Old 10-18-2019, 12:13 PM #1
KBToys KBToys is offline
KBToys is on a distinguished road
Roaring sound
07 4runner with 113k is making a roaring sound, kind of like the sound of driving with some aggressive mud tires. I currently have hankook dynopro atm less than a year old so i thought maybe it was just the tires but when i put on my old set of cooper ht's i am still getting the same noise. Wondering if something else is going on. Noise varies by speed and doesn't matter if accelerating or braking
KBToys is offline   Reply With QuoteReply With Quote
Old 10-18-2019, 12:17 PM #2
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
Sounds like very typical noise that you get from bad wheel bearings. I would put the truck on jack stands and rotate the wheels by hand to see if you have any bad ones.
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 10-18-2019, 10:13 PM #3
metramm metramm is offline
metramm will become famous soon enough
I second this about the wheel bearings. I had the roaring noise that would go away when turning left (if I'm remembering correctly).
Pulled the front tires off and the passenger side wheel bearing was toast.
Ended up changing both out at the same time just for good measure. Easy bolt on assemblies. Took 45 minutes each side.
I got mine from NJ bearings (forgot his username). Toyo bearings made in Japan. Good stuff.
Let us know if this turns out to be your problem as well or something different.
Metramm
2006 4Runner Limited 4x4 v6
241,000 miles and counting!
metramm is offline   Reply With QuoteReply With Quote
Old 10-19-2019, 02:55 PM #4
chaz's Avatar
chaz chaz is offline
chaz will become famous soon enough
chaz's Avatar
where is the sound coming from? if it seems like the rear it may also be the pinion bearing. just replaced one in my 06.
chaz is offline   Reply With QuoteReply With Quote
Old 10-23-2019, 07:44 PM #5
Couldn't really tell where the sound is coming from. Maybe the front. Also tried the hard turn left and right but roaring sound didn't go away
Old 10-24-2019, 04:12 PM #6
Burt Burt is offline
Burt is on a distinguished road
If noise seems to follow engine RPM, then could be fan clutch.
Burt
2008 SR5 V6 4WD
1984 1/2 GT350 Mustang
2019 F250 SuperDuty
Burt is offline   Reply With QuoteReply With Quote
noise , roaring , set , sound , tires
Roaring sound. Tenn_volsfan56 3rd gen T4Rs 9 10-02-2011 11:34 AM
Roaring sound from back of 4 runner Alexat1974 Problems & Warranty Issues 1 06-27-2011 11:34 PM
Roaring Runner- Help!! cbdooley 4th Gen T4Rs 1 05-05-2011 03:16 PM
Rear Driveshaft Roaring ujdmc 3rd gen T4Rs 1 12-14-2010 09:46 PM
Roaring Noise from fan on 95 4R DrAnonymous Classic T4Rs 2 06-10-2007 06:07 PM
