Old 09-27-2019, 11:53 AM #31
Originally Posted by kcdehart View Post
Can't speak for him, but I use 10w-30 in the summer because it thins out less than 5w-30. If I have an oil change in the winter I'll typically use 5w-30 to try to limit startup wear.
The owner's manual has a range of oil weights to use for certain temperature ranges.
how does a 10/30 thin out less than a 5/30?
& the owners manual, at least for my 2008, shows 1 weight of oil... 5/30 for ALL temps from -20f to 100+f.
there is no benefit or reason to use a 10/30 oil in these engines.
Old 09-27-2019, 11:59 AM #32
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough
phatcheeks's Avatar
119k. still on original engine oil.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
phatcheeks is offline   Reply With QuoteReply With Quote
Old 09-27-2019, 12:25 PM #33
kcdehart's Avatar
kcdehart kcdehart is offline
Real Name: Kevin
kcdehart is a jewel in the rough kcdehart is a jewel in the rough kcdehart is a jewel in the rough kcdehart is a jewel in the rough
kcdehart's Avatar
Real Name: Kevin
My bad, they have the same viscosity at running temps, so thin out isn't really the right term here. I was thinking of my Volvo which I run 5w40 in instead of 5w30, as it sees some hot conditions with the turbo.
I'd personally rather run a thicker oil as long as it's not too cold out. Especially with my engine getting close to 200k miles. Clearances are gonna be getting ever-so-slightly larger, so I'm worried about oil pressure being lower on startup with thinner oils (especially when it's pushing 100 degrees in the summer here). Maybe I'm just paranoid because I've owned vehicles known for spinning bearings, but I prefer the heavier weights.
'04 4Runner - Build Thread | '05 CBR 600RR & 1000RR - The slow vehicles ;)
kcdehart is offline   Reply With QuoteReply With Quote
Old 09-27-2019, 03:01 PM #34
ok, was just curious what you meant by that. & just an FYI, but thicker oil doesn't help anything related to heat or turbos... oils main job besides lubrication is cooling internal engine parts & a thinner oil flows better than a thick oil, therefore cooling better.
also, thicker oil isnt better on start up, same thing applies for flow on start up, it takes a lot longer for a thicker oil to get pumped through the engine at start up, cold or hot. dont get too hung up on pressure, pressure is not what protects engine parts, its the flow & ability of the oil to get in & out of tight clearances, pressure is just a factor of the pump vs bearing clearances & i doubt your clearances are worn so much that you need thicker oil. a standard rule is 10psi for every 1000 rpms which im sure you have, so at start up you want flow more than psi.
think of it this way, you can try to pump oil through a very small hole like a syringe needle, it will have very high pressure because it can barely get out of the opening, but the volume of oil will be very very minimal.... same applies to an engine, you want a minimum psi to keep metal parts from touching, but just as important or more, is having enough flow/volume. either oil will work ok & 10/30 wont blow up the engine or anything... but if your oil pressure light isn't coming on with 5/30, its probably better for the engine to run the weight toyota calls for. thicker oil isnt better if its not called for or needed.
Old 09-27-2019, 03:21 PM #35
kcdehart's Avatar
Real Name: Kevin
kcdehart's Avatar
Real Name: Kevin
a standard rule is 10psi for every 1000 rpms, so at start up you want flow more than psi. think of it this way, you can try to pump oil through a very small hole like a syringe needle, it will have very high pressure because it can barely get out of the opening, but the volume of oil will be very very minimal.... same applies to an engine, you want a minimum psi to keep metal parts from touching, but just as important or more, is having enough flow/volume. either oil will work ok & 10/30 wont blow up the engine or anything... but if your oil pressure light isn't coming on with 5/30, its probably better for the engine to run the weight toyota calls for. thicker oil isnt better if its not called for or needed.
I mention the turbo as it causes the engine bay to be at much higher operating temps, which are (from what I understand) when you want to have heavier weight oils. As the '30' may turn into a '20' at the higher operating temps, whereas the '40' will lubricate like a '30' would at lower temps (if that makes any sense).
I follow what you're saying about flow, and it's good to know. Sounds like the goal is finding the sweet spot, which I'm sure manufacturers do, provided the vehicle is being used within typical circumstances.
