leaking from my T/C front output shaft. I'm sure it's the output shaft seal, I know it's not the dreaded actuator seal, I replaced that before. Anyway, when searching for the OEM seal there are 2 different seals listed for my model (2004 V8 Limited). Even when I try to search by my vin# it still gives me 2 different seals.
Does anyone know how to figure out which one is the right seal for model? Got pics of the 2 seals online and they are very different looking.
Transfer Case Output Shaft Seal-output_shaft_seal-jpg  Transfer Case Output Shaft Seal-90311-41012-jpg  Transfer Case Output Shaft Seal-90311-41013-jpg
-2004 4Runner 4WD Limited V8, Bilstein 5100s, Wheeler's T12 Rear Springs, GY Silent Armor 265/70-17
GLP is offline   Reply With QuoteReply With Quote
Old 09-19-2019, 04:40 PM #2
Crikeymike
Guest
Posts: n/a
Crikeymike
Guest
Posts: n/a
Looks like it has some date codes with those part numbers - to me anyway.
First looks like 200609 (09 of 2006) to 200807 (07 of 2008), then the other is 200807 on.
Maybe there's another drawing for the earlier 2004 that you have.
Or perhaps I'm reading that totally wrong, and there's an inner and outer seal. The OE part numbers are only 1 digit off from each other.
Old 11-06-2019, 04:46 PM #3
Elan750's Avatar
Elan750 Elan750 is offline
Elan750 will become famous soon enough
Elan750's Avatar
Did you ever find out anything more on this? I'm in the same boat.
I think the 200609 - 200807 could also be a VIN range. however my vin has 20x630 so maybe not... Im m in a gx470 so maybe thats why theres an x...
or its simply a typo in the parts dept...
either way I want to be sure i Have the right seal before I start taking things apart.....
2005 4Runner Sport 4wd v6 -totaled!
2003 Lexus GX470
Elan750 is offline   Reply With QuoteReply With Quote
Old 01-05-2020, 04:18 PM #4
Billynath1988's Avatar
Billynath1988 Billynath1988 is offline
Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about
Anyone know which of these goes on the back of the transfer case?
Transfer Case Output Shaft Seal-80072307_614109632462101_4045633956157063168_n-jpg  Transfer Case Output Shaft Seal-1-jpg
2005 4Runner SE V8
http://www.toyota-4runner.org/4th-ge...-v8-build.html
Billynath1988 is offline   Reply With QuoteReply With Quote
Old 01-10-2020, 11:16 AM #5
Anybody know exactly which part number is used for the rear facing output shaft seal of the transfer case?
2005 4Runner SE V8
Old 01-10-2020, 11:50 AM #6
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Based off your pics and from doing some research, I would say you need part # 9031141012.
Edit - Actually, I take that back.
Part # 9031141012 would be for what I view as the front output shaft seal, for the front driveshaft. Your pic is of the rear output shaft, for the rear driveshaft, with the actuator motor next to it. For that side, you need 90311-41007, which Toyota says in no longer available but I do see them on Amazon and other places.
xtremewlr is offline   Reply With QuoteReply With Quote
Old 01-11-2020, 09:41 PM #7
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Just buy them both, they're cheap. Return the one you don't use.
Old 01-13-2020, 09:56 AM #8
LOL thats exactly whats going to happen.
2005 4Runner SE V8
model , output , seal , seals , shaft
Gen 1 Transfer Case Output Shaft Leak MBZ300CD Classic T4Rs 7 01-25-2020 06:36 PM
Output shaft seal on transfer case GX4SEVEND 5th gen T4Rs 2 09-14-2019 08:40 PM
Transfer Case Output Shaft Seal Replacement mtbtim 3rd gen T4Rs 12 06-22-2019 10:14 AM
Transfer Case Output Shaft Leak rwh963 4th Gen T4Rs 4 11-09-2018 11:37 PM
Transfer Case Leak -- Output Shaft Seal Merle Maintenance/Detailing 3 04-17-2017 12:32 PM
