After getting an “alignment” from a local shop and after giving them the paperwork instructing them on how to mess with the caster with the SPC control arms I noticed my rig started pulling right a week after getting the alignment.
Upon further inspection the shop did not adjust the castor position on the UCA but with the LCA.
The post alignment castor was 2.4 degrees but his machine says “3.5” now.
I am using quotes because my before and after alignment numbers are pretty shady. The before numbers are pretty symmetrical but I remember one tire had really bad positive camber while the other tire looked fine. The steering wheel stays slightly to the right but the post alignment numbers all match and are within spec.
Is it within Toyota spec to have both cam bolts in such a far range from one another rom back to front?
