Originally Posted by xavier847
Well, pouring over the Torque Pro app I noticed that the RPMs are off by 500 between OBD2 and tachometer, the obd2 reading 500 higher. I know that my speedometer is off because I'm running slightly bigger tires than stock, but that should have nothing to do with engine rpm. I can't find anything on the net referencing this discrepancy.
Also, I'm starting to get a p0012 code, so I can at least get codes, but still no CEL. The Torque Pro app/OBD2 says that the timing is advanced 25 degrees on average, not sure how off the timing would be to pop the p0012 code but I did replace the camshaft position sensor during this installation, so I'm thinking that maybe the wire fix I did wasn't perfect. It runs perfectly(no hesitation, starts fine, and solid throttle response) and my MPG seems the same, if I'm ***** footing I can get up to 18mpg.
Are you still not seeing the CEL when you turn the ignition to on but not to start?
If not then you do have a issue causing that for sure, the CEL should be on until you start the engine and for it to be throwing the P0012 code the CEL should also be on when running, so I'm guessing the CEL is actually on but either the bulb is burned out or there a short causing it to not turn on, could be the wires you pinched and they may not be patched correctly or maybe when they got pinched it burned out the bulb or the circuit in the instrument cluster.
At this point since it seems to be running well I can't imagine the timing is off as much as the app is saying it is, I would try and track down why the CEL is not on, fixing that may solve your issues, or at least it will be one less issue you have, I know you said you tested the new cam sensor, but have you tried putting the old one back in to see if there's still an issue?
