Old 11-03-2019, 06:13 PM #1
chuntmd chuntmd is offline
Real Name: Chris
chuntmd is on a distinguished road
Real Name: Chris
Frame broke, worth fixing or make-me-an-offer!
My 04 v8 limited with 277,000 miles needed a timing belt and was leaking ATF due to one of the hard cooling lines had corroded and bulged out. Took it to Laurel Toyota Carmax (tow, see pic below) and while on the lift and changing the oil the tech heard a weird noise.
On the passenger side the frame has rusted out. More rust is on top of the frame as you move towards the front.
Driver's side looked good. The 4R was in Ohio from 04 to 10 when I moved it to MD. 80 mile commute M-F.
Worth fixing?
Frame broke, worth fixing or make-me-an-offer!-4runner_pass_frame1-jpg  Frame broke, worth fixing or make-me-an-offer!-4runner_driver-frame1-jpg  Frame broke, worth fixing or make-me-an-offer!-20191101_082832-jpg
chuntmd is offline   Reply With QuoteReply With Quote
Old 11-03-2019, 06:47 PM #2
radlynx radlynx is offline
Registered User
radlynx will become famous soon enough
Registered User
Rust is not too bad. It's better to get it fixed.
radlynx is offline   Reply With QuoteReply With Quote
Old 11-03-2019, 07:57 PM #3
Kryptoroxx's Avatar
Kryptoroxx Kryptoroxx is offline
Real Name: John
Kryptoroxx has a spectacular aura about Kryptoroxx has a spectacular aura about
Kryptoroxx's Avatar
Real Name: John
Another vote for fixing it here. After you get it fixed clean up the frame and get a sealer on it. You're going to want to do the inside as well to keep this from getting any worse.
To find out if you have any more spots lurking take a small hammer and tap on your frame all over. Gotta find that stuff and head it off before anything else happens.
98 Toyota 4runner 3rz 5spd 4x4 - Sold Build Thread
06 4runner 2uz Build Build Thread
Instagram: @Kryptowerkz
Kryptoroxx is offline   Reply With QuoteReply With Quote
Old 11-03-2019, 08:04 PM #4
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
There is a v8 runner being parted out in the classifieds here, pretty sure the frame is still available...
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 11-03-2019, 08:41 PM #5
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Worth fixing?
I agree that from just looking at the photos the rust area looks like it could be repaired....BUT the OP did also state that there's rust on top of the frame that isn't shown in the photos, no way for us to judge that rust for possible repair and that rust could be much worse....also as many know much of this type rust is also coming from the inside out and there's no way for us to judge just how badly that rust on the inside is, the only way to know for sure is too use a bore scope/snake camera to get a good look inside the frame.
That all being said I'm sorta on the fence on telling the OP that it can be fixed without having more info/photos.
2004 Limited V8
Old 11-05-2019, 01:41 AM #6
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
Looks similar to brand new 2018 Jeep JL Wranglers.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 11-05-2019, 07:33 AM #7
Bernardchan96 Bernardchan96 is offline
Real Name: Bernard Chan
Bernardchan96 is on a distinguished road
Worth fixing?
Honestly looks quite fixable for a respected welder. But im surprised to see just those weld points rust, but the rest of the frame looks clean or maybe its just that picture. I live in ontario canada so rust on mine is present although not on the weld points as much, more on the bottom but i have since treated with por-15.
get a quote from a body repair shop to see how much it costs, although it would be quite pricey to get it fixed, its much better than a car payment and the rest of the frame looks solid, although we would need more pictures of it.
Bernardchan96 is offline   Reply With QuoteReply With Quote
fixing , frame , side , top , worth
Worth fixing? (Rust) Neil_R 3rd gen T4Rs 16 01-30-2023 03:32 PM
3rd Gen 4Runner Front Frame Assembly, Differential, Make Offer, Fair Oaks , CA, 95628 Toyotadude88 For Sale: T4R Items 0 11-16-2014 11:09 PM
Fixing a frame KidVermicious Classic T4Rs 41 11-26-2013 08:44 AM
Will this be worth fixing? Lowriderman234 3rd gen T4Rs 4 08-15-2012 08:12 PM
is it worth fixing smurf216 Classic T4Rs 2 09-24-2007 08:28 PM
