Just as an FYI, I recently had a front door speaker blow and researched all the options of replacement. replacing the doors with components, replacing the whole system, getting a new head unit etc.. etc..
In the end because I wanted to keep the stock HU and sub I wanted to find replacement speakers that matched existing as best possible, since most aftermarket 4ohm speakers would not match up with the rest of the existing JBL system
I ended up buying PowerBass 2ohm 6.75" for the front doors, and PowerBass 2ohm 6.5" speakers for the rear doors. I installed the one 6.75" speaker in the door that was damaged and nearly stopped there, but I ended up installing all 4 and the system sounds great again.
Not sure what you are going for with your system build, but unless you're planning on ripping out the HU and get a new amp for a replacement sub I cant recommend these affordable 2ohm speakers I installed. link below.
Rear Doors
PowerBass L2-652 6-1/2" 2-way car speakers — for use with 2-ohm factory systems at Crutchfield
Front Doors
PowerBass L2-675 6-3/4" 2-way car speakers — designed to replace 2-ohm factory speakers at Crutchfield
