07-09-2013, 12:04 PM
Real Name: Ryan
Real Name: Ryan
Wiring Angel Eyes / Halo Lights
So I have some Morimoto xbALed Angel Eyes on order from The Retrofit Source, I took advantage of their 4th of July sale.
They offer a corner/marker light harness. but since our 4Runners use the DRL's as turn signals I don't think I can use this harness since it will make my Angel Eyes blink like a turn signal which isn't really what I'm going for.
that's correct right? is there a way to tap into the DRL and not have the angel eyes blink but only the amber bulb blinks.
any tips, advice or suggestions are welcome.
I'm thinking the best solution is to just wire them up to the ignition with a switch somewhere and then wither manually disable the DRL on the amber bulb or get Toyota to disable DRL with their scantool.
2007 Toyota 4Runner Limited V8 4x4
|Goodyear Duratrac 275/65R18|Daystar 2.5F RAS Adjusted Rear|1.25" Spidertrax|BM Chop|WeatherTech Floor Liners|28% Tint|LED Interior/Exterior Swap|4300k HID's|"Black Series" Projector Lenses|Jet Yellow Fogs|Pioneer AVH-P8400BH|Airaid Synthamax|HCF Delete|
07-09-2013, 12:32 PM
Moderator
Real Name: Zak
Moderator
Real Name: Zak
Are there three wires running to the DRL? One + constant, one -, and one from a flasher relay?
07-09-2013, 12:48 PM
Real Name: Ryan
Real Name: Ryan
Just went to look and there is a white wire with a black stripe and a red wire going into the back of the bulb.
07-09-2013, 12:49 PM
Moderator
Real Name: Zak
Moderator
Real Name: Zak
I always assumed there would be three. Try cutting each one and seeing what happens.
Not sure how the reverse polarity works with the turn signals too. Maybe be - that is switched. Try tracing the wires to a flasher relay too? then you could tap in before it
07-09-2013, 01:43 PM
Real Name: Ryan
Real Name: Ryan
Yeah, I'll have to take a closer look once I have the headlights out, I might just keep it simple and wire them to the ignition then just disable the DRL function.
07-09-2013, 02:12 PM
Real Name: Chris
Real Name: Chris
The DRL's are dual filament so they're tied to a relay, I would try and tap off either the headlight or foglight, or just run off the ignition like you mentioned in your original post
07-09-2013, 02:44 PM
Moderator
Real Name: Zak
Moderator
Real Name: Zak
I have my halos wired to the parking lights fwiw.
07-09-2013, 02:50 PM
Real Name: Ryan
Real Name: Ryan
So I've heard a bunch of names for lights.
in the factory headlight housing, there is the low beam, high beam, and signal/DRL bulb in the upper corner, is there one more in there?
which lights are the "parking lights"? if tapping into the parking lights do the halos just turn on with the ignition?
07-09-2013, 06:21 PM
There are markers, they are under the dtrl/signal . they are on when the headlights are on or if you just turn on the markers
Budget Build,5100's with tacoma/fj coils, CBI Offroad Front mount hitch, MY MAP LIGHT MOD How to: A/C in console
09 limited Titanium Metallic ,stock, color matched emblems, LED interior lights, winjet fog lights, LED foot well lights,HCF mod, fumoto f-103 oil valve, anytime backup-camera mod.
07-09-2013, 06:25 PM
Moderator
Real Name: Zak
Moderator
Real Name: Zak
ya this
headlight switch goes "off" "parking" "on" "auto"
07-09-2013, 08:48 PM
Real Name: Leonard
Real Name: Leonard
The running light and signals are 2 different bulbs.
You can tap into the running light setup and pull the bulb out and it will work the same with out having the light on and can return it to factory later.
Did this so I only had running light on my SW bumper.
Having fun's build
07-10-2013, 10:11 AM
i think havinf fun said it all.....i ordered the blacked out halos projector drop in kit....i intend to wire the halos the way the poster above described..
remove the drl bulbs/cut off power going to them...and then feed the angel eyes with the cable/power from the drls.....should be a piece of cake...the real pita would be removing the headlights assy!!!
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto...... sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
07-10-2013, 10:38 AM
Moderator
Real Name: Zak
Moderator
Real Name: Zak
Reach through the fender liner for the tricky bolt, it makes it really easy.
10-15-2013, 08:40 AM
how did you finally resolve this issue..my drop in kit has arrived, i now understand the issue you had then..the drls act as turning signals in my 05...so cutting off power to them isnt an option as i would be left without a turn signal!
10-15-2013, 09:34 AM
Moderator
Real Name: Zak
Moderator
Real Name: Zak
I wired mine to the parking lights on my 03
