Old 10-23-2019, 01:41 AM #1
pahaf91 pahaf91 is offline
pahaf91 is on a distinguished road
Anyone swap in a 5th gen 4.0 into the 4th gen 4Runner?
hey guys. Love this forum. I have a 2006 4Runner v6 4.0 with 202k on it. i dumped about 2k into this car on top of what i bought it for and i love it so far. I bought bilstien 5100. OME springs. Took care of all the maintenance. Got 5th gen trail rims on. Falken Wildpeaks AT3 285-70-R17.
I love this car, wife loves it, 2 of our dogs love it. And i really dont want to get rid of it.
Anyway, history of this car. 1st owner blew the head gasket at 140k, put some "stop leak" in it and drove it for another 10k. Then he changed the head gasket. At 170k the head gasket blew again so he sold it and new owner put a new engine in and drove it for 10k before the head gasket blew again. Changed it, 10k later, Blew head gasket again. i bought it at 190k, had a mechanic put in new head gaskets, resurface the heads, new water pump. i drove it for 10k.......blew a head gasket.
I really dont want to get rid of this 4runner. I love it. My mechanic is going to replace the head gasket for free this time but im afraid it will blow again.
Im thinking to swap in a 5th gen 4.0 next time. i can get one for about $2000 with 96k. Just curious if it will be a an easy swap. I can swap over all the accessories and the intake manifold and the injectors. wondering if there is something that needs to be modified.
pahaf91 is offline   Reply With QuoteReply With Quote
Old 10-23-2019, 06:45 AM #2
Mike07SE's Avatar
Mike07SE Mike07SE is offline
Mike07SE is on a distinguished road
Mike07SE's Avatar
Just guessing even though they are fundamentally the same, but I'm going to say no as there are going to be issues with sensors and hardware to cause a conflict. I know looking at the engine of my MY07 vs my MY19 that there are a lot of differences from an electronics and plumbing standpoint.
Bigger question is why the constant HG blow every ~10K miles? Also, is the replaced engine a pre-'06 motor? Just guessing as that may have something to do with it as early generation engines were prone. I think best best would be to find a late model 4th gen motor to swap as a best bet.
2007 4Runner Sport Edition V6 4X4 - Natural White - Perf: Doug Thorley Long Tube Headers | 4.56 Gears ARB Front / TrueTrac Rear Off Road: Fr: Bilstein 6112 w/1/2" Toytec Spacer / Rr: MT ICON Long Travel | JBA UCAs | VTX Rogue 17x8.5 -10 | GY Duratrac 285/70R17 | Rear Diff Breather Mod | 1" Toytec Body Lift | Custom Cut Axle Joints ICE: Auto Pumpkin 10.1" Android | 3.5" Tweeter Mod Exterior: Quad Bi-Xenon HID Retrofit
2019 4Runner Limited 4x4 - MGM - Hers. Mostly stock - for now.
Mike07SE is offline   Reply With QuoteReply With Quote
Old 10-23-2019, 04:45 PM #3
Toyojay's Avatar
Toyojay Toyojay is offline
Real Name: Jay
Toyojay is on a distinguished road
Toyojay's Avatar
Real Name: Jay
The 2010 has dual vvti, ECU is going to be different and there will be more connectors on the motor. 5th gens also use air injection and 4th's don't. The motor will physically bolt in, but it won't run without some computer work. Not worth the effort IMO, I'd find a low mileage 2008-2009 1GR
Toyota Parts Guy
2009 Sport Edition V6 4WD
285/70/17 KO2 - T.E Wheels - Dobinsons 3/2 coils & UCA - Custom lights - 5100's
Toyojay is offline   Reply With QuoteReply With Quote
Old 10-23-2019, 08:16 PM #4
benztech82's Avatar
benztech82 benztech82 is offline
benztech82 is on a distinguished road
benztech82's Avatar
If head gasket is keep on popping I say it's warped bottom end. Have your mechanic inspect it with a straight edge, filler gauges without head gasket in area where gasket is blowing.
Sent from my Redmi 4 using Tapatalk
benztech82 is offline   Reply With QuoteReply With Quote
Old 10-24-2019, 10:46 AM #5
That would make sense actually. Man, I really love this 4Runner, just sucking me dry lol. Getting expensive.
I will look to find another engine 2006-2009. The problem is that most of them have higher mileage already. Which should still be fine I guess
I have no idea what engine was swapped into this car when the 1st one blew
Old 10-24-2019, 11:06 AM #6
CarolinaLGRW CarolinaLGRW is offline
CarolinaLGRW is on a distinguished road
I blew my HG around 180k miles. I found a salvage 1GR from an '08 Tacoma w/ 93k and have since put about 95k on the salvage motor with no issues, HG or otherwise. I considered just replacing the HG but I knew it had overheated twice and my mechanic talked me into the salvage route.
Just my .02 but I wouldn't worry about an 06+ higher mileage 1GR. Maybe replace the water pump while its easily accessible as a precaution.
2006 SE 4wd w/ 270k mi
Wheeler's/Eibach T1 front and T12 rear | Bilstein 5100s | JBA UCA | Spidertrax | 265/70/17 Falken Wildpeak AT3 | PowerStop Z23 F/R
CarolinaLGRW is offline   Reply With QuoteReply With Quote
blew , gasket , gen , head , love
Bad_Vision's 1985 Toyota 4RUNNER TDI Swap (Completed swap) Bad_Vision Classic T4Rs 211 10-06-2019 10:56 PM
Swap 4Runner for LC DCOURTS1984 5th gen T4Rs 15 07-03-2018 05:43 PM
86 4runner 5.3 swap lsx angle Classic T4Rs 11 03-08-2015 09:53 PM
95 3.0 into 90 4runner swap. runnerDan Classic T4Rs 3 11-04-2014 05:24 PM
fun 4runner swap Toker Classic T4Rs 2 10-17-2011 10:49 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
