Old 10-16-2019, 10:43 AM #1
4rociousrunner's Avatar
4rociousrunner 4rociousrunner is offline
4rociousrunner is on a distinguished road
Body roll and bounciness after installing new rear shocks
So recently (about a week or so ago), I replaced the 2003 oem rear shocks on my 4runner with a pair of 2011 Tacoma TRD Bilstein 4600s. They felt pretty dang good for the first couple of days and they are not showing any signs of leakage, however there is definitely an imbalance between the rear and the front, which still has factory-spec coilovers. The truck has slight body roll around tighter turns and the front feels much stiffer than the rear (I can feel almost every little bump through the steering wheel, which also vibrates often.). It's in need of an alignment, camber and toe in / toe out adjustment as well, but I was curious as to which shock would be best for making the front end softer, like the rear? Currently debating between a 5100 or a 4600, like the rears.
_________________________________________________
2003 4Runner SR5
32" Falken Wildpeak AT3/W
1.25" Spidertrax spacers
1.5" Daystar Leveling Kit
Bilstein 4600 Rear Shocks
4rociousrunner is offline   Reply With QuoteReply With Quote
Old 10-16-2019, 10:07 PM #2
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Are your front shocks the originals, and did you replace the rear springs?
FWIW, my fronts are 4600s off a ‘15 Tacoma TRD Offroad and the ride & handling are superb. The 5100 is essentially the same shock (IMO, others disagreej except it’s designed to allow height adjustment.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 10-17-2019, 10:52 AM #3
Front shocks were recently replaced at a dealer with factory specification shocks (lets be real though, oem SR5 shocks are complete crap); rear shocks are off of a 2011 TRD Tacoma and the rear springs are still stock so i'm thinking they might be a little worn out. I would prefer height adjustability however I will go with 4600s if it means a more balanced ride quality....atm the front feels like a brick and the rear feels soft.
Old 10-17-2019, 04:55 PM #4
Bluesky 07's Avatar
Bluesky 07's Avatar
The ride should be similar up front whether you choose 5100s or 4600s - in other words either should be fine. Since many 4th Gen owners run Bilsteins, maybe you can trade a 6-pack for a ride with someone who has ‘em up front just to get a sense of how they ride. I’ve had mine since last December and couldn’t be happier on or off the pavement. There are videos in my build thread, check out the 2019 Kentucky Toyota Trail Ride for example to see where 4600s will take you.
Old 10-17-2019, 05:05 PM #5
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
I'd match 'em up with 4600s in front.
Sounds like the dampening is different between the brands.
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 10-17-2019, 09:59 PM #6
4RunnerMexico 4RunnerMexico is offline
4RunnerMexico is on a distinguished road
Tacoma shocks are valved to soft for our trucks.....
Get 4600s / 5100s for a 4Runner
4RunnerMexico is offline   Reply With QuoteReply With Quote
Old 10-17-2019, 10:09 PM #7
Bluesky 07's Avatar
Bluesky 07's Avatar
Here we go again. Sigh...
Seriously, based on what? Somebody else said that too but nobody has any facts on how they’re different. What I & numerous others who have done the swap have is lots of actual experience on road and off that says Taco Billies give a great ride on a 4Runner.
Old 10-17-2019, 10:54 PM #8
Sure they’re soft but not a bad kind of soft. The 5100s and 4600s are valved the same AND 4Runners are built on a Tacoma-based chassis. I don’t see how there’s a difference between the two...if anything the Tacoma’s shocks should be fine since they are supporting a truck bed.
Old 10-17-2019, 10:58 PM #9
They ride nicely, it’s just a matter of how much weight the truck is carrying. Softer shocks tend to handle better under a heavier load. I agree though; Tacoma Bilsteins and 4Runner bilsteins are virtually the same other than having to retrofit the former.
Old 10-17-2019, 11:01 PM #10
Yeah I probably will....the front sags a little though....rear has about an inch more lift than the front so I’m kinda drawn towards the height adjustable 5100s too.
Old 10-18-2019, 10:57 AM #11
look into poly sway bar bushings to help with body roll.
bilstein , body , front , rear , shocks
'97 4R problem installing Bilstein rear shocks DUK-RNR 3rd gen T4Rs 4 05-26-2016 08:12 PM
bad rear body roll obxfunrunner 3rd gen T4Rs 10 06-21-2013 03:06 AM
installing rear shocks marcel 3rd gen T4Rs 17 11-15-2012 12:23 PM
KDSS - Less Body Roll westwind77 5th gen T4Rs 6 12-18-2011 11:48 AM