I'm curious now why so many people recommended running oils like 15w-50 and 20w-50 when I had my 3000GT. Possibly just because it was an older engine with looser clearances. Or because they were worried about pressure once it warmed up more than initial flow (that engine heated up *quick* with 2 turbos. And the rear cylinder bank area reached temps over 1000F when driving moderately hard). I'd imagine they'd run something like a 10w-50 if it was easily accessible.
Old 09-27-2019, 04:46 PM #36
higher operating temps needing thicker oil is incorrect. some of the best oils today are very thin synthetics, like 0/20, many modern high performance & turbo cars are spec'd for that or other thin oils. if you are within the designed operating temps of the engine, the oil isnt going to get hot enough to change its weight, definitely wont go from a 30 to a 20 in any normal operating temps.
yes its about finding the sweet spot, thinnest oil possible that keeps a good psi. our 4runners dont have a gauge but theres no reason to doubt what toyota says to use for oil, if yours doesnt burn oil between changes or smoke, & your oil light never comes on, i'd stick with the 5/30, will get better mpg theoretically & have better lubrication on start up.
older v8s may have looser clearances & can use a 10/40, but many GM performance cars from the late 60's & into the 70's used 10/30. it all depends on how the engine was built & the bearing clearances. a loose engine for drag racing may use 20/50, but to use 20/50 in any normal street car or stock vehicle is way too thick. thick oil causes all kinds of issues if the engine isnt designed for it.
im not familiar with 3000gt's so cant say what oil they spec, but if the motor was rebuilt for performance maybe it did have looser clearances & a thicker oil would be better? otherwise id rather have the thinnest oil that kept good psi, turbo or not.
Old 09-27-2019, 05:03 PM #37
kcdehart's Avatar
Real Name: Kevin
kcdehart's Avatar
Real Name: Kevin
yes its about finding the sweet spot, thinnest oil possible that keeps a good psi. our 4runners dont have a gauge but there no reason to doubt what toyota says to use for oil, if yours doesnt burn oil between changes or smoke, & you oil light never comes on, i'd stick with the 5/30, will get better mpg theoretically & have better lubrication on start up.
I believe a cherry red turbo may fall outside of designed operating temps ;) And as said turbo is cooled/lubricated by oil, that's gonna drive up the oil temps quite a bit. And as that manual specifies that 5w-40 is OK as long as you won't be using the car in <-4F weather, I think it's a 'better safe than sorry' situation.
I'll switch to 5w-30 in the 4Runner next oil change and see if I notice any gas mileage difference. It seems to be a tad quieter with the heavier oil, but that might just be a placebo effect.
3000GTs have a twin turbo, laterally-mounted 3.0L V6. So, that rear cylinder bank and rear turbo are butted up against the firewall. There were times when I'd run the car hard, park it at 8-9pm, and come out the next morning to an 80 degree vehicle on a 40-degree morning. The community basically found that running much less than 10w-40 - in one that was run hard from time-to-time - would result in 8-10 PSI of oil pressure at idle. Which is very much in the danger zone for those cars. There seemed to be a constant battle to keep oil pressure high to prevent spun bearings. Probably just a poorly designed 90's engine. But they made some decent power
Old 09-27-2019, 05:32 PM #38
what are you doing to cause the turbo to be cherry red? is that normal? the engineers designed the engine to factor in the added temps of the turbo, & the oil they say to use can handle the extra heat, especially if you use a synthetic, a 10/30 synthetic will handle just as much heat as 20/50 & technically if thinner oil still meets adequate psi, it will cool the engine better than an overly thick oil due to better flow. thats how i understand it after lots of research on oil & what my engine builder explains.
i own a 1981 turbo v8 trans am, early draw through carburetor design, no inter cooler, it runs hotter than most other modern turbo cars i see, a friend has a 700+hp suburu wrx that runs much cooler. anyways, the t/a calls for a 10/30 oil on an older v8 engine, based on its clearances, a super hot turbo doesnt change the weight of the oil it needs.
each car/engine is different so use what you feel best about, but be sure to verify with a reputable source what is actually best, there are a lot of myths & false info out there on oil. i just wanted to provide some info based on what ive learned over the years from talking to oil companies & engine builders & owners of very fast cars.
also, i think there was even a toyota bulletin saying the v6 after 2006 can use the current 0/20 or maybe its 5/20, that the 5th gen 4runners use. they are going as thin as possible for the same reasons.
