Old 12-10-2019, 12:22 AM #46
Kryptoroxx's Avatar
Kryptoroxx Kryptoroxx is offline
Real Name: John
Kryptoroxx has a spectacular aura about Kryptoroxx has a spectacular aura about
Kryptoroxx's Avatar
Real Name: John
My 4runner interior is in many pieces right now. Lots going on but I didnt even want to take pictures lol. The atoto sounds great paired with the stock amp and hopefully I have some great progress pics tomorrow. Gotta get this thing back on the road.
Sent from my SM-G965U using Tapatalk
98 Toyota 4runner 3rz 5spd 4x4 - Sold Build Thread
06 4runner 2uz Build Build Thread
Instagram: @Kryptowerkz
Kryptoroxx is offline   Reply With QuoteReply With Quote
Old 12-12-2019, 11:23 PM #47
Kryptoroxx's Avatar
Real Name: John
Kryptoroxx's Avatar
Real Name: John
This took a little bit of figuring but by far was the easiest part. Getting into the rear door was as simple as removing the two plastic panels. Removing the bolt that holds the strap in, and then using a small plastic pry bar to pop the panel out. Then it slides up just a little and comes right out. You'll want to remove the little black caps that are coincidentally right where you need to get an extension in with a 10mm to undo the rear handle assembly. Make sure you unplug it and pull that through gently. After that you will have the part in your hands and can easily start working on the tougher part. You don't have to remove the light but I was figuring out how to get everything off and where the wires went through for the license plate lights.
This is what the tailgate looks like with the rear handle removed. The far right hole is for the lock.....so don't reinstall the grommet there.
This is the handle assembly. It is all one piece except for the lock which pokes through and mounts from the back side of the door. All of the nuts are 10mm so find wherever that devil is hiding if you're trying to do this.
Next you will have to gently cut into the plug that goes through the tailgate. Now the wires have their own run and are sealed so you can't fit any other wires through. I simply cut a place for the new ones to lie.
Use a little heat to melt the rubber back around the wire gland and then tape liberally. This area sees a lot of water so you don't want any getting into the interior of the rear door. Then reinstall.
This is how it should look when you get everything completed and reinstall your license plate. Here is a link to the camera that I got. It has a small LED light surround for backing up at night. All of these cameras are pretty much wired up the same. I can't confirm but it might even work with the stock system.
Amazon.com: Backup Camera, 175o Wide Angle Hidden License Plate Easy Install HD Rear View Back Up Waterproof Cam with 12 LED Colorful Nigh Vision (License Plate Camera): Car Electronics
Next part will be the snaking of the wires and the consequences of not getting it right.
Old 12-13-2019, 12:59 AM #48
Real Name: Skip
Real Name: Skip
Great job John...but hummm, I hate to tell you this but when you put it all back together you put the lift gate on upside down!!
2004 Limited V8
Old 12-14-2019, 08:31 AM #49
KrisB410 KrisB410 is offline
KrisB410 is on a distinguished road
I like this camera because it looks factory
Car Reverse Camera for Toyota 4Runner Land Cruiser Prado Fortuner SW4 Kluger CVX | eBay
KrisB410 is offline   Reply With QuoteReply With Quote
Old 12-14-2019, 02:49 PM #50
Kryptoroxx's Avatar
Real Name: John
Kryptoroxx's Avatar
Real Name: John
I didnt take it off lol. I blame the PO! Krypto's 06 2uz, the Sinister Bambi SlayerKrypto's 06 2uz, the Sinister Bambi Slayer
Old 12-14-2019, 10:10 PM #51
Kryptoroxx's Avatar
Real Name: John
Kryptoroxx's Avatar
Real Name: John
Small update:
The steering wheel controls now work and the stereo that fits the dash is now in as well. The other one is going back. That radio surround fit like crap.
Only problem is there is a difference between the radio bezels much to my chagrin. I'll have to find one for the navigation fitting but all in all I am very pleased with the atoto a6. The functionality is good and it was easy enough to hook up.
Still chasing problems on the backup camera. Everything in my wiring is good so next time I get to open up the rear door again I'll be checking the camera.
Old 04-08-2020, 11:25 PM #52
Jackkill1's Avatar
Jackkill1 Jackkill1 is offline
Jackkill1 is on a distinguished road
Jackkill1's Avatar
Originally Posted by doofenshmirtz View Post
It’s a bit of a pain to install but it’s great. The front grille comes off then this installs sandwiches between the hood and grille. They provide longer bolts but it’s still a tight fit. I liked that it blacked out the whole front for me.
