Old 01-06-2009, 01:54 PM #1
IK13 IK13 is offline
IK13 is on a distinguished road
Rear wiper almost not touching the window
The rear wiper blade on my '05 makes almost no contact with the window. Swings fine and gets back to "base", but is useless for actually wiping anything as it doesn't touch the glass.
Any ideas?
IK13 is offline   Reply With QuoteReply With Quote
Old 01-06-2009, 03:15 PM #2
steve germany steve germany is offline
Banned
steve germany is an unknown quantity at this point
Banned
Re: Rear wiper almost not touching the window
Any ideas?
I just noticed the same thing on my '06 in the snow/ice. I'm going to check my rear defroster and ensure that the rear window is up all the way and the the rear hatch contacts are not impeaded.
steve germany is offline   Reply With QuoteReply With Quote
Old 01-06-2009, 03:21 PM #3
If the window is not up all the way, the wiper won't swing at all.
Old 01-06-2009, 10:43 PM #4
T4RSpectreSix's Avatar
T4RSpectreSix T4RSpectreSix is offline
T4RSpectreSix is an unknown quantity at this point
This came up a month or so ago. I think the thread ended up agreeing it was likely due to the metal spring in the arm assembly freezing up and not pushing the blade up to the window in cold weather.
2004 SR5 V8 4WD Natural White
Retrofitted tails to Toyota factory LED
Tint 35% Fronts/20% Rears
Chromed Signal Bulbs
PIAA Headlamp Bulbs
LED Plate Bulbs
Valor Exhaust Tip
Dbl Decker Cargo
Pwr Moon Roof
Garmin GPS
Rear Spoiler
265/65R17
T4RSpectreSix is offline   Reply With QuoteReply With Quote
Old 01-07-2009, 11:15 AM #5
Not much of a cold weather in SoCal.
Went up the mountain last week, but it was doing it before that for sure...
Old 01-07-2009, 08:02 PM #6
Ah, I gotcha. Well in that case, I really don't know.
When I encountered this it was during a cold snap. The wiper worked fine after the temps rose.
PIAA Headlamp Bulbs
LED Plate Bulbs
Valor Exhaust Tip
Dbl Decker Cargo
Pwr Moon Roof
Garmin GPS
Rear Spoiler
265/65R17
Old 01-11-2009, 12:12 AM #7
Canuckcarguy Canuckcarguy is offline
Canuckcarguy is an unknown quantity at this point
You might want to try lubing the hinge on the wiper. The back window area gets pretty gritty, so that hinge will stop being as efficient as the vehicle sees more miles.
Canuckcarguy is offline   Reply With QuoteReply With Quote
Old 05-08-2013, 08:58 PM #8
DanLuo4Runner DanLuo4Runner is offline
DanLuo4Runner is on a distinguished road
I've wrestled with this problem for some time now. I've replaced the blade, spring, wiper arm(completely), and no change. The wiper blade barely touched the glass. Otherwise, it worked fine. The only solution is this. You need to remove the arm assembly from the splined motor shaft, then remove the wiper blade. Take the Spring out and separate the short mounting part from the longer arm section. The secret is to shave about 1/4" off the end of the large arm stop that makes contact with the short mounting part. The spring goes directly through this area. No more than 1/4", as that will decrease the angle that the arm takes to the window. Reinstall the spring, attach the short mounting part to the long arm section, mount wiper blade and return assembly to the splined motor shaft. You're done. End of problem forever. Enjoy................
Last edited by DanLuo4Runner; 05-09-2013 at 09:30 PM. Reason: decrease the angle not increase
DanLuo4Runner is offline   Reply With QuoteReply With Quote
Old 05-15-2013, 10:42 AM #9
stevec5000 stevec5000 is offline
stevec5000 is on a distinguished road
So how do you remove the arm assembly from the splined motor shaft?
stevec5000 is offline   Reply With QuoteReply With Quote
Old 05-15-2013, 11:20 AM #10
Stuck CAPS's Avatar
Stuck CAPS Stuck CAPS is offline
Real Name: Alex
Stuck CAPS is on a distinguished road
Stuck CAPS's Avatar
Real Name: Alex
Any ideas?
Check the little nub type deal covering the spring from the mechanical arm to the actual blade... mine broke, and this problem started.
2004 Toyota 4Runner SR5 PreRunner - A slow but steady build!
GOODϟYEAR Wrangler Silent Armors, K&N Air and Oil Filters, Borla PROXS Muffler, Mobil 1 Full Synthetic Oil, and a few other things
-Helpful DIY Videos
Stuck CAPS is offline   Reply With QuoteReply With Quote
Old 05-15-2013, 11:38 AM #11
2big4arunner 2big4arunner is offline
2big4arunner is on a distinguished road
I have been looking at making a new arm to replace this plastic older arm. Something you can get from the auto wreckers. The closest one I found was for a windstar and it would need a little tweaking for the more adventuresome types. I will try to post my solution here in a week or so.
2big4arunner is offline   Reply With QuoteReply With Quote
Old 05-15-2013, 06:14 PM #12
I had to use a puller to get the arm off then trimmed a little off where it contacts the mounting part but that didn't help and it still won't wipe the glass at the top of the window. I don't think the spring is strong enough to pull it against the glass hard enough to make contact with the entire surface.
Old 05-16-2013, 10:26 PM #13
use a small pulley to grab the arm and pull off the shaft then use the instructions above to really correct the problem. I have pictures of the parts if you're not sure what area of the arm to shave. Good luck.
Old 05-16-2013, 11:27 PM #14
iBison iBison is offline
Real Name: photoshop god
iBison is on a distinguished road
If you're me and it's last night you first try pulling it off, then you get a puller which does nothing other than start to damage the threads. Then you get out the channel locks and break the plastic part off of the aluminum center part that mounts on the motor shaft. After that you get out the dremel and make a cut in the top and bottom of the center metal piece. But not until you make a hole in a piece of cardboard and put it over the shaft so you don't scratch the paint. Then break the piece by twisting a screwdriver in the slots you cut in the metal center piece. Don't forget the swearing as well.
.: READ IT! :.
Pre-Purchase Info, Modifications, Write-Ups, Quick Links, and FAQ's
Tons of info on 4th gens for new and prospective buyers with links to the best topics.
iBison is offline   Reply With QuoteReply With Quote
Old 05-17-2013, 03:09 AM #15
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Can you guys post some pictures? I don't understand what is so difficult about getting the arm off? Maybe in saltier areas it corrodes the material a bit, but I have not had any issues with either wiggling or rocking the wiper arm some after taking the nut off (careful not to bend the motor shaft!) Also, do yourself a favor and trim the tab off the plastic cap so you can pull the wiper away from the window without braking the polymer arm when changing the rear blade.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Dynamic Rear Proportioning (aka EBD) Thai 4th Gen T4Rs 1 06-20-2011 09:24 PM
Rear Window 1988 4Runner no longer functioning Toyota_4Runner Classic T4Rs 4 07-27-2010 10:22 PM
new guy here...need rear hatch help!! rungolden11 4th Gen T4Rs 2 07-26-2010 08:13 PM
Lost Rear window defrost, wiper.... Sniggle Maintenance/Detailing 9 05-05-2010 09:37 PM
'05 4runner sport - rear window wiper skip Problems & Warranty Issues 6 09-24-2005 10:36 PM
