Old 11-05-2019, 09:14 PM #16
Terminator03 Terminator03 is offline
Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough
Originally Posted by Inv4drZm View Post
Thanks! That is super cool. I’ve never seen anything like that before.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
Old 11-06-2019, 10:17 AM #17
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Yeah, I just wish it held 2.25" and 1-5/8" tubing for headers.
When I first saw it I thought it was too expensive, but after cutting a few elbows on my bandsaw by hand, I had to have it. Should be real slick. Worth the price to not have to worry about cutting my hand.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 01:56 PM #18
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Whipped up a catback yesterday.
Dirty Deeds 5" diameter 20" length vs Magnaflow 6" diameter 18" length.
Sound camparison:
With just the Dirty Deeds catback, no y pipe the sound was deep, and when I added gears interstate travel was a little noisy with the higher RPMS.
With the Dirty Deeds and fabricated Y pipe/gears the sound was higher pitched and interstate drone might have gotten a little more annoying.
With the Magnaflow and fabricated Y pipe/gears the sound is deep like the first setup, but interstate travel is quiet.
So surprisingly the Magnaflow muffler is quieter than the Dirty Deeds. I lifted each system in each arm and the Dirty Deeds system is actually like 5lbs heavier!! I told you guys that thing was stout! I actually prefer the angry 'flat plane crank' sound the Dirty Deeds/ Y pipe combo gave me over the basic deep rumble, I'm not sure how to fabricate a system that sounds like that.
Most badass 4Runner exhaust system? (Excuse the temporary lack of headers)
The Magnaflow's deeper tone is most likely due to the increase in sound absorbing packing since it's larger in overall OD, and the packing in the Dirty Deeds may have deteriorated or partially blown out.
I just realized there's a helmholz resonator on the Dirty Deeds system. I wonder if extending it or adding another would reduce the drone, or add a small-case resonator like a Dynomax Race Bullet or Vibrant Perf. bottle-style...a larger diameter one might work too well and loose that cool angry sound. I can send you an unused 2.5" inlet/outlet aluminized Race Bullet if you're interested in testing it out.
Old 11-07-2019, 03:54 PM #19
Inv4drZm's Avatar
Inv4drZm's Avatar
I've ordered materials to make a 1/4 wave resonator/Helmholtz, and should be able to experiment with length using a slip fit and a clamp. Part of me wants to try and get rid of the lower pitched noise and leave the higher end but we'll see what happens.
The new Magnaflow setup is starting to sound like the Dirty Deeds setup, must have broken in a little.
We'll see what dual exhaust sounds like before I try different mufflers on the single systems, but in the end I might still end up running a single system for the weight savings.
Old 11-08-2019, 09:46 AM #20
doofenshmirtz doofenshmirtz is offline
doofenshmirtz has a spectacular aura about doofenshmirtz has a spectacular aura about
If you're measuring up you Dirty Deeds Helmholtz, would you mind posting the specs for it while you're at it? I've done some math, and I think I might be able to convert my factory resonator into a Helmholtz on my new exhaust setup - just cut the exhaust tip off and cap the resonator, then connect to the new exhaust with an elbow. I think the volume of the resonator is originally designed to reduce the drone at appx 1900-2200rpm. I wouldn't be surprised if the volume of the dirty deeds Helmholtz roughly matches the volume of the factory resonator.
doofenshmirtz is offline   Reply With QuoteReply With Quote
Old 11-08-2019, 11:24 AM #21
JONBOY345 JONBOY345 is offline
JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about
The Magnaflow stuff burns in over the course of the first 500-1k or so miles depending on how hot the exhast gasses are when they pass through the muffler.
I threw in a 2.5" Vibrant Ultra Quiet resonator in my Magnaflow cat-back setup it helped quiet a bit to help with drone. Didn't eliminate it completely, but certainly made it more pleseant in the cabin. Less than $100 on Amazon last I checked. Might be worth looking at if you haven't already.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
JONBOY345 is offline   Reply With QuoteReply With Quote
Old 11-08-2019, 11:55 AM #22
Inv4drZm's Avatar
Inv4drZm's Avatar
I'll post some info.
I meant sounded like the Dirty Deeds in a good way. I still doesn't have the drone the Dirty Deeds had when I swapped to 4.88 gears.
