Old 10-30-2019, 08:53 AM #16
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
Originally Posted by pahaf91 View Post
Ebay LCA Lower control arms
I got the ebay LCA and i use my 4Runner for more off roading then the average person on here i bet. I take it to trails at least 2x a week. And these are serious trails. I had no complaints at all.
Only issue installing these on my 4Runner was that one of the cam bolts was seized so i had to cut it off.
good perspective right there
hinmo24t is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 11:45 AM #17
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough
phatcheeks's Avatar
Both my lower ball joints are leaking. Might pick these up soon.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
phatcheeks is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 03:00 PM #18
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
I say keep the OEM hardware and get the urethane insert kits. The stock rubber bushings simply can't handle off roading and just rip apart. The good thing is that if you do urethane, you will never have to worry about breaking the bushings or noisy suspension. The uni-ball UCA's and LCA's all make a ton of noise, especially the heim joint versions. If you wan't your truck to sound like the Titanic hitting every rock ever conceived by humanity, ebay has lots of awesome chinese parts available.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 03:10 PM #19
solid metaphor
Old 10-31-2019, 04:30 PM #20
phatcheeks's Avatar
phatcheeks's Avatar
Where do I get these urethane inserts? I wanted to change the whole LCA becuase I heard the ball joint is a paint to remove.
Old 11-01-2019, 01:04 PM #21
here:
Unusual Activity Detected - Free Shipping on Orders Over $99 at Summit Racing
Also, with regards to the lower ball joint. Is it truly a pain to remove? Ball joint removers are cheap and easy to use, it might take you 30 minutes to do both of them with the right tool.
2005 Blue SR5 v8
Old 03-14-2020, 08:42 PM #22
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
Originally Posted by Captsolo View Post
I put the LCAs on my 2005 SR5 (150,000) a few years ago. They came with two bushings, and the mechanic at the Alignment shop said I should get them. Ours were AM, and worked great. Check out sway bars too... they are cheap and easy to find.
Amazon.com: Detroit Axle - Pair (2) Front Lower Control Arms + Ball Joints for 2003-2009 Lexus GX470 - [2003-2009 Toyota 4Runner] - 2007-2009 Toyota FJ Cruiser: Automotive
AM? Also, how are they holding up these days? Bushings still in tact?
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 03-14-2020, 09:27 PM #23
04rnr's Avatar
04rnr 04rnr is offline
04rnr is a jewel in the rough 04rnr is a jewel in the rough 04rnr is a jewel in the rough
04rnr's Avatar
Originally Posted by Berty_K View Post
Go OEM for LCAs. Lots of threads on problems with aftermarket.
Zero issues here with after market, after 2 years and to many trails to list I havent had a single issue.
2007 Sport.
"Colorado is FULL, try N.M."
"Everyone is an expert"
04rnr is offline   Reply With QuoteReply With Quote
Old 03-20-2020, 05:15 PM #24
HIMILESV8SPORT's Avatar
HIMILESV8SPORT HIMILESV8SPORT is offline
HIMILESV8SPORT is on a distinguished road
got new OEM LCA's and new hardware, used 20k mile UCA's
I still have my first car since 96, so I know when I'll be keeping something and want to get another 300,000 miles out of this 4R. Got OEM LCA's for right at $600 for the pair, and picked up used 2017 UCA's for $100. Hardware for lower and upper was right at $175. Hopefully I can find some TP to trade a tech for an alignment like I did for an O2 sensor install Wednesday...haha. Anyone want to buy my old LCA's???
Eibach pro truck with WOR springs on 1st notch in front. 5100's in rear w/ FJ OEM takeoff coils. 255/70R18 on 18" Limited wheels. 1.5" spacers on rear(one trimmed a bit to correct lean). Gibson catback, 06+Headlamps, auxito 16K bulbs in high, low, and fogs!
HIMILESV8SPORT is offline   Reply With QuoteReply With Quote
arms , lower , oem , recommended , toyota
WTB: 4th gen OEM lower control arms Brian3676 Want to Buy/Trade 2 07-12-2019 11:22 PM
WTB: 4th Gen lower control arms whosandrew For Sale: Suspension/Wheels/Tires 1 08-15-2018 03:31 PM
WTB - 5th gen Lower Control Arms Jetboy Want to Buy/Trade 0 01-13-2018 12:37 PM
WTB: 3rd gen upper/lower control arms/rear trailing arms BADCLOWN Want to Buy/Trade 2 05-24-2017 03:11 PM
