Old 10-22-2019, 04:51 PM #1
fulltimervexplorer's Avatar
fulltimervexplorer fulltimervexplorer is offline
Real Name: Justin Doggett
fulltimervexplorer is on a distinguished road
Help removing front grill before I break it.
So as I've read these acorn nuts can be a pita. Im a victim of breaking atleast 2 currently trying to remove the grill. I see no easy way to remove these as even the ones near the corners are spinning and I can even see the square back on those. Any help is appreciated otherwise I'm going to just re paint the grill with dip while on the car.
2008 Toyota 4Runner 4.7l V8, Toytec 3 inch lift, 285-70-17 KO2s plus alot more i dont wanna write out.
fulltimervexplorer is offline   Reply With QuoteReply With Quote
Old 10-22-2019, 04:53 PM #2
Also if I was to get a new grill how would I even go about removing the old one? The nuts dont look very easy to cut off? I assume the new grills comes with new hardware? Most of the ones I've seen also dont have the emblem with them.
Old 10-22-2019, 06:22 PM #3
SR502JAI SR502JAI is offline
SR502JAI is on a distinguished road
PB blaster or Penetrating WD-40 (silver and yellow bottle)
Then work it with a regular socket wrench combo, dont use power tools, and you will be able to get the acorn nut out, when you install your new grille, find some stainless steel nuts from McFadden if there is one around you or order online.
SR502JAI is offline   Reply With QuoteReply With Quote
Old 10-22-2019, 07:13 PM #4
Looks like I'm causing more bad then good. I now have 2 broken clips and one broken nut that sheared off and it's not looking good on saving and reusing this grill if I get it out.
Old 10-22-2019, 07:50 PM #5
if you are handy with as soldering iron, you can plastic weld the clips back. I did that with my grille when i got my 4Runner, and 4 months in i have not had an issue with them braking again, you can also jbweld the back on if all the pieces are still there
Old 10-22-2019, 09:21 PM #6
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Yes -these were a pita. I replaced my grill with a flat mesh/ satoshi look. I was able to get about half of these off. The other ones I had to fight with as they were rusted and stripped. I drilled, cut etc. to finally get it all off and now my grill is held on by half the previous number of nuts, but it works
Old 10-22-2019, 10:55 PM #7
LT1coupe's Avatar
LT1coupe LT1coupe is offline
LT1coupe will become famous soon enough
LT1coupe's Avatar
It's worth it
Help removing front grill before I break it.-thumbnail_20190902_180421-jpg
2006 V8 Sport 4wd conversion, ADD front axle, FJ twin stick transfer case, premium long tubes, truetrac ,5100's, FJ springs
LT1coupe is offline   Reply With QuoteReply With Quote
Old 10-23-2019, 02:02 PM #8
blackjackck's Avatar
blackjackck blackjackck is offline
Real Name: John
blackjackck will become famous soon enough
Real Name: John
I broke the 2 clips on the top middle but the sides were good so I figure It'll do. If I need to get a new grille, I'll pick up some via aftermarket on ebay.
2008 V6 4x4 Sports Edition / Build Thread/ FJ Off Road Package, 265/70/17, 2012 FJ Wheels, Husky Liner, LED bulbs, Spare Bumper -current////// SOLD Past vehicles:1996 V8 Landcruiser Rebuilt; 1988 Jeep Wrangler- 2 inch lift with 33' tires; 1976 Jeep CJ 7 (inline 6) - Frame off restoration
blackjackck is offline   Reply With QuoteReply With Quote
Old 10-23-2019, 05:13 PM #9
Seasparrow Seasparrow is offline
Seasparrow will become famous soon enough
Good youtube video for it.
YouTube
NATO Seasparrow Mk 57 Mod 2 & 3
2004 4th Gen Sport Edition
Seasparrow is offline   Reply With QuoteReply With Quote
back , grill , remove , spinning , square
Has anyone replaced their radiator WITHOUT removing their front grill??? dms1 3rd gen T4Rs 27 06-12-2017 07:38 PM
Front Grill piece broken, Toyota said they no longer sell color matched grill hgill 4th Gen T4Rs 16 09-12-2016 07:08 PM
Does Removing the Lower Grill Insert Require Removing the Bumper? Bluesky 07 4th Gen T4Rs 5 06-03-2016 07:24 AM
removing grill marcel 3rd gen T4Rs 12 10-07-2010 12:30 PM
removing my grill imryannn 3rd gen T4Rs 3 02-02-2009 04:14 PM
