Originally Posted by Billynath1988
Anybody know exactly which part number is used for the rear facing output shaft seal of the transfer case?
Based off your pics and from doing some research, I would say you need part # 9031141012.
Edit - Actually, I take that back.
Part # 9031141012 would be for what I view as the front output shaft seal, for the front driveshaft. Your pic is of the rear output shaft, for the rear driveshaft, with the actuator motor next to it. For that side, you need 90311-41007, which Toyota says in no longer available but I do see them on Amazon and other places.
