Old 10-30-2019, 10:26 AM #1
Hunter.Cribb's Avatar
Hunter.Cribb Hunter.Cribb is offline
Real Name: Hunter
Hunter.Cribb is on a distinguished road
Real Name: Hunter
Intermittent Popping spring like noise from reverse to drive??
I have a 2006 Toyota 4Runner limited V6 4wd with 158,000 miles. Every so often when I’m backing out of a parking spot turn the wheel then put form reverse to drive I get a loud noise that sounds like a spring popping of of something. I can feel it through the brake pedal and also slightly through the steering wheel. Any ideas??
2006 Limited V6 4WD, Natural White (Sold)
2006 Limited V8 4WD, Salsa Red Pearl
Hunter.Cribb is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 08:40 AM #2
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 will become famous soon enough
Real Name: Newell
That is common on a lot of vehicles. My 08 does the same thing.
I believe it is just due to excess play between the pad/shim & caliper. The pad shifts as the caliper compresses and then hits on the edge due to the rotation of the rotor.
Nothing to be concerned over.
UrbanRunner651 is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 09:13 AM #3
Real Name: Hunter
Real Name: Hunter
Thanks for the reply! That’s good to hear. I just have never heard it before. I guess since I just had calipers put on recently it makes since.
Old 11-01-2019, 08:56 AM #4
Real Name: Newell
Real Name: Newell
Usually due to a non-OEM pad/caliper combination. As long as you don't hear any grinding or strange continual/intermittent noises that relate to wheel rotation you'll be fine.
Old 11-01-2019, 11:47 AM #5
AceSpades AceSpades is offline
AceSpades is on a distinguished road
im thinking its the coil spring binding on its seat. Ive seen that problem on a previous Ford Ranger
AceSpades is offline   Reply With QuoteReply With Quote
drive , noise , reverse , spring , wheel
Reverse to Drive weird clicking noise webbbj 4th Gen T4Rs 6 04-11-2015 08:29 PM
Popping noise after starting and putting in reverse Y2KSR5 5th gen T4Rs 4 05-08-2014 02:42 PM
Intermittent auto trans noise in Drive when stopped Steve240 3rd gen T4Rs 4 01-15-2014 05:12 PM
Going from reverse to drive noise mikey's2010SR5 5th gen T4Rs 1 03-01-2010 07:11 PM
