Old 09-20-2019, 06:44 AM #1
MrSeth's Avatar
MrSeth MrSeth is offline
Real Name: Seth
MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough
MrSeth's Avatar
Real Name: Seth
Common Broken Parts During Trips
Hey all!
I have an up coming trip to Moab, UT in October- being far away from home, what are some spare parts y'all recommend I bring?
I have:
1. 2x spare rear shocks with hardware
2. 2x cardan/universal joints
3. Air filter
4. Fuses
5. Complete tool kit
6. Spare tire
What else should I bring? I plan on greasing everything before I go, and possibly doing the dual electric rad fan upgrade.
TIA!!
Seth
2006 Shadow Mica SR5 v6
1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
MrSeth is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 10:12 AM #2
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
Originally Posted by MrSeth View Post
Hey all!
I have:
3. Air filter
4. Fuses
6. Spare tire
TIA!!
Seth
I would definitely bring a spare CV shaft, fan belt, radiator hoses, radiator hose clamps. Also probably a good idea to replace all of the above (except CV shafts) before you go and do spark plugs.
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 10:42 AM #3
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
I don't like replacing or greasing anything just before a trip, to me it just increases the chances of something going wrong. For example overgreasing bushings can shred them pretty quickly, I've seen where someone greased UCA bushings before a trip and they died partway through. My theory is if its lasted daily driving the odds are good it'll survive one trip. Do it afterward or like a month before.
Might want to bring a spare tie rod.
Maybe a tire patch kit.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 12:41 PM #4
Crikeymike
Guest
Posts: n/a
Crikeymike
Guest
Posts: n/a
Spare fluids!!
Definitely a tire repair kit and an air compressor. Even if it's a slow/cheap air compressor, it's better than nothing.
Pull out your spare and make sure it's in good shape in case it needs to be run.
Are you expecting to break/damage the rear shocks? I'd do a full suspension travel test to make sure nothing on them binds up and make sure the top bushings are properly installed.
If your UCA's have been touched recently, make sure that the nuts are properly torqued. I've seen a few people this past year had that nut back off, with no spare. It sucked for them to get it back together and home again.
Old 09-20-2019, 01:48 PM #5
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Just some other applicable ideas…
A digital multimeter and basic electrical tools and consumables like a crimper, butt connectors, replacement fuses, bulbs.
Air compressor, tire patch kit, green slime, replacement valve stems, spare wheels studs, torque wrench.
Tow strap of various lengths , D rings, basic recovery gear gloves, safety vest, safety glasses.
Break fluid, coolant, quart or two of oil.
First aid, medication, thermometer, radio, GPS, satellite communicator.
Old 09-20-2019, 07:10 PM #6
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
tie rods, inner and outer...
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 09:35 PM #7
MrSeth's Avatar
Real Name: Seth
MrSeth's Avatar
Real Name: Seth
Thanks! Ive got a multimeter, E-tools, fuses, bulbs, an air compressor,torque wrench, lugs, d rings, gloves, a vest, brake fluid, coolant, and 3 quarts.
My first aid kit needs to be gone through, ive got a radio, GPS, and have been looking into a PLB incase my diabeetus goes awry.
Im glad you mentioned the above items- even though I have them, I might not have packed them!!!
Old 09-20-2019, 09:39 PM #8
MrSeth's Avatar
Real Name: Seth
MrSeth's Avatar
Real Name: Seth
I usually do a light greasing of the driveshaft and UCA's, but they have been great for quite some time now, maybe I wont touch them.
I am looking into tie rod ends, I wonder if I should just replace them pre-trip and then keep the old ones as spares?
I've run longer trips that have been more technical and hard on parts, I just don't want to break down and hold up the group at Moab- maybe Im just overthinking all of this?
Old 09-20-2019, 09:42 PM #9
Bumbo's Avatar
Bumbo's Avatar
Lots of PLB options these days... while I know the push and pray units are good, the Garmin inReach units are fantastic because its a 2-Way communication.
In addition to the SOS feature many of them can connect via Bluetooth to your phone, so you can use the Garmin app to text, using the inReach unit as a satellite modem for messaging.
I'm a big ham radio guy and id give up my radio before giving up my inReach for emergency use.
Old 09-21-2019, 02:07 PM #10
2003-4x4runner's Avatar
2003-4x4runner 2003-4x4runner is offline
2003-4x4runner will become famous soon enough
If you kept up on the maintenance on your truck, then you dont need much. But for sure take a Tire Repair kit and extra fluids.
I just did a 1500 miles round trip to DV on my 4Runner with 240k miles on the clock and I only took extra fluids and tire repair kit.
2003 V6 BLACK SR5 4X4-Runner
OB #1334
https://www.instagram.com/ob_1334/?hl=en
Dad's Travel Service.
We drive around till we find it. No map's needed!
