02-11-2020, 03:54 PM
#16
Real Name: Danny
Real Name: Danny
Originally Posted by Crikeymike
Just need the right kind of tool. Snap ring pliers usually go in both directions and would get it done.
2 screw drivers, go against both open ends at the same time and try to get it out that way. It's super easy to slip and bust a knuckle, but it can be done.
I'd have found someone with a 5th Gen that was replacing their UCA's. Most of them don't end up reselling the stock ones, and they should bolt into a 4th gen no problem.
I'm 99% positive that the 5th gen UCA will not work on a 4th gen. I found out the hard way when I picked up some 2nd gen Tacoma spindles (gussted) that the ball joint hole at the top of the spindle is different between Tacomas and 4th gens. The 5th gen also has a different part number from the Tacoma or 4th gen 4runner. I ended up buying a set of TC UCAs from a Tacoma buddy because he was changing out to DK.
02-11-2020, 04:13 PM
#17
Now you're really mixing things up. Tacoma and 4runner UCA's are NOT interchangeable.
One uses a tapered ball joint end and the other does not
Everyone running Dobinsons UCA's on 4th and 5th gen 4RUNNERS are using the same arms and ball joints
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
02-11-2020, 04:30 PM
#18
Real Name: 03 v8 Limited
Fyi
4th gen runners
2nd gen tacos
And some fJ's
ALL HAVE THE SAME FRONT END
PERIOD
Sent from my SM-G950U using Tapatalk
02-11-2020, 04:54 PM
#19
Real Name: Danny
Real Name: Danny
Which I'm aware of, since I'm now running Tacoma spindles AND UCAs ;)
02-11-2020, 04:58 PM
#20
Real Name: Danny
Real Name: Danny
Originally Posted by Brutalguyracing
Fyi
4th gen runners
2nd gen tacos
And some fJ's
PERIOD
Wrong. I took some measurements of the UCA Ball Joints and spindle holes from both a 4th gen 4runner and a 2nd gen Tacoma. You cannot mis match UCAs and spindles.
4th gen 4runner vs 2nd gen Tacoma spindles | IFS OFFROAD
02-11-2020, 07:58 PM
#21
If you have no first hand knowledge then you should stop posting disinformation
02-11-2020, 08:35 PM
#22
Real Name: Danny
Real Name: Danny
Pretty sure I just posted first hand knowledge. Should take a look at the link chief. Not only did I literally take measurements myself, you physically cannot force a 4th gen ball joint into a 2nd gen Tacoma spindle. I ****ing tried. It doesn't work. I also tried to stuff a 2nd gen ball joint into a 4th gen spindle. I own both vehicles so I had parts to test. If that isn't first hand knowledge, well, I don't know what to tell you.
Sent from my Pixel 2 using Tapatalk
02-11-2020, 10:17 PM
#23
Real Name: Craig! Craig Christ!!
Originally Posted by XR250rdr
Don't buy those! Those moog ball joints are absolute garbage. I bought a set for my wife's car and I couldn't believe how chincy they were. And I've seen videos of guys installing them on their 3rd gens. And completely failing after I just a few months. I seen a video of a guy who put them on and within two months. It's snapped and his whole tire folded under.
02-11-2020, 10:37 PM
#24
Real Name: Derek
Real Name: Derek
Seems like your the one mixed up.
No one was mixing in tacoma spindles but you.
Also the lexus GX460 is the same front end.
Also there have been members here that have used the 5th gen UCA on the 4th gen t4r.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
02-11-2020, 11:16 PM
#25
When I was looking for ball joints on mine, which I have not yet replaced. You can get the OEM brand joints from PartsGeek that are just the ball joints. You don't have to buy the control arm. That's what I plan to do this coming summer when I go to do my Alignment cam bolt Delete install....
02-12-2020, 02:08 AM
#26
Real Name: Danny
Real Name: Danny
Do you people just skim without reading? Because that was the stupidest response I've seen today. He stated that all the front ends are the same when in fact not all parts are interchangeable. You cannot put a Tacoma uca into a 4th gen spindle. You cannot put a 4th gen uca into a Tacoma spindle. It's physically impossible.
02-12-2020, 02:30 AM
#27
Fyi
4th gen runners
2nd gen tacos
And some fJ's
PERIOD
Ball diameter is larger on the SUVs. I remember someone trying to mix parts and finding out the diameter differences. So yes they are all the same suspension but the parts vary slightly so not exactly the same.
02-12-2020, 01:34 PM
#28
Real Name: Derek
Real Name: Derek
Chill the F out dude, you are still arguing with yourself... and i am the idiot?
YOU injected the Taco parts not me...DUH.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
02-12-2020, 01:39 PM
#29
Real Name: Danny
Real Name: Danny
Reading comprehension isn't your strong suit is it? Try starting from the top and working your way down. I wasn't the one claiming all front ends across multiple platforms are the same.
02-12-2020, 01:43 PM
#30
Real Name: Derek
Real Name: Derek
Still talking about yourself?
What a putz.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
