Old 10-07-2019, 11:42 PM #16
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough
phatcheeks's Avatar
Originally Posted by Mike07SE View Post
He's already past the range of suspension travel with the shocks he's using. If he were using shocks that were shorter in overall length he could probably stick with what he's got. Since his suspension is starting to bind with that setup, he should take it off and compensate for the lean by spacing a rear coil where there wouldn't be any adverse affect to the front suspension.
thanks for that. I do know that adding a spacer actually extends the travel more since its pushing the shock down lower vs having a spring that is 1/4 inch taller keeps the same shock travel.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
phatcheeks is offline   Reply With QuoteReply With Quote
Old 10-07-2019, 11:50 PM #17
phatcheeks's Avatar
phatcheeks's Avatar
I checked again for binding and for some reason it is not binding anymore. It seems like the alignment might of messed with the angle of the cv to wheel and fixed it.
Again, it was binding very little so any minor change could of fixed it.
i did notice though that at full droop and turning wheel all the way to the right the outer boot touches the lower shock mount. Nothing to terrifying hopefully.
Passenger is fine.
So for now the diff drop is off (might install later) and the spacer is still on.
Old 10-08-2019, 07:40 AM #18
Mike07SE's Avatar
Mike07SE Mike07SE is offline
Mike07SE will become famous soon enough
Mike07SE's Avatar
Sorry I wasn't trying to insult you, I was trying to explain the scenario to andreylights.
SOLD2007 4Runner Sport Edition V6 4X4 - Natural White - Perf: Doug Thorley Long Tube Headers | 4.56 Gears ARB Front / TrueTrac Rear Off Road: Fr: Bilstein 6112 w/1/2" Toytec Spacer / Rr: MT ICON Long Travel | JBA UCAs | VTX Rogue 17x8.5 -10 | GY Duratrac 285/70R17 | Rear Diff Breather Mod | 1" Toytec Body Lift | Custom Cut Axle Joints ICE: Auto Pumpkin 10.1" Android | 3.5" Tweeter Mod Exterior: Quad Bi-Xenon HID Retrofit
2019 4Runner Limited 4x4 - MGM - Hers | Ironman4x4 FCP's & UCA | Fuel Rebel 20x9+1 | GY Duratrac 275/60R20 | Victory 4x4 FLRR
Mike07SE is offline   Reply With QuoteReply With Quote
Old 10-08-2019, 10:48 AM #19
phatcheeks's Avatar
phatcheeks's Avatar
Lol I wasnt insulted. Just saying thanks, and giving some more explanation.
Old 10-12-2019, 12:58 AM #20
Elitepass010 Elitepass010 is offline
Real Name: Daniel
Elitepass010 is on a distinguished road
Real Name: Daniel
Tour other option would be to do a proper suspension lift, vs just a shock lift..... thus retaining the proper suspension travel and eliminating any bind (proper suspension lift will raise chassis while leaving suspension and diff at current height) example would be this rough country lift.
4-5in Suspension Lift Kit for 89-96 Toyota 4wd Standard Cab Pickup [734.20] | Rough Country (R)
Elitepass010 is offline   Reply With QuoteReply With Quote
Old 10-12-2019, 07:23 AM #21
Mike07SE's Avatar
Mike07SE's Avatar
Your talking about a bracket lift which no one on these forums really do as it's not really as functional offroad as opposed to a proper suspension lift. Your just lifting the hell out of the truck to clear big tires while keeping components nearly the same distance from the ground.
Sent from my Pixel 2 using Tapatalk
Old 10-13-2019, 03:03 AM #22
Real Name: Daniel
Real Name: Daniel
Unless you are talking about a steering knuckle drop there is no diffrent to a bracket drop on a IFS or a suspension lift on a solid axle. The differential will still be at the same height from the ground. So that's a mute point. This conversation was about a cv axle bind on a IFS due to a larger shock being installed...... to correct bind you either go back to the shock designed for the geometry of stock IFS. Or you drop the chassis to IFS height to correct geometry and not have the suspension sitting at close to full extension. Long story short if you raise height of vehicle with a shock or spacer, you must raise the chassis the same height to maintain proper suspension travel, suspension geometry, cv geometry and the correct steering .
Old 12-08-2019, 11:50 PM #23
phatcheeks's Avatar
phatcheeks's Avatar
Hi. Just a follow-up. I ended up removing my front spacer and added a Daystar 1.5" in the rear left. Front has dropped a bit, but not much. Has more rake which I prefer. Also ditched the diff drop as my CV angles are much better now.
Now time for a re-alignment
Thanks for the help.
Old 12-10-2019, 11:36 AM #24
Mike07SE's Avatar
Mike07SE's Avatar
Glad that worked out for you. Chasing CV binding is no fun.
Old 03-05-2020, 01:36 PM #25
phatcheeks's Avatar
phatcheeks's Avatar
Hi. since installing the rear daystar spacer I have noticed the rear end likes to jump a lot over bumps. Like it rebounds much quicker and harsher. especially when going over speedbumps and dips. Before it was a lot more plush and I was able to drive through those with no issues. What could be the issue?
Old 03-10-2020, 03:48 AM #26
MrSeth's Avatar
MrSeth MrSeth is offline
Real Name: Seth
MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough
MrSeth's Avatar
Real Name: Seth
I'm going to lean towards worn rear shocks. I had the same issue with literally the exact same setup, swapped shocks and voila, no more trampoline effect.
2006 Shadow Mica SR5 v6
1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
MrSeth is offline   Reply With QuoteReply With Quote
Old 03-10-2020, 10:39 AM #27
phatcheeks's Avatar
phatcheeks's Avatar
Shocks are fairly new. Less than a year/10k miles. I was doing some research and it seems like my rear setup is too high so the shocks are running out of travel at ride height. My best option right now is to remove the spacer and just run it like it is and hopefully that fixes it.
Old 03-10-2020, 11:11 AM #28
NinjaOne's Avatar
NinjaOne NinjaOne is offline
NinjaOne will become famous soon enough
NinjaOne's Avatar
Likely this. Can pull the spacer or source slightly longer shocks.
Also, re: CV bind. I've seen several people clearance the CVs slightly to prevent bind. Basically pull the boots and grinding/smoothing out the edge of the housing to allow slightly greater angles
<a href=https://www.instagram.com/t4r_juan/ target=_blank>t4r_juan</a>
NinjaOne is offline   Reply With QuoteReply With Quote
Old 03-10-2020, 11:36 AM #29
phatcheeks's Avatar
phatcheeks's Avatar
Thanks, Ill probably just pull the spacer out for now until i decide on a new suspension setup.
and for the CV bind, the problem was fixed after i removed the front spacer. My boot still rub a little but not enough to go through all the way. There is just a small groove in the boot.
bind , freely , passenger , side , spun
Need help quick please. In a bind. 983RDGEN 3rd gen T4Rs 10 10-10-2019 06:07 AM
I'm in a bind and need help from a machinist! T4Rscott Off Topic 7 10-09-2019 08:47 PM
Do any Gen 4's bind on turns in 4hi like Gen5's? Kennyr44 4th Gen T4Rs 11 08-30-2015 03:46 PM
Drivetrain Bind: SOMEONE FIX IT. Danimal Off Topic 5 06-12-2015 05:17 AM
Steering bind/pop onemanarmy Classic T4Rs 0 11-23-2014 11:47 PM