I have Metallic Grey paint and this would blend well with my 4R. In Formfit's part description, they state "Excludes Sport Model". I have the 2007 Sport V8 model and I thought model year hoods were the same. Any idea why they exclude the sport model? I'll send them an email. Your's looks great, thanks for the info.
Jackkill1 is offline   Reply With QuoteReply With Quote
Old 06-10-2020, 01:15 PM #53
Kryptoroxx's Avatar
Real Name: John
Kryptoroxx's Avatar
Real Name: John
I have been neglecting this thread. Lots of things have gone on during the bad beer virus. Since I was home and I am unfortunate resident of Michigan I remained at home till like this week or something. Doesn't really matter at this point.
Suspension:
After waiting forever I finally got everything from BattleBorn.
Bilstein 6112 shocks with Eibach 700lbs springs up front. Installation was pretty easy once I figured out the no compressor method. I will be honest though getting the top nut on the springs was a tad trickier since I did not have a bumper sitting on it right now.
In the middle of the install I remembered I had Butyl Rubber so that was an easy mod.
I didn't take a whole lot of pics because this is still my dd. Time was of the essence. The rear was fairly easy but I remembered the use of my stock jack in getting the axle down far enough to get the b112 springs in. They were about 3“ longer than the stock ones.
Then I rolled it out for a little bit and then took care of the belly pans.
The arb plates are a very nice upgrade over stock but not as beefy as some of them available. My main goal was to protect a little more of the underbody from deer guts although I do still like to off road. This is the family model as it were.
Sent from my SM-G986U using Tapatalk
Old 06-10-2020, 01:34 PM #54
Kryptoroxx's Avatar
Real Name: John
Kryptoroxx's Avatar
Real Name: John
The suspension settled and the ride improved but what really helped it was the bumper. Nwti open top. It comes in a very small package and I thought the price was very good for what it is.
The instructions were pretty good and as long as you take your time on the center pieces the wings will practically fall into place
Then I started to weld everything up and make it solid. I did full welds on the outside and stitched up the interior.
Old 06-10-2020, 01:39 PM #55
Kryptoroxx's Avatar
Real Name: John
Kryptoroxx's Avatar
Real Name: John
More pics from the building. Mostly grinding work and flapper disc stuff. I used a rustoleum primer and hammered topcoat. So far it is holding up well to the humidity and rain.
Tires will be coming sometime soon? The stockers are in pretty good shape and I hate to waste good tires. They will be replaced by the winter just because they are not great in the snow. It was pretty twitchy in the snow and a Toyota 4runner, and especially an awd, should not be twitchy in the snow lol.
Old 07-30-2020, 11:39 PM #56
Kryptoroxx's Avatar
Real Name: John
Kryptoroxx's Avatar
Real Name: John
Just a quick update with some pictures. My parts pile is growing but my time to get them installed is short for now. Been working on the house for the most part.
Old 09-04-2020, 01:38 AM #57
Kryptoroxx's Avatar
Real Name: John
Kryptoroxx's Avatar
Real Name: John
The fed ex guy would have gotten a hug today if I saw him.
Nothing fancy on this besides the y pipe from urd. Walker stainless cat back will be going in behind everything so I don't get a drone from the setup. Lookimg forward to a couple of days straight in the garage installing this and welding up the tire carrier.
Old 09-09-2020, 06:04 PM #58
Kryptoroxx's Avatar
Real Name: John
Kryptoroxx's Avatar
Real Name: John
Got a lot of background work done for installation of the headlights. Added in some underhood lights as well.
I didn't install but she got some new shoes last week as well. The spare barely fit under but about half an inch. Ill be glad when the True North rear setups arrives and I can start building on that.
I've still got 3 more harnesses to complete for the headlights as well as a new drl circuit.
It looks like I will have everything complete by the first flake of snow. Ready for some ice fishing this winter up in Wisconsin.
Old 09-16-2020, 01:32 PM #59
Kryptoroxx's Avatar
Real Name: John
Kryptoroxx's Avatar
Real Name: John
Pictures of the progress with the quad retro. Definitely shaping up nicely.
Old 09-16-2020, 01:32 PM #60
Kryptoroxx's Avatar
Real Name: John
Kryptoroxx's Avatar
Real Name: John
A little more. So close
build , bumper , mount , plans , rear
Killer Toy Tops fireman9067 Classic T4Rs 5 05-27-2018 05:07 PM
Killer Mod before Snowstorm ! calcrc 5th gen T4Rs 3 01-14-2018 05:58 PM
Chicken killer Ol'Blue Off Topic 21 06-22-2013 03:13 PM
Porsche killer!!! SilentYoda3 Classic T4Rs 20 09-18-2012 06:03 PM
Toyota Killer cabowally 4th Gen T4Rs 5 07-19-2011 11:59 AM
