PB blaster or Penetrating WD-40 (silver and yellow bottle)
Then work it with a regular socket wrench combo, dont use power tools, and you will be able to get the acorn nut out, when you install your new grille, find some stainless steel nuts from McFadden if there is one around you or order online.
Originally Posted by fulltimervexplorer
Also if I was to get a new grill how would I even go about removing the old one? The nuts dont look very easy to cut off? I assume the new grills comes with new hardware? Most of the ones I've seen also dont have the emblem with them.
