Old 10-28-2019, 10:33 PM #1
doofenshmirtz doofenshmirtz is offline
doofenshmirtz has a spectacular aura about doofenshmirtz has a spectacular aura about
DIY Engine Splash Shields
So I wanted to get some splash shields made since I’ve never had any. I’ve gone through all the threads and have had Rad Rubber shields in my shopping cart a dozen times but could never bring myself to pay knowing I could do it myself.
I’ve seen the trash can plastic ones and the rubber sheet ones, and I downloaded the scans someone posted of theirs to be able to redraw the file.
I went so far as to have my office laser cut some sheet metal ones to see if it would work, but the factory design won’t work. Still might do some metal ones eventually.
Anyway, the rubber sheet one seemed like a good start. The biggest factor is getting as small of a sheet as possible. That’s where I think I’ve done something not yet documented/answered. I think your minimum rubber sheet size is going to be 12x36. That size will only work while hand cutting, but at that size, you can get the same material Rad Rubber uses for half the price. They use 1/8” nitrile, and that can be had on Amazon for about $26 currently. Add a few bucks for clips and you can save about $28 making your own. If your time is worth more than that and you want rubber/nitrile or you’ve got a body lift that makes the splash shield bigger, then Rad Rubber is going to be the way to go. You can also easily go to 1/16” thick and save some extra money too.
In case anyone wants to see how to lay these out for the smallest sheet here’s a photo with everything fitting in a 12x36 bounding box. I’ll document how things work outlasted this week.
doofenshmirtz is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 12:23 AM #2
SoFL Runner's Avatar
SoFL Runner SoFL Runner is offline
SoFL Runner is on a distinguished road
I’m interested in seeing how these get mounted on. I’ve got a 1” body lift and have that gap. I’ve bounced around the idea of doing it myself but I’ve been in your same shoes with Rad Rubber and decided if I should pay to avoid the trouble.
2006 4Runner V8|King Suspension|Built Right UCA|
Total Chaos|Toyo Open Country R/T|BMF sliders|
Retrofitsource.com|Baja Designs|
The build continues...
SoFL Runner is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 06:22 AM #3
Bernardchan96 Bernardchan96 is offline
Real Name: Bernard Chan
Bernardchan96 is on a distinguished road
Hm, i just made my own splash guards last week, i literally printed the pdfs out on 8x11 paper, then cut and tape them together. Went to a local rubber shop and bought a 4'x1' sheet of 1/16 nitrile buna rubber for $26 (Canadian dollars) and cut them out and punched the holes. all in all pretty simple and saved me about $70 from buying from Rad
Bernardchan96 is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 10:53 AM #4
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
made mine over the weekend and have a clip kit waiting for me for after work today
hinmo24t is offline   Reply With QuoteReply With Quote
Old 10-30-2019, 01:59 PM #5
So the rubber sheet came in, and it was a perfect size for the splash guards. The metal templates made things really easy. I just traced everything with a sharpie and then used tin snips to cut the sheet: it was like cutting paper using those... I grabbed a drill bit to do all the holes.
I’m pretty sure it took longer to pull out all the old fasteners than it did to trace and cut the new rubber pieces, but I was done in less than an hour.
While I was down there, I noticed a nut had come off my sway bar so I fixed that after I took the picture. I spent a total of $33 on everything, which includes a few hundred more cheap Chinese fasteners.
Old 10-30-2019, 04:26 PM #6
djpope09 djpope09 is offline
djpope09 will become famous soon enough
Do you have a link for the fasteners?
djpope09 is offline   Reply With QuoteReply With Quote
Old 10-30-2019, 04:33 PM #7
To be honest, I'm not pleased with what I got. If I gave you the link, it would be more to see what NOT to buy. I bought a huge set of like 600 parts, and there was only one type of fastener in there that worked, and I used 1/3 of them on just this project :/
Old 10-31-2019, 03:55 AM #8
originalg00kster's Avatar
originalg00kster originalg00kster is offline
originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough
I love my rad rubber design splash guards. Came with everything needed to install. The clips hold it in real good, a couple of different sizes all together. Great quality as well, I'm sure it'll last a long time.
07 SR5 4x4
originalg00kster is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 07:02 AM #9
Terminator03 Terminator03 is offline
Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough
I made a set as one of my first “mods” a couple of years back since mine were missing when I got the truck. I used some 1/8” rubber mat that came in a roll from Home Depot. I had some left from a work project, and it was perfect. Has a nice texture resembling bedliner. I used the .pdf file someone posted on here for the patterns. The hardest part was finding fasteners that fit properly! I ended up drilling a couple of them a bit larger to accommodate some thicker push fasteners that I had which were maybe 3/8” diameter. Since they heavily salt the roads up here in the winter, I wanted the shields to keep as much out of the engine bay as possible! I don’t have a body lift though, so I was able to just use the templates as they were.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 10:57 AM #10
i got my tote lid blue ones above secured with this kit:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
you notice the warp in material when attached, designed to account for variables distances between frame and body
Old 10-31-2019, 09:45 PM #11
AZ07Runner's Avatar
AZ07Runner AZ07Runner is offline
AZ07Runner is on a distinguished road
AZ07Runner's Avatar
I did this a while back, but added a little more around the edges for added strength. Kept the same holes.
07 Limited V8 Titanium Metallic
Bilstein 5100s x4, Fronts set on 0 with OME 885s, Sway-A-Way 1.5 rear coils, JBA UCAs, '12 Trail wheels, Cooper AT3s 265/70/17, Mobil1 0W40, Amsoil Severe Gear 75W90 and SS ATF.
(Previous truck: 1993 Toyota DLX, V6, 4x4, Xcab, 5 speed, Pewter Pearl - owned from day 1)
http://www.toyota-4runner.org/4th-ge...ml#post2069269
AZ07Runner is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 10:22 PM #12
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
Love this idea but have an idea on how to make these better. There are extra holes in areas that would allow for larger shields which would further protect the engine bay. Has anyone made oversized guards to cover the whole area under there? Maybe even one large piece that goes up over the shock tower and over to the other side?
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 11-02-2019, 01:00 PM #13
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
Yup.
Used some clear plastic sheet to make a template.
Covered the whole hole on mine, worked very well.
Much cleaner engine bay than OEM and no noticed temperature increase. (scangauge2)
8.5mm push clips.
DIY - Creating and Installing 4th Gen Wheel Well Splash Shields
New...and gratuitous Elka plug.
DIY Engine Splash Shields-img_8389-jpg  DIY Engine Splash Shields-img_8403-jpg
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 11-02-2019, 02:28 PM #14
Originally Posted by BackOff View Post
Yup.
8.5mm push clips.
These look great! I know this topic has been discussed a dozen times, but it's nice to have a good bit of the high notes in one thread for other people.
i’ve , rubber , sheet , splash , work
DIY - Creating and Installing 4th Gen Wheel Well Splash Shields Bluesky 07 4th Gen T4Rs 30 11-28-2022 05:29 PM
Upgraded my inner fender splash shields Notch46 5th gen T4Rs 19 06-09-2020 11:06 AM
Flapping Engine Splash Guard ToyoTacoTurner 5th gen T4Rs 18 11-03-2018 10:45 PM
Quick question. How many splash shields? Utopia 4th Gen T4Rs 1 07-21-2016 04:37 PM
WTB: Splash guard - Between Passenger and engine s20004runner Want to Buy/Trade 4 02-27-2016 02:59 PM