2003-4x4runner is offline   Reply With QuoteReply With Quote
Old 09-21-2019, 02:50 PM #11
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
Why rear shocks?
You can still get by with a busted shock...for a little while.
Tools and a radio and first-aid kit.
Not like you are gonna be out in the middle of No-where...lots of help on the trail.
Can prepare for every situation and then that one thing happens you didn't think of...BAM!
You can also over prepare and just weigh down the whole adventure with TO MUCH CRAP.
Have fun.
Drive within your comfort level, don't let others force you into any situation you are uncomfortable with. Not everone is some kind of off-road King/Queen.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 09-21-2019, 03:06 PM #12
Inv4drZm's Avatar
Inv4drZm's Avatar
Originally Posted by BackOff View Post
Why rear shocks?
Have fun.
Yeah, my experience has been there is always help on the trails. I bring a spare CV, other people have loaned me PS/ATF fluid, we all support eachother.
Old 09-22-2019, 12:25 AM #13
MrSeth's Avatar
Real Name: Seth
MrSeth's Avatar
Real Name: Seth
Truth, I am meticulous with my maintenance. Ive got the fluids to take, and I just picked up a repair kit!
Old 09-22-2019, 12:26 AM #14
MrSeth's Avatar
Real Name: Seth
MrSeth's Avatar
Real Name: Seth
Good to know, and a confidence booster for sure... Ive got the fluids, I think my main parts ill bring are CV's and cardan joints. Im a little concerned with the level of grip + my center diff lock.
Old 09-22-2019, 02:45 PM #15
CO_Fletch's Avatar
CO_Fletch CO_Fletch is offline
Real Name: Jeff Homan
CO_Fletch is on a distinguished road
CO_Fletch's Avatar
What trails are on your list? A lot of the trails in Moab are close to town and there are parts stores in town that carry most items you might need, plus several 4x4 shops that can help as well.
When I first started wheeling, I had the same concerns, "what should I bring so I don't get stuck" After wheeling for the past 5 years all over CO, been to Moab several times, etc., I've probably become more complacent. I've been stuck way more times than I've broken down. That's why we buy Toyotas - they don't break I wheel a 200k mile 4th gen and my son wheels a 300k mile 3rd gen. Keep them maintained and they just keep working - off road or on road.
I still bring a full tool box but don't bother with CVs and all the other parts that might break or go bad. For example, a broken fan belt or ruptured hose isn't going to happen on the trail anymore than on the road and if maintained, won't be an issue on the trail. If you get a flat tire, that's what the spare is for and it's more likely the side wall or tread will be torn and plugs probably can't repair the tear.
If you do break a CV, you probably will need someone to pull you out to a better spot for repair so recovery gear is just as important as spare parts. I've used recovery gear on the trail, never parts. Having the CV would help if the local store doesn't have it or is closed for the day.
With fluids, if you lose fluids, you are either already leaking and carry fluids and if you don't leak, our rigs don't start to lose fluids going off road unless we hit and break something. In that case, you would probably need to get the part you don't have and then you can get the fluid you need to make the repair at the same time.
As someone else mentioned, probably best to avoid doing a bunch of changes just before you leave if you don't have time to make sure they are working as expected and no issues - those items are the ones more likely to cause issues on trail - something comes lose, doesn't work as expected, etc.
You mention concern about grip and center diff lock - what is the concern? I typically wheel Moab in 4 low and keep center diff locked unless I need to take a tight turn/turn around on slick rock. I know some like to engage and disengage CDL but I've found that when I really need it, it doesn't always lock so then I have to go back and forth and mess with it - it's just easier to stay locked and unlock for the rare tight turn or turn around on slick rock.
Moab is an awesome place - Enjoy!
'03 SR5 V6 - 3" Toytec Boss Ultimate. Stock wheels with 255/75/17 BFG MT. RCI Metalworks Full Skids, Rear Diff Skid and Rock Sliders.
'02 Limited V6 3.4L - 3" lift ToyTec/Bilstein. 4th Gen Stock Wheels with 255/75/17 BFG MT with G2 Spacers.
'99 SR5 V6 3.4L Supercharged, Stock (For now )
CO_Fletch is offline   Reply With QuoteReply With Quote
bring , kit , parts , spare , tire
mud/offroad + broken parts = FUN! offroad4r Classic T4Rs 3 12-17-2012 06:25 PM
WTB: parts from your broken/dead 4X4 switch F75gunslinger Want to Buy/Trade 1 04-10-2012 02:00 AM
What parts and pieces do these rigs have in common? FoneRunner 3rd gen T4Rs 5 05-17-2011 06:49 PM
Is a broken Upper control arm/link a common occurance? scoobydann 3rd gen T4Rs 4 12-17-2009 09:04 PM
ARB broken, mud and lots of broken parts sibanez 4th Gen T4Rs 14 08-02-2006 06:59 PM
