Old 10-08-2019, 09:08 AM #1
gaswede gaswede is offline
gaswede is on a distinguished road
Right rear squeak- sometimes
After reading tons of threads, I made the commitment to purchase a new wheel hub bearing assembly and all the associated parts needed for the axle shaft. I found a shop that would press everything off/on if they were allowed to pull the axle and do everything themselves. I agreed to this and brought it in only to be told my squeak was coming from the brake shield touching "something."
The shield was bend outward and I was charge 1 hr labor at $95. ugh.
After leaving, it continued to make the sound but only intermittently but under the same conditions as before (left hand turns only.) I brought it back this morning and of course, not a peep from the right rear! wtf!
So, im thinking im scewed out of $150 worth of parts that i bought bc ill loose money trying to return perfectly good parts.
any ideas on what else to check back there? again, its a squeak squeak squeak noise in the right-rear, only on left turns, changes with vehicle speed, does not go away with brake application, and is now intermitant.
'07 SR5 4WD
gaswede is offline   Reply With QuoteReply With Quote
Old 10-08-2019, 01:01 PM #2
T4RDirt's Avatar
T4RDirt T4RDirt is offline
Real Name: Devo
T4RDirt is on a distinguished road
T4RDirt's Avatar
Real Name: Devo
Have you checked the tension on the spare tire cable? Could also be bushings on your rear arms and/ or your rear sway bar bushings and links.
Sent from my ONEPLUS A6013 using Tapatalk
T4RDirt is offline   Reply With QuoteReply With Quote
Old 10-08-2019, 01:34 PM #3
havent checked the spare tire. good thought. ill look it over tonight.
Old 10-08-2019, 05:23 PM #4
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
It's possible that it could be something loose in the parking brakes, so after exhausting all other possibilities you may want to check that.
2004 Limited V8
Old 10-11-2019, 03:58 PM #5
ill do that. they need to be adjusted anyway. i forgot though, which way are the e-brake adjusters turned? i know they're opposite from each other but cant remember which side turns which way?
i have the dreaded Brake/Vsc/Slip lights on (no ABS light.) unfortunately, new gas cap, new brake switch, ecu reset, and ZPC have not worked. maybe the e-brake adjustment will help as i was in there screwing around when i replaced the regular brake pads.
brake , brought , parts , shield , squeak
Rear End Squeak eskimochaos 4th Gen T4Rs 5 05-05-2019 12:29 PM
Squeak coming from rear ericfromspace8 3rd gen T4Rs 4 11-03-2017 12:37 PM
Squeak from rear diveline Jt2El46 3rd gen T4Rs 5 03-07-2017 03:32 PM
Squeak From Rear DallasSR5 4th Gen T4Rs 6 07-12-2015 12:03 AM
Rear window squeak Glenn_Law 5th gen T4Rs 6 09-20-2011 10:58 PM
