Old 10-18-2019, 06:55 PM #16
djpope09 djpope09 is offline
djpope09 will become famous soon enough
Originally Posted by firebirdguy View Post
interstates are not very good & way overpriced... ive had 2 of them die in 5 years or less, not driven much & kept in climate controlled garages during peak of summer & all winter. i keep my batteries charged & do a few discharge cycles as well.
ive got close to 10 years on an autozone gold brand battery & 11+ years on an oreilys brand battery & its still going strong! all used in the same circumstances on 3 classic cars i own.
your treatment of the battery may not be helping & high heat or super cold when not kept fully charged will shorten the life a lot. buy a real battery charger & charge it for a few hours if it sits for more than a few weeks, & if you listen to teh radio for a long time charge it up afterwards. or buy a tender if it sits for a month or 2. driving it will charge the battery too. & if its not a maintenance free type, check the water level periodically & top off with distilled water.
ive heard of OEM toyota batteries lasting 10+ years... adjust your battery care procedure & you should be able to get a lot more than 5 years out of a battery.
I can't speak to the longevity of Interstate batteries as I've only had mine for a year or so. But I got mine at Costco for about $40-$50 less than any other price I could find. So I don't know about good, but they aren't overpriced if you get them at Costco.
djpope09 is offline   Reply With QuoteReply With Quote
Old 10-18-2019, 07:00 PM #17
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
The older Costco Interstate used to be a 5 year prorate warranty battery and they switched to a 3 year and dropped the price. It’s not as good, but again, the price is in line with what it is. They also handle issues and warranty related claims VERY well.
Walmart – EverStart Maxx Yellow is a 5 year Johnson Controls battery. Its available at a lot of other places as well, I just don’t care to research it. Again, price is right, and it’s a good battery as well.
Most all places sell various grades of battery… I usually go by the prorated warranty duration. The ones with longer warranties are physically built better and tend to last longer.
The only advise I can give is don’t go out of your way to spend on a premium battery ($200-500) unless you know why you are buying it and for what application. If you just need something to start your car, it REALLY doesn’t matter that much. Shop at a vendor you like, and based on the warranty duration as that is generally a good enough indicator.
Old 10-18-2019, 07:42 PM #18
4gambler
Guest
Posts: n/a
4gambler
Guest
Posts: n/a
You are paying for warranty or pre paying your next battery.
Old 10-18-2019, 08:13 PM #19
Bumbo's Avatar
Bumbo's Avatar
Interesting... I never considered looking at it that way… I guess that is a valid risk/reward tactic for a manufacture.
I do believe that all batteries are NOT equal in quality and physical construction, but I also believe there is a limit to what you get in a standard battery. I guess its really up to the end user to decide or validate if what they are buying is any different than the cheaper option.
I have found less problems or longer service life from batteries that typically had longer warranty durations. That said, it was the bottom dollar lowest grade batteries that were usually the absolute worst.
Old 10-18-2019, 10:49 PM #20
0verland's Avatar
0verland 0verland is offline
0verland will become famous soon enough 0verland will become famous soon enough
0verland's Avatar
Interstate. Get it at.costco.
+1
2006 V8 Limited 4WD
| Doug Thorley Headers | Gibson | Old Man Emu | ToyTec | SPC Performance | RCI Metalworks |
| Skid Mark 4x4 | SpiderTrax | BFGoodrich KO2 | aFe | Rutech | HCF Mod |
0verland is offline   Reply With QuoteReply With Quote
Old 10-19-2019, 01:32 PM #21
mastee mastee is offline
mastee is on a distinguished road
My recently acquired 04 came with duralast gold, it died while listening to music on low volume for an hour or so, I do have jbl synthesis though. I have not had any troubles starting the truck, not sure if I'l need one soon or if it was user error?
