Old 10-20-2019, 11:14 AM #1
lj4r lj4r is offline
lj4r is on a distinguished road
brake pedal require a heavy foot
I just replaced all four rotors. new pads (all oem parts) all around and completely swapped out all of the old brake fluid. applying the brakes in sudden stopping situations requires a very heavy foot. even then stopping quickly is a bit scary. all calipers are working properly. what are the next itms to check. 2003 sr5 4wd 180k miles. thanks.we have two other 4runners a 2003 and a 2004.. brakes on those vehicles are much more responsive. Phil
lj4r is offline   Reply With QuoteReply With Quote
Old 10-20-2019, 12:09 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Could be one of several things causing this or a combination of all of them, sticking calipers, brake booster electric motor/pump/accumulator issues and deteriorated rubber brake lines.
If the calipers are sticking slightly it can cause you to use more force to achieve proper braking.
If there an issue with the brake booster not building up pressure, holding proper pressure, etc. you will have to use more force in braking.
If the OEM rubber brake lines have deteriorated to the point that it has dislodged bits of rubber or swelling inside the line it can cause heavy footed braking issues as well.
I would start checking to make sure the calipers pistons are moving freely(you may have already done this when doing the brakes), then move to replacing the brake lines (if they're all original from 2003 I would replace no matter what else you find is wrong)
and if you still have the braking issue go to the brake booster.
2004 Limited V8
Old 10-20-2019, 12:45 PM #3
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
There could definitely still be a bubble somewhere in the lines, not hard to do with these systems. If you have fresh hardware, everything is clean and moving surfaces are lubed, and if your calipers aren't sticking...tough to not blame something electric or mechanical, but then you did flush the lines, so I would double check that before condemning parts.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 10-20-2019, 05:00 PM #4
weaves weaves is offline
weaves is on a distinguished road
Stupid question, but were your rotors zinc coated or bare metal? If the latter, did you make sure to clean off the protective oily film?
If the brake pedal is very firm or difficult to depress, I would lean towards a brake booster issue. Soft/spongy would indicate a hydraulic issue/air in the lines.
weaves is offline   Reply With QuoteReply With Quote
Old 10-22-2019, 03:12 PM #5
radlynx radlynx is offline
Registered User
radlynx will become famous soon enough
Registered User
I would say the brake booster is not giving enough pressure.
radlynx is offline   Reply With QuoteReply With Quote
brake , brakes , foot , heavy , stopping
Squeaky foot parking brake and odd rattle Mike318 5th gen T4Rs 3 02-01-2018 02:13 PM
Car moved while my foot was on the brake myzaa 3rd gen T4Rs 4 06-03-2014 08:39 PM
Sticking my foot out the door works better than my E-brake. Christiantdoug 3rd gen T4Rs 31 04-04-2013 08:38 PM
Jerk when you take your foot off the brake ziishan Problems & Warranty Issues 1 04-14-2008 06:18 PM