Old 09-29-2019, 03:54 PM #39
kcdehart's Avatar
Real Name: Kevin
kcdehart's Avatar
Real Name: Kevin
Definitely not normal - I was chasing a GTR on Tail of the Dragon. I wouldn't say the car sees that kinda driving often, but when it does, I'd like the thicker oil for sure.
The info is much appreciated! Sounds like you know your stuff with it.
Old 09-29-2019, 06:42 PM #40
summit21 summit21 is offline
summit21 is on a distinguished road
204K, Mobil 1 5w30, Mobil 1 in the Differentials, and Redline ATF in the tranny.
2018 TRD Pro, BFG TA KO2 265/70/17
summit21 is offline   Reply With QuoteReply With Quote
Old 09-30-2019, 10:57 AM #41
meltdowner meltdowner is offline
Real Name: Tim
meltdowner is on a distinguished road
Real Name: Tim
58k 2006 v8 sport
Mobile Synthetic
meltdowner is offline   Reply With QuoteReply With Quote
Old 09-30-2019, 12:43 PM #42
derekdevasia's Avatar
derekdevasia derekdevasia is offline
Real Name: Derek
derekdevasia is on a distinguished road
Real Name: Derek
240k, Mobil 1 Full synthetic 5w-30 every 10-15k. Girlfriends 4runner is on Mobil 1 5w-30 full synthetic and is pushing 350k
2004 toyota 4runner v8 4x4.
Bilstein 5100, Toytec Superflex, toytec/elibach front lift coils, 1 inch toytec body lift. 17x9 Method The Standard wheels, 285/70/17 Cooper AT3's, LC80 Snorkel
derekdevasia is offline   Reply With QuoteReply With Quote
Old 09-30-2019, 01:52 PM #43
WarChild's Avatar
WarChild WarChild is offline
WarChild is on a distinguished road
WarChild's Avatar
I use Rotella T6 in everything I own. From my F350 to my BMW R1200 GSA
WarChild is offline   Reply With QuoteReply With Quote
Old 09-30-2019, 10:06 PM #44
TT4RLtdV8's Avatar
TT4RLtdV8 TT4RLtdV8 is offline
TT4RLtdV8 is on a distinguished road
TT4RLtdV8's Avatar
Huge rotella user in my XJ's, so ^that guy gets it.
My 06 V8 has 246400 on it. I use Mobil 1 Full Synthetic High Mileage with OEM Toyota filters. Fumoto valve too so oil changes are as easy as your skid plate bolts will come out.
2006 V8 4WD Limited - DT Long Tubes, Y Pipe, Gibson, TitaniumWorks, Bilstein, RESZ Links, ARB, orangeBoxx MOLLE and dead pedal, Pedal Commander.
TT4RLtdV8 is offline   Reply With QuoteReply With Quote
Old 09-30-2019, 10:40 PM #45
trey99ek trey99ek is offline
trey99ek will become famous soon enough
Originally Posted by meltdowner View Post
58k 2006 v8 sport
Mobile Synthetic
58k in 13 years. Do you even drive it.
Sent from my SM-G960U1 using Tapatalk
2008 Sport Edition - GONE
2020 TRD ORP
trey99ek is offline   Reply With QuoteReply With Quote
guys , miles , mine , oil , shop
3rd gen engine w/120k miles Houston, Tx $750 zwalker16 For Sale: T4R Items 0 11-28-2018 11:28 PM
Annual 1yr/20k miles Engine Oil Change TripleTS_T4R General Discussions 17 10-18-2017 02:03 PM
4.7 V8 Tundra (same engine as our 4r with 1 million miles) Arthur4R 4th Gen T4Rs 11 08-29-2016 11:43 AM
600,000 miles on a Toyota Engine! Toyota4Runner Maintenance/Detailing 9 03-22-2005 04:05 PM
