Originally Posted by 4RunnerMexico
Alternator Brushes: If you're still running your OEM Denso and the bearings are good, this will save you a headache in 40-50k. Pulling the alternator out and replacing these during a timing belt really only adds about 15 minutes of your time. Just pull alt. and remove 3 8mm nuts on the back.
TOYOTA: 27370-20130
That's not a bad idea!
Mine is currently in pieces in the garage as it's a 3rd vehicle but typically when I do a Tbelt on a Toyota I do the belt, water pump, idler and tensioner pulleys, serp belt, plugs and replace the rad. Cam seals are dry so I'm not pulling them.
Y'know... while you're there. I'm currently doing a truck that has 256,000KM (160K miles) that had an original belt and water pump. The rad was leaking badly and the water pump has been weeping for quite some time. A bit of deferred maintenance but I seem to find them for decent prices.
