Old 09-19-2019, 11:11 PM #1
rock6802 rock6802 is offline
rock6802 is on a distinguished road
265/70r17 rubbing sway bar
I've got em on a set of pro comp 17x8 0 offset 4.5 backspacing and they're rubbing on the sway bar so I'm thinking of just getting new rims. Any recommendations that won't rub? How much backspacing do i need? If I lift it more will that do the trick? All I have now is a from leveling kit and the adjustable bilstein 5100s...total novice over here
2003 4runner Limited AWD v8
Bilstein 5100's + leveling kit
265/70R17 BFG KO2s
rock6802 is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 03:14 PM #2
techno's Avatar
techno techno is offline
techno has a spectacular aura about techno has a spectacular aura about
techno's Avatar
What part of the sway bar are they rubbing?
I got a 2000 and a 2008 SR5 4x4.
techno is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 07:13 PM #3
Right here
265/70r17 rubbing sway bar-885bb511-1983-4441-a5e7-8ddcfc92972f-jpg
265/70R17 BFG KO2s
Old 09-20-2019, 07:20 PM #4
duffdog duffdog is offline
duffdog will become famous soon enough duffdog will become famous soon enough
Everyones oversized tires rub on that. Show me one picture of a 4th gen on 33's that doesn't rub on the front sway bar. There is no way to fix that aside from removing the sway bar or getting a new truck. Even changing rims won't do anything because the 4th gen turning radius is so tight that every offset of every combination will have the same result. And before anyone says anything about "have you tried"... I literally have 4 different sets of 33's on 4 different offset rims sets and they all do the same thing.
I would be very interested in seeing a setup on any 4th gen which allows for no rubbing with 33s on anything under any condition. I would buy that suspension setup in a second.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 08:44 PM #5
jrm's Avatar
jrm jrm is offline
jrm is on a distinguished road
jrm jrm is offline
jrm's Avatar
how much front lift?
stock UCAs? where in the wheel/tire upgrade process was the alignment done? results...
jrm is offline   Reply With QuoteReply With Quote
Old 09-21-2019, 01:46 AM #6
Well good to know I'm not alone haha. They weren't rubbing on stock rims but I've tried two sets of rims and still the same. I thought I was just screwing up my math. Rather rub then go back to stock!
265/70R17 BFG KO2s
Old 09-21-2019, 04:19 PM #7
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss will become famous soon enough
MY GARAGE
rdruss's Avatar
Real Name: Ron
MY GARAGE
So there you have it duffdog, stock rims and no rubbing.
Old 09-24-2019, 06:14 PM #8
Porqupine82's Avatar
Porqupine82 Porqupine82 is offline
Porqupine82 will become famous soon enough
I have 34s and don't rub. Remove the sway bar.
Instagram: overland_tennessee
Website: www.redclayrally.com
Porqupine82 is offline   Reply With QuoteReply With Quote
Old 09-25-2019, 10:09 AM #9
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a jewel in the rough That_Titanium_4RNR is a jewel in the rough That_Titanium_4RNR is a jewel in the rough That_Titanium_4RNR is a jewel in the rough
MY GARAGE
Real Name: Michael
MY GARAGE
Same
Titanium Metallic 2006 Limited 4WD V8 | 5th Gen Brake Swap | Slyfox AIP Bypass | TPMS Bypass | Fog Light Mod | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 09-25-2019, 05:03 PM #10
No way is that true. I tried with stock rims and 285/70/17 and they DEFINITELY rubbed on the sway bar. They rubbed even more than the -10mm, 0, and -20mm offset wheel and tire combo I tried.
The only way they did not rub is if he also had the stock tire size or the tires were smaller than 33x12.5r17.
2005 Blue SR5 v8
Old 09-25-2019, 06:01 PM #11
techno's Avatar
techno's Avatar
I have 265/70s on 5th gen rims, which I think have 15mm offset and they don't rub.
backspacing , bar , lift , rubbing , sway
Anyone else rubbing the sway bar? MisplacedTexan 5th gen T4Rs 6 06-05-2019 08:48 AM
Got an alignment now rubbing on sway bar. Velonici 4th Gen T4Rs 2 08-30-2018 01:24 PM
Sway Bar Rubbing Coilovers BlackWorksInc 4th Gen T4Rs 34 08-17-2017 06:55 PM
Rubbing with 275/70R17 Goodyear MTRs? frankvh Off-Roading 4 06-30-2005 12:02 AM
Copyright © 2019