On a side note, can you guys advise on following? Craigslist has a interstate mt-65 listed for $50, mfg date June 2018, the guy stated that it's a backup and it's been on a trickle charger for the last 6 months, consider it or pass?
mastee is offline   Reply With QuoteReply With Quote
Old 10-19-2019, 04:50 PM #22
radlynx radlynx is offline
Registered User
radlynx will become famous soon enough
Registered User
I start my car a few times a day and has a commute time of 6 miles. That's not enough to fully charge the battery. So what I do is recharge it every 3 months or so. I have an exide agm. 24f size.
radlynx is offline   Reply With QuoteReply With Quote
Old 10-19-2019, 06:54 PM #23
Ralph Blake Ralph Blake is offline
Ralph Blake is on a distinguished road
I found buy the best battery at Walmart around $90 US is the best choice for my needs, have a problem Walmart's are everywhere.
Ralph Blake is offline   Reply With QuoteReply With Quote
Old 10-20-2019, 08:35 AM #24
inscarguy's Avatar
inscarguy inscarguy is offline
Real Name: brian
inscarguy has a spectacular aura about inscarguy has a spectacular aura about
inscarguy's Avatar
Real Name: brian
For What its worth I have had good luck with toyota true start batteries. The first one lasted 7 years and the second one is going on 8 years.
Of thats not affordable then go to walmart. They have a 3 year unconditional return and a 5 year warranty. Costco is only as good if you have a membership which costs 50.00 or 60.00. So if you dont have a membership and you sign up for one that 90.00 battery just became 140.00.
There are alot more Wal-Mart's out there than costco( I do love Costco though).
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
inscarguy is offline   Reply With QuoteReply With Quote
Old 10-20-2019, 05:02 PM #25
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
A six mile commute is plenty of time to charge your battery after an engine start. A start draws maybe 300 amps for 2 seconds if everything is healthy. That's .167 ampere-hours of draw on the battery. Assuming your commute takes 10 minutes, the alternator only has to supply 1 amp for that time to replenish the battery.
I have a 5 mile commute, and have never had battery issues because of it. I'll venture that 5 mile or less trips are the norm for a great number of people who don't even know what a battery charger is, and who get along just fine.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 10-21-2019, 02:08 PM #26
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
same here but i havent had to jump mine in the year ihave owned it. i should probably test and charge it because same situation here.
hinmo24t is offline   Reply With QuoteReply With Quote
Old 10-21-2019, 02:10 PM #27
Bumbo's Avatar
Bumbo's Avatar
Starting a car does very little to actually deplete a battery… it’s just a large load for an brief moment. Charges back up pretty fast.
The real problem is when your battery can’t deliver the cranking amps required to start.
Old 10-21-2019, 04:59 PM #28
BR06run BR06run is offline
Real Name: Bill R.
BR06run is on a distinguished road
Real Name: Bill R.
Walmart ones work good for me. Have used some from Advanced Auto when Walmart didn't have a particular one. Walmart usually has the best price but when I have to buy from Advanced I search for discount coupons. Without the discount coupons you pay a lot more.
BR06run is offline   Reply With QuoteReply With Quote
Old 10-21-2019, 06:34 PM #29
CelticRunner's Avatar
CelticRunner CelticRunner is offline
CelticRunner is on a distinguished road
Yeah, I think I’m going with Walmart. I never considered that they are everywhere.
06 SR5, 190k miles (just breaking it in)
CelticRunner is offline   Reply With QuoteReply With Quote
Old 10-22-2019, 01:35 PM #30
Registered User
Registered User
That's good to know. Thank you. I guess that's probably why my original Panasonic battery lasted 8 years.
battery , car , care , day , don’t
Exact battery cable lengths for OME replacement with OEM battery oriented posts. Majindan 3rd gen T4Rs 3 11-20-2017 02:57 PM
Battery questions. What size wire for battery? 2 gauge enough? e60ral 5th gen T4Rs 9 03-12-2017 12:29 PM
Anyone using the $26 Summit Racing SUM-G1201 battery tray for 31M battery? jicko 5th gen T4Rs 3 04-27-2015 12:24 PM
Multi Battery Isolator and Dual Battery Selector, $60 - Pocatello, ID tjhaf2007 For Sale: Non-T4R Items 17 10-16-2013 11:00 PM
SS006-07 08/11/2007 Battery - Absorbed Glass Mat Battery (AGM) Information CBR_GUY_IA TSB 0 07-12-2009 09:30 PM
