Old 09-29-2019, 01:43 PM #1
Pekoe1111 Pekoe1111 is offline
Pekoe1111 is on a distinguished road
Can You Override RAS Sensors with XREAS?
I just bought a 2008 Limited with XREAS and would like to get 275/65-18 tires and do the Daystar 2.5 front spacer and override the rear air suspension sensors to increase the rear by 1.5 inches.
I know I will need to push the inner fenders forward and do a little mudflaps trimming, and use Spidertrax 1.5 wheel spacers.
My question is, can you override the sensors using the method people describe even if I have XREAS?
Anything I am missing, or have incorrect?
Thanks!
BB
Pekoe1111 is offline   Reply With QuoteReply With Quote
Old 09-29-2019, 01:49 PM #2
Bossman's Avatar
Bossman Bossman is offline
Bossman has a spectacular aura about Bossman has a spectacular aura about
Bossman's Avatar
RAS sensor adjustment
I easily added a 3 inch lift to RAS equipped 4runner - Toyota 4Runner Forum - Largest 4Runner Forum
Rear Air Suspension Daystar set up.
Rear Air Suspension Adjustment
Summer: Michelin Premier LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 09-29-2019, 03:17 PM #3
XREAS v RAS
Are they the same thing?
Old 09-29-2019, 03:34 PM #4
Real Name: Skip
AuSeeker is a name known to all AuSeeker is a name known to all AuSeeker is a name known to all AuSeeker is a name known to all AuSeeker is a name known to all AuSeeker is a name known to all
Real Name: Skip
No they aren't the same thing, RAS is an air bag system in the rear to adjust ride height, XREAS is the shock absorber system where the shocks are hydraulically connected in an X pattern to make the vehicle more stable.
2004 Limited V8
Old 09-29-2019, 07:37 PM #5
Front Struts
My front struts appear to have some leakage but not from the XREAS connection - just your typical damp sides. Since I just bought the truck, Im not yet sure if the system works as it should.
Best case is everything is working, and I can do the Daystar 2.5 up front and adjust the RAS.
Question - if the front XREAS struts are shot, does that mean I have to either replace them with XREAS struts or replace all struts with regular ones, like Bilstein 5100?
Thanks!
Time crunch due to sale on 275/65-18 Duratracs but Im trying to minimize strut and coil replacements due to limited funds.
Old 09-29-2019, 08:16 PM #6
Real Name: Skip
Real Name: Skip
My front struts appear to have some leakage but not from the XREAS connection - just your typical damp sides. Since I just bought the truck, I’m not yet sure if the system works as it should.
Best case is everything is working, and I can do the Daystar 2.5” up front and adjust the RAS.
Thanks!
Time crunch due to sale on 275/65-18 Duratracs but I’m trying to minimize strut and coil replacements due to limited funds.
If any of the XREAS shocks are leaking at all they need to be replaced, not just the fronts, all of them due to age.
You can replace them with OEM XREAS shocks...but they are very expensive, most simply do away with them and replace with standard shocks.
I know that's not what you wanted to hear but it's the facts...you should be fine to replace them later if the ride feels OK for now and wait for them too get worst to replace which gives you time to save some money to do so, just keep an eye on your tire wear in the meantime.
2004 Limited V8
Old 09-29-2019, 08:27 PM #7
Thanks, that what I figured because I know they are connected diagonally front to back. Yes, not investing in XREAS shocks!
Old 10-02-2019, 12:11 AM #8
grave's Avatar
grave grave is offline
grave will become famous soon enough grave will become famous soon enough
grave's Avatar
Why so many spacers? They’ll make your truck ride like shit and wear out your shocks (not struts, 4runners don’t have struts)
pet every dog!
also (4Runners don't have struts)
grave is offline   Reply With QuoteReply With Quote
override , rear , sensors , spidertrax , xreas
AC override? simple Problems & Warranty Issues 6 03-13-2014 09:02 PM
The reason why Non-Xreas takes on ramps better than Xreas. MICA4R 4th Gen T4Rs 14 05-14-2013 09:14 PM
XREAS rear height sensors ollie 4th Gen T4Rs 2 06-04-2008 10:58 AM
6.1 Nav override banker1 4th Gen T4Rs 0 02-05-2008 03:08 PM
Override NAV with the TSB? LSUMBA Engines / Suspension / Wheels / Tires / Audio / Accessories 0 02-12-2007 12:14 PM
Copyright © 2019