So I guess there is no real reason to play around with a Helmholtz in my current Magnaflow setup except to see if I can change the pitch or completely eliminate the little drone there is. Experimentation mostly.
Old 11-08-2019, 12:39 PM #23
I assume you've seen all the calculations needed for the Helmholtz, right? You can basically find the RPM correlated with the sound you want to eliminate and convert it to Hz (or even better - just get something to measure the specific frequency). From there, like you've said, it's just creating something volumetrically 1/4 the length of the soundwave to eliminate it.
My understanding is that the extra geometry of a resonator (conical ends with cylindrical body) give you more opportunity to catch other waves or provide some extra margin for error in the sizing.
I think your harder part will be that the magnaflow (and Gibson, etc.) itself is kind of designed to trap the higher pitched stuff and create the deeper tone, so you may be fighting a battle to get those back to an extent. You might even try straight pipe with a resonator or glasspak and a couple adjustable Helmholtz tubes to eliminate the headache areas.
Just slip fit a bunch of shit together in that long straight section and have some fun, lol.
Old 12-24-2019, 07:40 AM #24
DZNUTS DZNUTS is offline
DZNUTS will become famous soon enough
So I’m running the DT shorty headers with cats, factory Y pipe and about 1’ of the factory exhaust pipe behind the spring bolts. Then I clamped (temporary) a 2.25”-2.5” and 2.5”-3” reducer into 2’ of 3” pipe into a SpinTech 3” 9000 series muffler. Sounds amazing. A slight drone in the cabin due to the pipe dumping right below the rear seats (temporary).
I will be fabbing up a 2.5” Y pipe (pie cutting for bends) into a 2.5”-3” collector without cats. I will then run an 6” long 3” flex pipe rather than spring bolts. After the flex pipe I will run a 3” hi flow cat into my 3” SpinTech muffler. I’m running a top secret exhaust pipe route after the muffler, which I’ll reveal when it’s completed.
1995 ECR33 GTS-T (sold)
1990 s13 coupe TONS of work
2005 4Runner Sport V8
DZNUTS is offline   Reply With QuoteReply With Quote
Old 12-24-2019, 10:30 AM #25
Inv4drZm's Avatar
Inv4drZm's Avatar
My 2.5" Y pipe sounds amazing, not sure if it's because of the equal length legs or the diameter but you'll love it once its finished.
Old 09-03-2023, 09:27 AM #26
daprotege5 daprotege5 is offline
daprotege5 will become famous soon enough daprotege5 will become famous soon enough
i like the idea of making your own exhaust.
did you source the materials locally or order online??
just picked up a tig and my manifolds are leaking or they broke and their not even 6 months old. thinking of just redoing the whole exhaust. thiknking of getting some JBA headers, swap the cats over, and get rid of the secondary cats.
what did you use to bend the pipes??
daprotege5 is offline   Reply With QuoteReply With Quote
Old 09-05-2023, 09:41 PM #27
Inv4drZm's Avatar
Inv4drZm's Avatar
I ordered stainless bros elbows, and I think it was ebay tubing for the straight sections. You could buy all 90 or 180 tight radius elbows and cut them to the desired angle. Mark, cut, tack weld, repeat. Then finish weld the whole thing once its all pieced together. I did most of my welds without filler metal, only adding some where there was a gap in fitup.
One thing I would change is to add cats back in. I didnt spend the money and check engine light stays on and the exhaust fumes are pretty bad. Plus cats would probably quiet it down some and remove some rasp.
I made my own x pipe to save money. Lots of pics are in my build thread (somewhere).
dual , dyno , exhaust , single , system
Custom Exhaust putcha 4th Gen T4Rs 5 05-03-2014 12:01 AM
first time buying custom wheels SierraDan 4th Gen T4Rs 13 05-02-2014 10:45 AM
Custom Exhaust TRDSmokedU 4th Gen T4Rs 5 11-18-2011 01:46 AM
3rd Gen custom 304 SS exhaust Yota X 3rd gen T4Rs 17 02-16-2011 04:47 PM
Custom 4runner box with pictures this time Colo4Fun Classifieds - buy & sell (no commercial ads please) 2 12-23-2006 01:09 AM
