Old 10-18-2019, 01:38 AM #1
4rociousrunner's Avatar
4rociousrunner 4rociousrunner is offline
4rociousrunner is on a distinguished road
Loose steering while trail riding
So....as of late, my steering has been rather loose when hitting the trails....to the point where hitting a small rock at crawling/ trail riding speed causes the vehicle to jerk one way or another. On the road it is ok for the most part, though divots and imperfections in the road seems to make the steering wheel jerk one way or the other. I don't wish for it to be as tight as a sports car, though it is to the point where it has become so vague that I can visibly notice a misalignment before feeling it through the steering wheel. Is it a bad shock bushing? Bad steering rack? Ball joints going out? Tie rods?
*The power steering pump does have a minor leak, though the vague steering has been going on for quite some time before this issue.
2003 4Runner SR5 // Galactic Grey Mica
32" Falken Wildpeak AT3/W // 1.25" Spidertrax Spacers // 1.5" Daystar Leveling Kit // 2010 Tacoma TRD Bilstein 4600 Shocks
48" Hi Lift Jack // Yakima-style Roof Basket
4rociousrunner is offline   Reply With QuoteReply With Quote
Old 10-18-2019, 10:51 AM #2
4gambler
Guest
Posts: n/a
4gambler
Guest
Posts: n/a
Do this 1st:
Install NEW POLYURETHANE STEERING RACK BUSHINGS AND get toe checked out adjusted after install. Test drive and take it from there.
Also check all ball joints for movement using pry bar under tire and jack stands on frame.
Old 10-18-2019, 10:54 AM #3
4gambler
Guest
Posts: n/a
4gambler
Guest
Posts: n/a
Forgot. Also check tie rod ends for wear. Steer back and forth with a TRUSTY helper and watch tie rod end for movement 4runner on floor not jacked up. You will also confirm and see rack move if oem bushings are shot.
Old 10-18-2019, 11:13 AM #4
Billynath1988's Avatar
Billynath1988 Billynath1988 is offline
Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about
Originally Posted by 4gambler View Post
Do this 1st:
Link to bushings or part numbers for the rack? Any how to write ups on doing this?
2005 4Runner SE V8
http://www.toyota-4runner.org/4th-ge...-v8-build.html
Billynath1988 is offline   Reply With QuoteReply With Quote
Old 10-18-2019, 11:29 AM #5
Hunter.Cribb's Avatar
Hunter.Cribb Hunter.Cribb is offline
Real Name: Hunter
Hunter.Cribb is on a distinguished road
Real Name: Hunter
Mine is the same way off road. Very hard to maintain control because the steering wheel vigorously jerks back and forth.
2006 Limited V6 4WD, Natural White (Sold)
2006 Limited V8 4WD, Salsa Red Pearl
Hunter.Cribb is offline   Reply With QuoteReply With Quote
Old 10-18-2019, 11:42 AM #6
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
That certainly is my preference.
Old 10-18-2019, 12:41 PM #7
Inv4drZm's Avatar
Inv4drZm Inv4drZm is online now
Inv4drZm's Avatar
Some of it has to do with tire pressure, some of it is just normal for rock-crawling, it requires a good grip on the steering wheel at times.
But maybe in your case its a significant amount?
Inv4drZm is online now   Reply With QuoteReply With Quote
Old 10-18-2019, 01:55 PM #8
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
There is a difference between steering wheel "play" and it just jolting back and forth from offroading. Does your steering wheel have any "play" when on highway or other roads??
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 10-18-2019, 02:47 PM #9
4gambler
Guest
Posts: n/a
4gambler
Guest
Posts: n/a
There will always be play. Question is how much is too much.
Old 10-18-2019, 07:30 PM #10
On the road it's fine for the most part...minor bumps and divots sometimes cause the steering wheel to do a little shimmy but its not uncontrollable. Speed tables also cause the steering wheel to turn one way or another. /it just feels way too loose. Off-road its gotten so bad that even gravel roads cause the wheel to do a shimmy....I recently installed 4600s in the rear so I expected a dampening imbalance until the 5100s are installed in the front, but not for it to struggle on a forest service road of all things.
Old 10-18-2019, 07:36 PM #11
I mean, i'm only running 32s at this point and no beadlocks, so the lowest i ever dare to go on the Falkens is around 24 PSI on the trails. That being said, I DON'T do any rock crawling at this point since I'm only on 4600s and 1.5" of lift; I can't afford a fully fledged build at this point being a college student . The rattling in the steering wheel is awful even at a low psi on something as simple as a forest service road.
Old 10-19-2019, 08:20 AM #12
Real Name: Michael
Real Name: Michael
Are those e rated tires? If so you’ll need to go down more. 24 is not low enough imo to do any good. I always go alittle above 15. You won’t have to worry about blowing a bead. Especially if you aren’t rock crawling
Old 11-18-2020, 01:58 AM #13
CaseyMacD CaseyMacD is offline
CaseyMacD is on a distinguished road
I'm having the same problem with my 2008. Bumps and trails seem to influence the steering wheel much more than they used to but at the same time the steering feels vague and sloppy...
Did you ever figure out the cause/find a fix for it?
CaseyMacD is offline   Reply With QuoteReply With Quote
jerk , loose , road , steering , wheel
replacing intermediate steering column U joint - loose steering jrm 4th Gen T4Rs 4 09-15-2017 05:28 PM
trail riding in va 2003 va runner ltd Maryland / Virginia / WV / D.C. 16 08-10-2012 08:29 PM
1st time trail riding mireland4390 4th Gen T4Rs 4 06-11-2011 02:18 PM
Little autumn trail riding quicksilvr 3rd gen T4Rs 3 10-23-2010 07:35 PM
Some trail riding pics ShipOfFools 4th Gen T4Rs 1 07-13-2009 07:32 PM
