Old 10-22-2019, 08:41 PM #1
weaves weaves is offline
weaves is on a distinguished road
2UZ-FE V8 Bolt Identification
I just replaced the head gaskets and timing belt on my V8 this past weekend but I ended up with two M10 bolts that don't have a home. I was pretty meticulous about labeling all the bolts but I kept some of the bolts with their parts which got moved/bumped around and a few times in my garage.
Anyone recognize these bolts? They're M10-1.25 x 40mm with a 14mm head.
weaves is offline   Reply With QuoteReply With Quote
Old 10-22-2019, 09:28 PM #2
4RunnerMexico 4RunnerMexico is offline
4RunnerMexico is on a distinguished road
Did my timing belt two weeks ago...
Those are 10mm, there's not a lot of 10's, mostly all the super important stuff are 12's and up.
You missing bolts on the timing cover?
4RunnerMexico is offline   Reply With QuoteReply With Quote
Old 10-22-2019, 09:36 PM #3
These are quite a bit bigger than the bolts for the timing covers. Those are 6mm bolts with a 10mm head. These are 10mm bolts (diameter of threaded section) with a 14mm head/wrench size.
Old 10-23-2019, 10:39 AM #4
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
There is a really good set of videos on the OTRAMM (sp?) youtube channel about changing the t-belt on a 2uz in a land cruiser. You may want to refer back to that. If i remember correctly he goes over a lot of the bolt sizes
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 10-23-2019, 03:00 PM #5
Good idea, I didn't even think to look at that. I just watched it and couldn't find those specific bolts but I did noticed the power steering bracket that bolts onto the RH cylinder head has 14mm head bolts that could very well be it. I did remove that bracket when I disassembled the heads.
I took a picture shortly after I bolted the heads on and noticed I had one of those bolts partially threaded into that bracket. I don't know why I would have threaded that bolt in there since I already had the power steering bolts/nut labeled in a separate baggie which are longer than 40mm.
Old 10-26-2019, 10:20 PM #6
It was on the backside of the power steering bracket which was not visible looking from the front of the engine.
bolts , garage , moved/bumped , parts , times
Parts identification grousehunter 61 Classic T4Rs 3 12-16-2017 05:45 PM
Steelcraft Bull Bars - 2 Bolt vs 4 Bolt Versions 4runnator 4th Gen T4Rs 4 07-04-2017 11:07 AM
Part Identification Help hawaiianryan 5th gen T4Rs 0 07-25-2016 10:51 PM
Header identification 88yota Classic T4Rs 4 11-10-2014 01:23 PM
starter identification johnny c 3rd gen T4Rs 6 08-05-2009 10:23 PM
