Old 10-29-2019, 10:06 AM #1
Jan777 Jan777 is offline
Jan777 is on a distinguished road
need to rebuild the transfer case, best source for parts in EUROPE?
The transfer case started giving me troubles again, after I had the chain replaced exactly two years ago. When accelerating or starting from a steep uphill position the chain skips on the cogwheel. And the shifters are also stuck.
Its a pretty standard operation but my problem is that I have a U.S. T4R Limited V8 in Europe and importing parts through the dealer is out of question. Much too expensive! Also 2nd hand for these type of parts is not the best idea.
So I am looking for a source for new bearings, chain & gaskets of the transfer case in Europe! Any hints?
Jan777 is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 01:18 PM #2
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
If you're having repeated chain failures in the tcase, you need to investigate why. Unless you are really stressing it in low-range, those things should last forever, and chain failures are very rare.
I would check for adequate lubrication first, and then, if you have it apart, make sure the the sprockets are aligned. Someone may have installed a bearing or thrust washer improperly the last time it was rebuilt, causing misalignment and early failure. There's also a possibility of an improperly assembled oil pump, leading to poor lubrication.
The fact that your shifters are stuck leads me to believe there might be a lubrication issue.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 02:18 PM #3
Zeke588's Avatar
Zeke588 Zeke588 is offline
Real Name: Zeke
Zeke588 will become famous soon enough
Zeke588's Avatar
Real Name: Zeke
Might be time for a new transfercase? If it were me I would assess the damage that has been done and see if its worth fixing it and risking it failing again, or just getting a completely new tcase.
03 V8 limited. Bilsteins, rear OME 895e springs. 285/75/16 Nitto Terra Grapplers Tacoma Wheels.
1993 4runner 3 inch lift 33/12.5/15 KO2 SOLD
Zeke588 is offline   Reply With QuoteReply With Quote
case , chain , europe , parts , transfer
Transfer case rebuild thread? eimkeith 3rd gen T4Rs 14 10-24-2019 05:17 AM
Transfer case rebuild TNFISHRMAN 4th Gen T4Rs 16 08-16-2019 08:56 PM
Source for Front End rebuild Parts DED&DED 3rd gen T4Rs 9 03-20-2017 07:23 PM
Transfer case rebuild question Jcamero 3rd gen T4Rs 2 12-03-2011 01:19 PM
Advance Adapters 50-5705 Transfer Case Adapter 700R-4 To A Toyota Transfer Case 21 To NMRunner Classifieds - buy & sell (no commercial ads please) 0 08-18-2010 11:42 PM
