Old 11-04-2019, 05:53 PM #1
ted4r ted4r is offline
ted4r is on a distinguished road
Dreaded V8 Secondary Air Failure - kits?
Hi Folks,
2006 V8 4Runner Limited.
It finally happened to me, at 105k miles. I started the car yesterday morning and got the shopvac - after a quick WTF second I realized exactly what it was, revved the engine and it went right away and didn't come on for the rest of the day including 2 warm-ish starts. This morning it happened again, revved it and it went away, then came right back on. Revved it again and it went off. No codes thrown as of yet. I drove it and then parked it, until I get a bypass installed.
I have been looking around and there seems to be three kits - the Slyfox kit which is the least expensive but requires splicing and extra cost for block plates; Hewitt which has a partial plugnplay, with a plug in at the MAF and a wire to the starter relay, and comes with plates; and the Rutech which is similar in price but true plugnplay with simply plug at the MAF and also comes with plates.
I would truly appreciate any thoughts folks might have on this - I don't mind paying more for the Rutech to get truly plug and play, but want to make sure it has the same basic features as the other two. The only operational differences I can see so far are the Rutech must start within 10-seconds, the Hewitt within 5(?) and I am not sure about the Slyfox kit.
Any thoughts sure appreciated!
Ted
ted4r is offline   Reply With QuoteReply With Quote
Old 11-04-2019, 05:56 PM #2
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
Originally Posted by ted4r View Post
Hi Folks,
Ted
Stop driving it. Also no need for block off plates with slyfox kit. I have it and it works fine. Takes 5 min to install.
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 11-04-2019, 09:41 PM #3
Shiftless Joe's Avatar
Shiftless Joe Shiftless Joe is offline
Shiftless Joe is on a distinguished road
I went with Hewitt Tech, but I hear nothing but good things about Slyfox's kit.
2005 - 2007 Plug & Play SAIS Bypass Kit
Shiftless Joe is offline   Reply With QuoteReply With Quote
Old 11-05-2019, 07:30 AM #4
Bernardchan96 Bernardchan96 is offline
Real Name: Bernard Chan
Bernardchan96 is on a distinguished road
Hi Folks,
Ted
Had the same issue this summer with the Secondary Air Injection, although mine did not seem to make a shopvac sound (probably did), it would throw a code p2445 i think, and it would actually go into limp mode and could not accelerate or go to highway speeds. The limp mode would go away after clearing the codes and drive like normal but come back within 100km. Bought the slyfox kit shipped to canada, came with instructions and all accessories needed. Mind you i am terrible with electrics and still managed to install the kit in 15 minutes. The truck is all fine now, and its been months since the first code thrown.
Bernardchan96 is offline   Reply With QuoteReply With Quote
Old 11-05-2019, 11:12 AM #5
Thanks for all of the replies folks, much appreciated. I will freely admit when it comes to working on cars and motorcycles I am quite confident mechanically, but a disaster electrically. The Rutech simple plug and go solution is what is drawing me their way - just want to make sure that all three kits mentioned basically function the same way, just have different ways of getting there.
Still can't figure out how Rutech eliminates the Hewitt purple wire but offers the same bypass?
Old 11-05-2019, 02:26 PM #6
Well I think I have answered my own questions
From reading a lot of threads here and things online, looks like the Slyfox and Hewitt kits work pretty much exactly the same. The difference is that Hewitt comes all nicely wrapped up in a custom plug, and the Slyfox saves you about $100 by requiring you to splice into the existing wiring.
Rutech eliminates the purple starter wire used by the Slyfox and Hewitt kits, and adopts the Hewitt custom plug approach with a timer on the starter. Upside is that it is truly a 30-second plug and play, downside is it only is effective if you start within 10-seconds of turning to on. Wait any longer and the override will not function and you're back in code-city.
My 4Runner just started with the vacuum noise, and has not thrown any codes yet (three starts with the vacuum noise - which only made noise for a second or two before revving the engine and having the noise stop - been parked since.) I am hoping I've limited any damage they might have been caused (are the codes immediate?) and will likely go with Slyfox or Hewitt for peace of mind.
Old 11-05-2019, 02:45 PM #7
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
If you don't mind the DIY wiring Slyfox's bypass + Hewitt block off plates will save you some money.
Old 11-13-2019, 04:26 PM #8
stopthefury stopthefury is offline
stopthefury is on a distinguished road
PM sent!
stopthefury is offline   Reply With QuoteReply With Quote
Old 11-14-2019, 06:12 PM #9
toddtt19 toddtt19 is offline
toddtt19 is on a distinguished road
Good info.
toddtt19 is offline   Reply With QuoteReply With Quote
plates; , plug , revved , rutech , thoughts
Secondary Air Injection Pump Failure on V8's! Important! Billynath1988 4th Gen T4Rs 545 02-05-2024 08:24 AM
secondary air injection help Txjcb5002 4th Gen T4Rs 10 08-27-2020 12:21 PM
Dreaded Head Gasket Failure - Looking for engine swap advice 00_4runner 4th Gen T4Rs 9 11-18-2019 10:31 PM
Anyone Have A Secondary Vehicle? MrSeth General Discussions 78 09-11-2017 08:52 PM
Toyota IFS Eliminator kits and Classic kits. FREE SHIPPING AddictedOffroad Addicted Offroad 0 02-14-2011 01:45 PM
