Old 11-06-2019, 11:50 AM #16
Originally Posted by AuSeeker View Post
The rule is to discourage Spammers.
unfortunately the rule doesnt stop them...
Old 11-06-2019, 01:21 PM #17
andywickstrom andywickstrom is offline
andywickstrom is on a distinguished road
I've noticed in our 03 V8 4Runner that the steering has recently felt a bit loose. We noticed it especially on a gravel road while turning into rough parking spot in the woods. I turned into this sort of deep gulch as I pulled in to park - the gulch was just for a moment, then the road was fine. But that maybe was the last straw for it and after that I could basically drive straight while the wheel could be off of level - which is definitely not how it used to drive. Our truck is getting up there in age - were are at 251K (highway) miles on it. We had it looked at and the wheel bearing had something to do with it. Is that right?
andywickstrom is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 10:17 AM #18
Captsolo Captsolo is offline
Captsolo will become famous soon enough
Originally Posted by dvto2 View Post
2005 4runner sport v6. 260 K. The truck was maintener by the dealer for the first 100 K and then I took over. One thing I never got to was ther power steering fluid. Last week the steering got stiff and a little jerky. I changed the fluid by sucking it out, exchanging a little at a time, until it looked clean, at least much cleaner. I exchanged almost a quart. However, the steering isn't much better. Do I need to exchange another quart, or should I be checking other things.
I have a 2005 SR5 V6 with 144,000 miles. Yours with 260,000 is huge. My steering is perfect and I changed PSF like you have. Hope yours is not a leak somewhere.
Mine PSF has always looked clear, but things wear out. PSP could be failing. Any squeels? Does it leak any fluid?
Captsolo is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 03:43 PM #19
Seasparrow Seasparrow is offline
Seasparrow will become famous soon enough
Youtube video shows a few tips
Flat spot on spline needs to line up with new joint (old clamp) so bolt can pass through. Also part of old joint (the clamp) may need to be reused.
I have never done this I am just saying the video is probably worth watching.
https://www.youtube.com/watch?v=bqPF_SNueyg
NATO Seasparrow Mk 57 Mod 2 & 3
2004 4th Gen Sport Edition
Seasparrow is offline   Reply With QuoteReply With Quote
Old 11-11-2019, 06:50 PM #20
MikeinNH67's Avatar
MikeinNH67's Avatar
Originally Posted by MikeinNH67 View Post
+1 for that shaft u-joint. It's not easy to see especially from above. I was able to lube mine up enough to free it but it still needs to be replaced at some point soon.
Replaced my steering shaft on the weekend. A pain to get the lower part off the rack but now no intermittent hard steering and the looseness is gone too. That u-joint was toast.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
clean , fluid , power , quart , steering
Power Steering Problems DirtDawg 3rd gen T4Rs 16 01-26-2016 03:54 AM
AC Power Steering problems? Gremcat Classic T4Rs 2 05-28-2014 10:53 AM
Problems with new power steering pump/ new pump with fluid. no power steering? cdcrone123 Classic T4Rs 3 08-27-2013 09:29 PM
Power steering problems AZ4runnerPrerunner Classic T4Rs 2 07-27-2013 09:07 PM
94 V-6 Power Steering pump problems edtheshark Classic T4Rs 4 02-18-2011 11:20 AM
